<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GPy Initial Startup Connection Issues]]></title><description><![CDATA[<p dir="auto">Hi, I just received the GPy module with the Expansion board 3.0. I updated the expansion board 3.0. Then attached the it as described. I see that the board is not detected with the gpy attached on the mac.</p>
<p dir="auto"><img src="/assets/uploads/files/1549057315508-5868c6b0-56ce-4ae4-985e-55600033b746-image.png" alt="0_1549057315424_5868c6b0-56ce-4ae4-985e-55600033b746-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">Only Expansion board 3.0 is able to connect:<br />
<img src="/assets/uploads/files/1549057427804-7677e8c1-8a7f-4fb5-bffe-edb0a5b5a559-image.png" alt="0_1549057427715_7677e8c1-8a7f-4fb5-bffe-edb0a5b5a559-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">Few resets sometimes results in constant Red Led or green led blinks on the gpy.</p>
<p dir="auto">Has anyone had similar issues?<br />
<img src="/assets/uploads/files/1549057270149-screenshot_2_1_19__4_40_pm-resized.jpg" alt="0_1549057269071_Screenshot_2_1_19__4_40_PM.jpg" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/topic/4323/gpy-initial-startup-connection-issues</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 19:32:14 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4323.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Feb 2019 21:44:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GPy Initial Startup Connection Issues on Fri, 01 Feb 2019 21:44:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I just received the GPy module with the Expansion board 3.0. I updated the expansion board 3.0. Then attached the it as described. I see that the board is not detected with the gpy attached on the mac.</p>
]]></description><link>https://forum.pycom.io/post/25483</link><guid isPermaLink="true">https://forum.pycom.io/post/25483</guid><dc:creator><![CDATA[aventri]]></dc:creator><pubDate>Fri, 01 Feb 2019 21:44:52 GMT</pubDate></item><item><title><![CDATA[Reply to GPy Initial Startup Connection Issues on Sat, 02 Feb 2019 00:17:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3932">@aventri</a> My guess is that you haven't installed the drivers to allow you PC to see the Expansion Board com port? When I was starting with GPY, I found this tutorial from Core Electronics in Australia, to be very helpful..<br />
<a href="https://core-electronics.com.au/tutorials/pycom-gpy-getting-started.html" target="_blank" rel="noopener noreferrer nofollow">https://core-electronics.com.au/tutorials/pycom-gpy-getting-started.html</a></p>
<p dir="auto">It is Windows centric, but there are others to be found as well</p>
]]></description><link>https://forum.pycom.io/post/25486</link><guid isPermaLink="true">https://forum.pycom.io/post/25486</guid><dc:creator><![CDATA[Stevo52]]></dc:creator><pubDate>Sat, 02 Feb 2019 00:17:03 GMT</pubDate></item></channel></rss>
