<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Connection issue to WiPy 3.0r]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I was uploading many files to WiPy board using PySense board (more than 1000 files). During uploading, it suddenly prompted me the upload fails. Then, the COM3 connection was not responding.</p>
<p dir="auto">Then, I reset the board and after that I am not able to connect to the board using COM3 and also Wi-Fi. When I try to connect using Atom it just prompts the below message and nothing happens:</p>
<p dir="auto"><em>Autoconnect: Found a PyCom board on USB<br />
Autoconnect: Connecting on COM3...</em></p>
<p dir="auto">I also tried to use PuTTY to connect to COM3 and the new terminal pops up, but it is not responding.</p>
<p dir="auto">How can I access to the board and delete all files or rest factory the board?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.pycom.io/topic/4383/connection-issue-to-wipy-3-0r</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 07:52:50 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4383.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Feb 2019 01:15:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Connection issue to WiPy 3.0r on Fri, 15 Feb 2019 08:03:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/momentaj" aria-label="Profile: momentaj">@<bdi>momentaj</bdi></a> When using the pycom uploader 1.15.2, you have tghe option to erase the device on uploading a new firmware image.</p>
]]></description><link>https://forum.pycom.io/post/25931</link><guid isPermaLink="true">https://forum.pycom.io/post/25931</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 15 Feb 2019 08:03:40 GMT</pubDate></item><item><title><![CDATA[Reply to Connection issue to WiPy 3.0r on Thu, 14 Feb 2019 23:13:29 GMT]]></title><description><![CDATA[<p dir="auto">I tried to do that but it there is no change. Here are the steps which I did:<br />
1- Connecting P12 to the 3.3v pin.<br />
2- Attaching USB cable to the PySense board while the pins are connected.<br />
3- Holding the pins connected for more than 3 seconds.</p>
<p dir="auto">Atom shows this message and I am not able to type in it:</p>
<pre><code>Autoconnect: Found a PyCom board on USB
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:QIO, clock div:1
load:0x3fff0008,len:4
load:0x3fff000c,len:148
load:0x40078000,len:11876
ho 0 tail 12 room 4
load:0x40080000,len:268
entry 0x40080034
Autoconnect: Previous board is not available anymore
</code></pre>
<p dir="auto">Then, I disconnected the USB and connect it again and it prompts:</p>
</code></pre>
<p dir="auto">Am I doing something wrong?</p>
<p dir="auto">Note: as it is shown in the pin layout <a href="https://docs.pycom.io/.gitbook/assets/wipy3-pinout.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>, I tried connecting <strong><strong>3rd and 8th top-right pins</strong></strong>.</p>
]]></description><link>https://forum.pycom.io/post/25920</link><guid isPermaLink="true">https://forum.pycom.io/post/25920</guid><dc:creator><![CDATA[momentaj]]></dc:creator><pubDate>Thu, 14 Feb 2019 23:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to Connection issue to WiPy 3.0r on Thu, 14 Feb 2019 23:09:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/momentaj" aria-label="Profile: momentaj">@<bdi>momentaj</bdi></a> said in <a href="/post/25918">Connection issue to WiPy 3.0r</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul-thornton" aria-label="Profile: paul-thornton">@<bdi>paul-thornton</bdi></a> I have many libraries to use and all of the are Python files.</p>
</blockquote>
<p dir="auto">Sounds much too huge for an esp32. I guess that you have to use every trick to run your stuff.</p>
<ul>
<li>
<p dir="auto">Switch off compression for USB transfer.</p>
</li>
<li>
<p dir="auto">figured out unused files and don't copy them</p>
</li>
<li>
<p dir="auto">precompile the libs and make the important ones frozen</p>
</li>
<li>
<p dir="auto">use this string something feature, so you strings will be located in flash and used by reference</p>
</li>
<li>
<p dir="auto">if they are too large for the internal flash, place some on an SD card</p>
</li>
<li>
<p dir="auto">merge some files, so you don't waste that many blocks.</p>
</li>
<li>
<p dir="auto">shorten all names (class, methods, properties and variables)</p>
</li>
<li>
<p dir="auto">think small and redesign (do you really need all this stuff in this detail)</p>
</li>
<li>
<p dir="auto">think big     and redesing (add a unix machine with a few GByte as a coproc)</p>
</li>
</ul>
]]></description><link>https://forum.pycom.io/post/25919</link><guid isPermaLink="true">https://forum.pycom.io/post/25919</guid><dc:creator><![CDATA[crumble]]></dc:creator><pubDate>Thu, 14 Feb 2019 23:09:13 GMT</pubDate></item><item><title><![CDATA[Reply to Connection issue to WiPy 3.0r on Thu, 14 Feb 2019 19:04:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul-thornton" aria-label="Profile: paul-thornton">@<bdi>paul-thornton</bdi></a> I have many libraries to use and all of the are Python files.</p>
]]></description><link>https://forum.pycom.io/post/25918</link><guid isPermaLink="true">https://forum.pycom.io/post/25918</guid><dc:creator><![CDATA[momentaj]]></dc:creator><pubDate>Thu, 14 Feb 2019 19:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to Connection issue to WiPy 3.0r on Thu, 14 Feb 2019 10:31:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">You can put the board into a "Safe Boot" mode by connection P12 to  the 3.3v pin and  reset the board. It will stop any code in <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> or <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a> from executing.</p>
<p dir="auto">Afterwhich you should be able to connect to the board and run</p>
<pre><code>import uos
uos.mkfs("/flash")
</code></pre>
<p dir="auto">To clear the flash filesystem back to empty.<br />
That said. 1k files sounds excessive. Are they all code?</p>
]]></description><link>https://forum.pycom.io/post/25906</link><guid isPermaLink="true">https://forum.pycom.io/post/25906</guid><dc:creator><![CDATA[Paul Thornton]]></dc:creator><pubDate>Thu, 14 Feb 2019 10:31:59 GMT</pubDate></item></channel></rss>
