<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can the fipy handle transient spikes of -0.5V on the analog pins?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Can the fipy handle transient spikes of -0.5V on the analog pins?</p>
<p dir="auto">I am using a voltage divider and a diode for protection but occasionally it goes to negative half a volt and I couldn't see in the documentation whether it could handle that?</p>
]]></description><link>https://forum.pycom.io/topic/4390/can-the-fipy-handle-transient-spikes-of-0-5v-on-the-analog-pins</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:11:50 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4390.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Feb 2019 05:05:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can the fipy handle transient spikes of -0.5V on the analog pins? on Fri, 15 Feb 2019 05:05:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
]]></description><link>https://forum.pycom.io/post/25926</link><guid isPermaLink="true">https://forum.pycom.io/post/25926</guid><dc:creator><![CDATA[Edward Dimmack]]></dc:creator><pubDate>Fri, 15 Feb 2019 05:05:34 GMT</pubDate></item><item><title><![CDATA[Reply to Can the fipy handle transient spikes of -0.5V on the analog pins? on Fri, 15 Feb 2019 08:01:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3914">@edward-dimmack</a> The data sheet tells: -0.3 - 3.6V as maximum ratings. If teh source impedance is high, it should withstand a little bit more than that. Us a shottky diode (e.g. 1N5711, BAT48) for input protection, which has a lower forward voltage.</p>
]]></description><link>https://forum.pycom.io/post/25930</link><guid isPermaLink="true">https://forum.pycom.io/post/25930</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 15 Feb 2019 08:01:38 GMT</pubDate></item></channel></rss>
