<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[lopy sigfox know if message is sent]]></title><description><![CDATA[<p dir="auto">Hi, i'm working with lopy4 and sigfox. I'm able to send message to sigfox, it works.<br />
Is there any option to know if message that i sent is corretly arrived to sigfox? i need to know because sometimes i don't have network coverage and i would to implement a caching system that store gps position if sigfox didn't receive message</p>
<p dir="auto">thanks a lot<br />
best<br />
Andrea</p>
]]></description><link>https://forum.pycom.io/topic/4276/lopy-sigfox-know-if-message-is-sent</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 18:37:38 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4276.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Jan 2019 11:13:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to lopy sigfox know if message is sent on Fri, 25 Jan 2019 11:13:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi, i'm working with lopy4 and sigfox. I'm able to send message to sigfox, it works.<br />
best<br />
Andrea</p>
]]></description><link>https://forum.pycom.io/post/25195</link><guid isPermaLink="true">https://forum.pycom.io/post/25195</guid><dc:creator><![CDATA[raaden89]]></dc:creator><pubDate>Fri, 25 Jan 2019 11:13:01 GMT</pubDate></item><item><title><![CDATA[Reply to lopy sigfox know if message is sent on Fri, 25 Jan 2019 13:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2581">@raaden89</a> Simply you can't. Sigfox as very very low downlink ability ( network to your device as 4*8 bytes limits per day!) .<br />
You just can't design this functionnality as is, and you need to think to another way to work.<br />
exemple:wait in your device for a downlink coming from sigfox with a sequencial number index, send after that the gps pos with following index and so on. On the next download your device will receive a new index (or the same at the last time if no uplink as been successfull) and your device will restart to send the gps pos following the index recevied.</p>
]]></description><link>https://forum.pycom.io/post/25199</link><guid isPermaLink="true">https://forum.pycom.io/post/25199</guid><dc:creator><![CDATA[Eric73]]></dc:creator><pubDate>Fri, 25 Jan 2019 13:36:05 GMT</pubDate></item></channel></rss>
