<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pysense new + Mac os x 10.14.3 ?]]></title><description><![CDATA[<p dir="auto">Pysense connected with USB-cable, device doesn’t show up.<br />
Tried installing FTDI-drivers, no result.<br />
Tried the D2XX-stuff, no result.<br />
Is there somebody who has this board working with this version OSX ?<br />
I never worked with pic-family.<br />
I have a pysense v1.0 + FiPy and wanted to do the firmware upgrade (pysense) first.<br />
Also looked at the video’s on Core Electronics.<br />
I measure no voltage on pin 5v ( connector to insert other board on top ) and 300mV on the 3.3V pin.<br />
On the external IO header i measure 3.3V on pin4 (3V3_sensors) but not on pin 3 (3V3_Pymodule).<br />
Do I forgot something ? Or is there something wrong with my board.<br />
My board has not the same component layout as the one shown on the webpage,<br />
some extra components near the USB-connector.(other version?)<br />
Now ordered an expansion board ( amazon prime ) to test my FiPy, but it is somewhere lost in space ?</p>
]]></description><link>https://forum.pycom.io/topic/4430/pysense-new-mac-os-x-10-14-3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 09:41:24 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4430.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Feb 2019 08:23:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Fri, 22 Feb 2019 08:23:07 GMT]]></title><description><![CDATA[<p dir="auto">Pysense connected with USB-cable, device doesn’t show up.<br />
]]></description><link>https://forum.pycom.io/post/26126</link><guid isPermaLink="true">https://forum.pycom.io/post/26126</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Fri, 22 Feb 2019 08:23:07 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Fri, 22 Feb 2019 14:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/4056">@technoman</a> The Pysense does <strong>not</strong> use an FTDI chip. It uses the CDC (ACM): Communication Device Class (Abstract Control Model) protocol which is natively supported by MacOS.</p>
<p dir="auto">We use MacOS internally at Pycom and I have the same version 10.14.3 on my MacBook Pro and the Pysense / Pytrack / Pyscan and Expansion Board 3+ all work without problems.</p>
<p dir="auto">On the external header pin 3 (3V3_Pymodule) is the 3V3 that comes from the voltage regulator on the FiPy. Are you still measuring 0V when a module is inserted properly.</p>
<blockquote>
<p dir="auto">I measure no voltage on pin 5v ( connector to insert other board on top ) and 300mV on the 3.3V pin.</p>
</blockquote>
<p dir="auto">Can you please clarify where exactly you are taking these measurements?</p>
]]></description><link>https://forum.pycom.io/post/26138</link><guid isPermaLink="true">https://forum.pycom.io/post/26138</guid><dc:creator><![CDATA[Xykon]]></dc:creator><pubDate>Fri, 22 Feb 2019 14:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Sat, 23 Feb 2019 15:10:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/69">@xykon</a> That is exactly what I thought, it is not an FTDI chip.<br />
On the expansion board it's an FTDI-chip I believe.<br />
I must have followed a bad link somewhere, explaining the installation of those drivers.<br />
But my board is still not working.<br />
I measure no voltage between the pins where the FiPy gets is 5V ( see picture ), with or without FiPy mounted.<br />
I followed that pin somewhat and its coming from pin11(RC2) on the PIC16LF1459, where I also measure no voltage.<br />
So the mounted FiPy is not powered. Is power for the mounted board coming from the PIC16 ?<br />
Also tested my usb-cable.<br />
To me it seems like the PIC is not working, or there is no firmware in it ?</p>
<p dir="auto"><img src="/assets/uploads/files/1550934427821-img_2335-resized.jpg" alt="0_1550934419668_IMG_2335.jpg" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/26159</link><guid isPermaLink="true">https://forum.pycom.io/post/26159</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Sat, 23 Feb 2019 15:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Mon, 25 Feb 2019 08:01:29 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/4056">@technoman</a>, could you try just connecting Pysense alone (no Fipy) with macbook.<br />
Either use Cmd+Space: System Profiler, or <code>brew install lsusb</code> to use a nice lsusb linux equivalent. To see if a new USB is detected.<br />
Using <code>lsusb</code> you'll see something like either:</p>
<ul>
<li>normal PIC application mode (PID: 0xF012): <code>Bus 020 Device 008: ID 04d8:f012 Microchip Technology Inc. Pysense  Serial: Py06760a</code> or</li>
<li>PIC bootloader mode (PID 0xF011): <code>Bus 020 Device 004: ID 04d8:f011 Microchip Technology Inc. Application Specific Device</code></li>
</ul>
<p dir="auto">This would show if PIC firmware is ok, so to split the problem firmware or hardware.</p>
<p dir="auto">Fyi: The Expansion v2.x has FTDI, while v3.x has the PIC.</p>
]]></description><link>https://forum.pycom.io/post/26171</link><guid isPermaLink="true">https://forum.pycom.io/post/26171</guid><dc:creator><![CDATA[catalin]]></dc:creator><pubDate>Mon, 25 Feb 2019 08:01:29 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Tue, 26 Feb 2019 07:55:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1969">@catalin</a> and @...<br />
Thanx for the help.<br />
Installed lsusb, with or without pysense connected, no difference.</p>
<p dir="auto">The expansion board v3.0 has also a PIC ? Does it has to be updated ?<br />
Because I ordered expansion board also, normally tomorrow delivery.<br />
First expansion board was lost ( Amazon, but I got my money back ), I hope it is version 3.0, normally it should be, but you never know.<br />
So with the pysense the PIC is dead or there is no firmware in it ?</p>
<p dir="auto">My FiPy, I tested without expansion board and is working fine at first sight, was able to program it with Atom+plugin, but till now not with VSCode+plugin. With VSCode no connection, but I think telnet is not installed by default on OS X, perhaps that's the problem.</p>
<p dir="auto">Strange:<br />
Last week I tested a ESP32-WROVER board with a SIL2104 on it, didn't work and the chip really was getting hot. I installed CP210X usb to UART bridge VCP driver for MAC OS X and problem solved. For the wrover board I'm getting /dev/tty.SLAB_USBtoUART after installing the driver.</p>
<p dir="auto"><img src="/assets/uploads/files/1551167413864-img_2336-1.jpg" alt="0_1551167411095_IMG_2336-1.JPG" class="img-responsive img-markdown" /></p>
<p dir="auto">Always Thanx !</p>
]]></description><link>https://forum.pycom.io/post/26204</link><guid isPermaLink="true">https://forum.pycom.io/post/26204</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Tue, 26 Feb 2019 07:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Tue, 26 Feb 2019 20:59:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/4056">@technoman</a><br />
So Pysense seems dead, if nothing appears on lsusb; either power problems, or the PIC is not connected with USB (PCB issues). Though do you have other computer (maybe Linux or Windows) to try it? I understand drivers could be messed up.<br />
Pysense PIC firmware can't be deleted, at least bootloader is write-protected, and it has to show some USB port on any OS.<br />
How did you connected Fipy with laptop? Using breadboard and UART2USB (FTDI) external chip?<br />
Yes, Expansion v3.0 has PIC and it should work out-of-the-box.</p>
]]></description><link>https://forum.pycom.io/post/26226</link><guid isPermaLink="true">https://forum.pycom.io/post/26226</guid><dc:creator><![CDATA[catalin]]></dc:creator><pubDate>Tue, 26 Feb 2019 20:59:10 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Wed, 27 Feb 2019 09:37:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1969">@catalin</a><br />
Ok, thanx anyway.<br />
Try to send it back and get my money.<br />
When this doesn't work, do you think it is possible to use the sensors on the board.<br />
The FiPy I can program over the air and the pysense 3V3 is ok. Just giving the mounted board 5V like on a breadboard.<br />
And yes I already tried the pysense on a bare linux machine, no result.<br />
So the PIC's are being programmed before mounting them on the boards, or are they programmed on the board and write-protected after ?</p>
<p dir="auto">My expansion board also arrived today, seem to have no luck with Pycom, it's a v2.1A with a FTDI-chip.<br />
Trouble again ? ( deep-sleep mode, updating, drivers ). I see only one button on the board and I read something about issues with deep-sleep mode.<br />
Should I give it a try or send it back direct ?</p>
<p dir="auto"><img src="/assets/uploads/files/1551260009573-img_2341.jpg" alt="0_1551260007635_IMG_2341.JPG" class="img-responsive img-markdown" /></p>
<p dir="auto">Thanx a lot in advance.</p>
]]></description><link>https://forum.pycom.io/post/26237</link><guid isPermaLink="true">https://forum.pycom.io/post/26237</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Wed, 27 Feb 2019 09:37:58 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Wed, 27 Feb 2019 10:48:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/4056">@technoman</a><br />
The 3V3 it's output from Fipy, and it powers all Pysense sensors (also pull-up on I2C lines). So sensors should work.<br />
Does the Expansion v2.1 works with Fipy, can you connect to the REPL <code>&gt;&gt;&gt;</code> prompt?<br />
There's no issue with Expansion v2.1 and Fipy in deep-sleep. With Expansion v3.x you'll obtain a better power-consumption in deepsleep (~30uA). Only the RTS/CTS jumpers from Expansion v2.1 should be removed for Fipy.</p>
]]></description><link>https://forum.pycom.io/post/26241</link><guid isPermaLink="true">https://forum.pycom.io/post/26241</guid><dc:creator><![CDATA[catalin]]></dc:creator><pubDate>Wed, 27 Feb 2019 10:48:05 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Thu, 28 Feb 2019 10:22:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1969">@catalin</a><br />
Ok, thanx for your help and time.<br />
The FiPy is working fine. Didn't test all its capabilities but seems OK.<br />
Updated the firmware ( FiPy) and now it also works in Visual Code, mounted on the expansion board.<br />
( In Atom it already worked on a breadboard and not updated. )<br />
Programming it 'over the air' also worked.<br />
Seems that I had bad luck with the pysense at first, but I learned a lot.<br />
Now the real fun begins.</p>
<p dir="auto">Perhaps one last question, why are there only 3 mounting holes in the pysense ?</p>
<p dir="auto">Thanx again.</p>
<p dir="auto"><img src="/assets/uploads/files/1551349205922-img_2342.jpg" alt="0_1551349202924_IMG_2342.JPG" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/26270</link><guid isPermaLink="true">https://forum.pycom.io/post/26270</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Thu, 28 Feb 2019 10:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to Pysense new + Mac os x 10.14.3 ? on Thu, 28 Feb 2019 15:39:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1969">@catalin</a></p>
<p dir="auto">Is it possible the pins of the external io header on the pysense are reversed in the online datasheet ?<br />
Pins 3 and 4  are reversed ? or the names are confusing ?<br />
For sure:<br />
Pin 4(ext io header) is coming from the voltage regulator.(5pins - pin5) ----- is called 3V3_Pymodule online.<br />
Pin 3(ext io header) is coming from FiPy 3V3 output and goes to the sensors (power). ----- is called 3V3_Sensors online.</p>
<p dir="auto">What is the purpose of control pin 2 PWR_EN (ext io header) ? connected by two resistors to pin GPIO24 I believe.</p>
<p dir="auto">Found some topics in the forum, but no clear answer and/or I'm looking at the wrong topics/datasheet.<br />
( I always start with <a href="http://pycom.io" target="_blank" rel="noopener noreferrer nofollow">pycom.io</a> to search for information )<br />
I ask this questions because before buying other boards with that PIC chip, I want to understand the working and be sure not having the same problems again. I still can't imagine that all power (3V-5V) for the mounted module is coming from that PIC16lf1459 ( pin RC2 ).</p>
<p dir="auto">Thanx.</p>
]]></description><link>https://forum.pycom.io/post/26291</link><guid isPermaLink="true">https://forum.pycom.io/post/26291</guid><dc:creator><![CDATA[technoman]]></dc:creator><pubDate>Thu, 28 Feb 2019 15:39:28 GMT</pubDate></item></channel></rss>
