<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Porting adafruit TSL2591 micropython to Pycom library]]></title><description><![CDATA[<p dir="auto">I'm trying to port this code in from Adafruit and not seeing what it's doing to trip up..  I've succeeded in getting several other libraries working, but it seems that each one is written completely differently, so it's not been as simple as tweak a few lines.  :(</p>
<pre><code>Now starting user code in main.py
  File &quot;main.py&quot;, line 17, in &lt;module&gt;
  File &quot;/flash/lib/tsl2591.py&quot;, line 116, in __init__
  File &quot;/flash/lib/tsl2591.py&quot;, line 129, in _read_u8
TypeError: can't convert bytearray to int
</code></pre>
<p dir="auto">/lib/tsl2591.py:</p>
<pre><code># The MIT License (MIT)
# Copyright (c) 2017 Tony DiCola for Adafruit Industries
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the &quot;Software&quot;), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED &quot;AS IS&quot;, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
# THE SOFTWARE.
&quot;&quot;&quot;
`adafruit_tsl2591`
CircuitPython module for the TSL2591 precision light sensor.  See
examples/simpletest.py for a demo of the usage.
* Author(s): Tony DiCola
Implementation Notes
**Hardware:**
* Adafruit `TSL2591 High Dynamic Range Digital Light Sensor
  &lt;https://www.adafruit.com/product/1980&gt;`_ (Product ID: 1980)
**Software and Dependencies:**
* Adafruit CircuitPython firmware for the ESP8622 and M0-based boards:
  https://github.com/adafruit/circuitpython/releases
* Adafruit's Bus Device library: https://github.com/adafruit/Adafruit_CircuitPython_BusDevice
&quot;&quot;&quot;
from micropython import const
#import adafruit_bus_device.i2c_device as i2c_device
from machine import I2C,Pin
#__version__ = &quot;0.0.0-auto.0&quot;
#__repo__ = &quot;https://github.com/adafruit/Adafruit_CircuitPython_TSL2591.git&quot;
#pylint: disable=bad-whitespace
# Internal constants:
_TSL2591_ADDR                = const(0x29)
_TSL2591_COMMAND_BIT         = const(0xA0)
_TSL2591_ENABLE_POWEROFF     = const(0x00)
_TSL2591_ENABLE_POWERON      = const(0x01)
_TSL2591_ENABLE_AEN          = const(0x02)
_TSL2591_ENABLE_AIEN         = const(0x10)
_TSL2591_ENABLE_NPIEN        = const(0x80)
_TSL2591_REGISTER_ENABLE     = const(0x00)
_TSL2591_REGISTER_CONTROL    = const(0x01)
_TSL2591_REGISTER_DEVICE_ID  = const(0x12)
_TSL2591_REGISTER_CHAN0_LOW  = const(0x14)
_TSL2591_REGISTER_CHAN1_LOW  = const(0x16)
_TSL2591_LUX_DF              = 408.0
_TSL2591_LUX_COEFB           = 1.64
_TSL2591_LUX_COEFC           = 0.59
_TSL2591_LUX_COEFD           = 0.86
_TSL2591_MAX_COUNT_100MS     = const(36863) # 0x8FFF
_TSL2591_MAX_COUNT           = const(65535) # 0xFFFF
# User-facing constants:
GAIN_LOW                  = 0x00  # low gain (1x)
&quot;&quot;&quot;Low gain (1x)&quot;&quot;&quot;
GAIN_MED                  = 0x10  # medium gain (25x)
&quot;&quot;&quot;Medium gain (25x)&quot;&quot;&quot;
GAIN_HIGH                 = 0x20  # medium gain (428x)
&quot;&quot;&quot;High gain (428x)&quot;&quot;&quot;
GAIN_MAX                  = 0x30  # max gain (9876x)
&quot;&quot;&quot;Max gain (9876x)&quot;&quot;&quot;
INTEGRATIONTIME_100MS     = 0x00  # 100 millis
&quot;&quot;&quot;100 millis&quot;&quot;&quot;
INTEGRATIONTIME_200MS     = 0x01  # 200 millis
&quot;&quot;&quot;200 millis&quot;&quot;&quot;
INTEGRATIONTIME_300MS     = 0x02  # 300 millis
&quot;&quot;&quot;300 millis&quot;&quot;&quot;
INTEGRATIONTIME_400MS     = 0x03  # 400 millis
&quot;&quot;&quot;400 millis&quot;&quot;&quot;
INTEGRATIONTIME_500MS     = 0x04  # 500 millis
&quot;&quot;&quot;500 millis&quot;&quot;&quot;
INTEGRATIONTIME_600MS     = 0x05  # 600 millis
&quot;&quot;&quot;600 millis&quot;&quot;&quot;
#pylint: enable=bad-whitespace
class TSL2591:
    &quot;&quot;&quot;TSL2591 high precision light sensor.
        :param busio.I2C i2c: The I2C bus connected to the sensor
        :param int address: The I2C address of the sensor.  If not specified
        the sensor default will be used.
    &quot;&quot;&quot;
    # Class-level buffer to reduce memory usage and allocations.
    # Note this is NOT thread-safe or re-entrant by design.
    _BUFFER = bytearray(2)
    def __init__(self, i2c, address=_TSL2591_ADDR):
        self._integration_time = 0
        self._gain = 0
        self.i2c=I2C(pins=(&quot;P9&quot;,&quot;P10&quot;))
        #self._device = i2c_device.I2CDevice(i2c, address)
        # Verify the chip ID.
        if self._read_u8(_TSL2591_REGISTER_DEVICE_ID) != 0x50:
            raise RuntimeError('Failed to find TSL2591, check wiring!')
        # Set default gain and integration times.
        self.gain = GAIN_MED
        self.integration_time = INTEGRATIONTIME_100MS
        # Put the device in a powered on state after initialization.
        self.enable()
    def _read_u8(self, address):
        # Read an 8-bit unsigned value from the specified 8-bit address.
        #with self._device as i2c:
            # Make sure to add command bit to read request.
        self._BUFFER[0] = (_TSL2591_COMMAND_BIT | address) &amp; 0xFF
        self.i2c.writeto(self._BUFFER, end=1, stop=False)#line 129
        self.i2c.readinto(self._BUFFER, end=1)
        return self._BUFFER[0]
    # Disable invalid name check since pylint isn't smart enough to know LE
    # is an abbreviation for little-endian.
    #pylint: disable=invalid-name
    def _read_u16LE(self, address):
        # Read a 16-bit little-endian unsigned value from the specified 8-bit
        # address.
        self.i2c.write(self._BUFFER, end=1, stop=False)
        self.i2c.readinto(self._BUFFER, end=2)
        return (self._BUFFER[1] &lt;&lt; 8) | self._BUFFER[0]
    #pylint: enable=invalid-name
    def _write_u8(self, address, val):
        # Write an 8-bit unsigned value to the specified 8-bit address.
            # Make sure to add command bit to write request.
        self._BUFFER[1] = val &amp; 0xFF
        self.i2c.write(self._BUFFER, end=2)
    def enable(self):
        &quot;&quot;&quot;Put the device in a fully powered enabled mode.&quot;&quot;&quot;
        self._write_u8(_TSL2591_REGISTER_ENABLE, _TSL2591_ENABLE_POWERON | \
                       _TSL2591_ENABLE_AEN | _TSL2591_ENABLE_AIEN | \
                       _TSL2591_ENABLE_NPIEN)
    def disable(self):
        &quot;&quot;&quot;Disable the device and go into low power mode.&quot;&quot;&quot;
        self._write_u8(_TSL2591_REGISTER_ENABLE, _TSL2591_ENABLE_POWEROFF)
    @property
    def gain(self):
        &quot;&quot;&quot;Get and set the gain of the sensor.  Can be a value of:
        - ``GAIN_LOW`` (1x)
        - ``GAIN_MED`` (25x)
        - ``GAIN_HIGH`` (428x)
        - ``GAIN_MAX`` (9876x)
        &quot;&quot;&quot;
        control = self._read_u8(_TSL2591_REGISTER_CONTROL)
        return control &amp; 0b00110000
    @gain.setter
    def gain(self, val):
        assert val in (GAIN_LOW, GAIN_MED, GAIN_HIGH, GAIN_MAX)
        # Set appropriate gain value.
        control &amp;= 0b11001111
        control |= val
        self._write_u8(_TSL2591_REGISTER_CONTROL, control)
        # Keep track of gain for future lux calculations.
        self._gain = val
    @property
    def integration_time(self):
        &quot;&quot;&quot;Get and set the integration time of the sensor.  Can be a value of:
        - ``INTEGRATIONTIME_100MS`` (100 millis)
        - ``INTEGRATIONTIME_200MS`` (200 millis)
        - ``INTEGRATIONTIME_300MS`` (300 millis)
        - ``INTEGRATIONTIME_400MS`` (400 millis)
        - ``INTEGRATIONTIME_500MS`` (500 millis)
        - ``INTEGRATIONTIME_600MS`` (600 millis)
        &quot;&quot;&quot;
        return control &amp; 0b00000111
    @integration_time.setter
    def integration_time(self, val):
        assert 0 &lt;= val &lt;= 5
        # Set control bits appropriately.
        control &amp;= 0b11111000
        control |= val
        # Keep track of integration time for future reading delay times.
        self._integration_time = val
    @property
    def raw_luminosity(self):
        &quot;&quot;&quot;Read the raw luminosity from the sensor (both IR + visible and IR
        only channels) and return a 2-tuple of those values.  The first value
        is IR + visible luminosity (channel 0) and the second is the IR only
        (channel 1).  Both values are 16-bit unsigned numbers (0-65535).
        &quot;&quot;&quot;
        # Read both the luminosity channels.
        channel_0 = self._read_u16LE(_TSL2591_REGISTER_CHAN0_LOW)
        channel_1 = self._read_u16LE(_TSL2591_REGISTER_CHAN1_LOW)
        return (channel_0, channel_1)
    @property
    def full_spectrum(self):
        &quot;&quot;&quot;Read the full spectrum (IR + visible) light and return its value
        as a 32-bit unsigned number.
        &quot;&quot;&quot;
        channel_0, channel_1 = self.raw_luminosity
        return (channel_1 &lt;&lt; 16) | channel_0
    @property
    def infrared(self):
        &quot;&quot;&quot;Read the infrared light and return its value as a 16-bit unsigned number.
        &quot;&quot;&quot;
        _, channel_1 = self.raw_luminosity
        return channel_1
    @property
    def visible(self):
        &quot;&quot;&quot;Read the visible light and return its value as a 32-bit unsigned number.
        &quot;&quot;&quot;
        full = (channel_1 &lt;&lt; 16) | channel_0
        return full - channel_1
    @property
    def lux(self):
        &quot;&quot;&quot;Read the sensor and calculate a lux value from both its infrared
        and visible light channels.
        &quot;&quot;&quot;
        # Compute the atime in milliseconds
        atime = 100.0 * self._integration_time + 100.0
        # Set the maximum sensor counts based on the integration time (atime) setting
        if self._integration_time == INTEGRATIONTIME_100MS:
            max_counts = _TSL2591_MAX_COUNT_100MS
        # Handle overflow.
        if channel_0 &gt;= max_counts or channel_1 &gt;= max_counts:
            raise RuntimeError('Overflow reading light channels!')
        # Calculate lux using same equation as Arduino library:
        #  https://github.com/adafruit/Adafruit_TSL2591_Library/blob/master/Adafruit_TSL2591.cpp
        again = 1.0
        if self._gain == GAIN_MED:
            again = 25.0
        elif self._gain == GAIN_HIGH:
            again = 428.0
        elif self._gain == GAIN_MAX:
            again = 9876.0
        cpl = (atime * again) / _TSL2591_LUX_DF
        lux1 = (channel_0 - (_TSL2591_LUX_COEFB * channel_1)) / cpl
        lux2 = ((_TSL2591_LUX_COEFC * channel_0) - (_TSL2591_LUX_COEFD * channel_1)) / cpl
        return max(lux1, lux2)
</code></pre>
<p dir="auto"><a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a>:</p>
<pre><code># Simple demo of the TSL2591 sensor.  Will print the detected light value
# every second.
from machine import I2C, Pin #added for tsl2591  sensor
#import board
#import busio
import tsl2591
#i2c = I2C(0, pins=(&quot;P9&quot;,&quot;P10&quot;))
# Initialize the I2C bus.
i2c = I2C(0,pins=(&quot;P9&quot;,&quot;P10&quot;))#board.SCL, board.SDA)
i2c.init(I2C.MASTER, baudrate=9600)
# Initialize the sensor.
sensor = tsl2591.TSL2591(i2c)
# You can optionally change the gain and integration time:
#sensor.gain = adafruit_tsl2591.GAIN_LOW (1x gain)
#sensor.gain = adafruit_tsl2591.GAIN_MED (25x gain, the default)
#sensor.gain = adafruit_tsl2591.GAIN_HIGH (428x gain)
#sensor.gain = adafruit_tsl2591.GAIN_MAX (9876x gain)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_100MS (100ms, default)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_200MS (200ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_300MS (300ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_400MS (400ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_500MS (500ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_600MS (600ms)
# Read the total lux, IR, and visible light levels and print it every second.
    # Read and calculate the light level in lux.
    lux = sensor.lux
    print('Total light: {0}lux'.format(lux))
    # You can also read the raw infrared and visible light levels.
    # These are unsigned, the higher the number the more light of that type.
    # There are no units like lux.
    # Infrared levels range from 0-65535 (16-bit)
    infrared = sensor.infrared
    print('Infrared light: {0}'.format(infrared))
    # Visible-only levels range from 0-2147483647 (32-bit)
    visible = sensor.visible
    print('Visible light: {0}'.format(visible))
    # Full spectrum (visible + IR) also range from 0-2147483647 (32-bit)
    full_spectrum = sensor.full_spectrum
    print('Full spectrum (IR + visible) light: {0}'.format(full_spectrum))
    time.sleep(1.0)
</code></pre>
]]></description><link>https://forum.pycom.io/topic/4325/porting-adafruit-tsl2591-micropython-to-pycom-library</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 00:27:58 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4325.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Feb 2019 00:25:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Porting adafruit TSL2591 micropython to Pycom library on Sun, 03 Feb 2019 00:25:56 GMT]]></title><description><![CDATA[<p dir="auto">I'm trying to port this code in from Adafruit and not seeing what it's doing to trip up..  I've succeeded in getting several other libraries working, but it seems that each one is written completely differently, so it's not been as simple as tweak a few lines.  :(</p>
</code></pre>
# THE SOFTWARE.
&quot;&quot;&quot;
`adafruit_tsl2591`
**Hardware:**
&quot;&quot;&quot;
class TSL2591:
    &quot;&quot;&quot;
        self._gain = 0
        self.enable()
        # address.
    def enable(self):
    def disable(self):
    @property
    def gain(self):
        - ``GAIN_LOW`` (1x)
        &quot;&quot;&quot;
    @gain.setter
        control |= val
        self._gain = val
    @property
        &quot;&quot;&quot;
        control |= val
    @property
        &quot;&quot;&quot;
    @property
        &quot;&quot;&quot;
    @property
    def infrared(self):
        &quot;&quot;&quot;
        return channel_1
    @property
    def visible(self):
        &quot;&quot;&quot;
    @property
    def lux(self):
        &quot;&quot;&quot;
        # Handle overflow.
        again = 1.0
            again = 25.0
            again = 428.0
            again = 9876.0
</code></pre>
# every second.
#import board
#import busio
import tsl2591
    lux = sensor.lux
    time.sleep(1.0)
</code></pre>
]]></description><link>https://forum.pycom.io/post/25501</link><guid isPermaLink="true">https://forum.pycom.io/post/25501</guid><dc:creator><![CDATA[dnear1]]></dc:creator><pubDate>Sun, 03 Feb 2019 00:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to Porting adafruit TSL2591 micropython to Pycom library on Sun, 03 Feb 2019 07:35:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3737">@dnear1</a> The I2C classes of Circuitpython and Pycom's Micropython are different. While Circuitpython stores the address in a i2c object, it has to be provided separately for Pycom's dialect.<br />
So what should be changed:<br />
a) in <strong>init</strong>, change:</p>
<pre><code>        #self._device = i2c_device.I2CDevice(i2c, address)
</code></pre>
<p dir="auto">into</p>
<pre><code>        self._i2c_address = address
</code></pre>
<p dir="auto">b) in read_u8 change:</p>
<pre><code>        self._BUFFER[0] = (_TSL2591_COMMAND_BIT | address) &amp; 0xFF
</code></pre>
<pre><code>        self.i2c.readfrom_mem_into(self._i2c_address,
                                   (_TSL2591_COMMAND_BIT | address) &amp; 0xFF,
                                   self._BUFFER)
</code></pre>
<p dir="auto">c) do the same in _read_u16LE()<br />
d) in _write_u8(),  change</p>
</code></pre>
<pre><code>        self.i2c.writeto_mem(self._i2c_address,
                             val &amp; 0xFF)
</code></pre>
<p dir="auto">There is more to change. Especially the line int <strong>init</strong>() which creates the i2c object should be in the calling code. Actuall it is already in your <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a>, so change:<br />
so</p>
<pre><code>        self.i2c=I2C(pins=(&quot;P9&quot;,&quot;P10&quot;))
</code></pre>
<pre><code>        self.i2c = i2c
</code></pre>
]]></description><link>https://forum.pycom.io/post/25503</link><guid isPermaLink="true">https://forum.pycom.io/post/25503</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Sun, 03 Feb 2019 07:35:47 GMT</pubDate></item><item><title><![CDATA[Reply to Porting adafruit TSL2591 micropython to Pycom library on Sun, 03 Feb 2019 21:38:00 GMT]]></title><description><![CDATA[<p dir="auto">I made those changes and worked thru a few more issues.<br />
I get output the first time thru then it breaks.  Still working through that but here's what I've got so far<br />
Serial output:</p>
<pre><code>[41, 64]
[41, 64]
[41, 64]
[41, 64]
[41, 64]
Total light: 55.55328lux
[41, 64]
[41, 64]
Infrared light: 141
[41, 64]
[41, 64]
Visible light: 9241007
[41, 64]
[41, 64]
Full spectrum (IR + visible) light: 9241149
[41, 64]
[41, 64]
Total light: 0.0lux
[41, 64]
[41, 64]
Infrared light: 0
[41, 64]
[41, 64]
Visible light: 0
[41, 64]
[41, 64]
Full spectrum (IR + visible) light: 0
</code></pre>
<p dir="auto">the zero outputs repeat the rest of the tries.<br />
<a href="http://tsl2591.py" target="_blank" rel="noopener noreferrer nofollow">tsl2591.py</a>:</p>
# THE SOFTWARE.
&quot;&quot;&quot;
`adafruit_tsl2591`
**Hardware:**
&quot;&quot;&quot;
class TSL2591:
    &quot;&quot;&quot;
        self._gain = 0
        self.i2c=i2c#I2C(pins=(&quot;P9&quot;,&quot;P10&quot;))
        self._i2c_address=address
        self.enable()
        #self._BUFFER[0] = (_TSL2591_COMMAND_BIT | address) &amp; 0xFF
        # self.i2c.writeto(self._BUFFER, end=1, stop=False)
        #self.i2c.writeto(_TSL2591_ADDR,self._BUFFER)
        #self.i2c.readinto(self._BUFFER, end=1)
        print(self.i2c.scan())
        self.i2c.readfrom_mem_into(self._i2c_address,(_TSL2591_COMMAND_BIT|address) &amp; 0xFF,self._BUFFER)
        # address.
        #self.i2c.write(self._BUFFER, end=1, stop=False)
        #self.i2c.readinto(self._BUFFER, end=2)
        #self._BUFFER[1] = val &amp; 0xFF
        #self.i2c.write(self._BUFFER, end=2)
        self.i2c.writeto_mem(self._i2c_address,(_TSL2591_COMMAND_BIT | address) &amp; 0xFF,val &amp; 0xFF)
    def enable(self):
    def disable(self):
    @property
    def gain(self):
        - ``GAIN_LOW`` (1x)
        &quot;&quot;&quot;
    @gain.setter
        control |= val
        self._gain = val
    @property
        &quot;&quot;&quot;
        control |= val
    @property
        &quot;&quot;&quot;
    @property
        &quot;&quot;&quot;
    @property
    def infrared(self):
        &quot;&quot;&quot;
        return channel_1
    @property
    def visible(self):
        &quot;&quot;&quot;
    @property
    def lux(self):
        &quot;&quot;&quot;
        # Handle overflow.
        again = 1.0
            again = 25.0
            again = 428.0
            again = 9876.0
</code></pre>
# every second.
#import board
#import busio
import tsl2591
#i2c=i2c
    lux = sensor.lux
    time.sleep(1.0)
</code></pre>
]]></description><link>https://forum.pycom.io/post/25520</link><guid isPermaLink="true">https://forum.pycom.io/post/25520</guid><dc:creator><![CDATA[dnear1]]></dc:creator><pubDate>Sun, 03 Feb 2019 21:38:00 GMT</pubDate></item></channel></rss>
