FiPy , connecting to Orange LTE-M (France) , any informations ? [Solved]
  • Hi all ,
    I just receive a SIM for Orange LTE-M network.
    Want to try it with a Fipy working on LoRa for the moment .
    The firmware is nearly up to date:
    (sysname='FiPy', nodename='FiPy', release='1.18.1.r10', version='v1.8.6-849-d53c7f3 on 2019-01-10', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='0.9.5')
    lte.imei() return is ok , but lte.iccid() return nothing , is there special information to get connected ?
    try a cap command and it returns:
    == CAPS config =============================
      .Lock UE on SRV band    : false
      .MFBI support           : true
      .TM8 TDD support        : false
    == CAPS ====================================
      . access stratum: R13
      . catM          : 1
      . nb-IoT        : 0
    -- EUTRA bands --
      . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
      . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
      . admin         :
      . pending admin :
    -- EUTRA carriers --
      . admin         :
      . pending admin :
    OK
    my showphy give that:
    DL SYNCHRO STATISTICS
        Synchro state                         : OFF
        PPU SIB1 ACQ watchdog                 : 0
        Frequency Hypothesis RF  (Hz)         : 0
        RSRP (dBm)                            : 0.00
        RSRQ  (dB)                            : 0.00
        Channel estimation state (Cell-spec.) : LOW CINR
        Channel estimation state (UE-spec.)   : LOW CINR
        Channel estimation state (MBSFN)      : LOW CINR
        Channel estimation CINR               : 0.00
        Channel length                        : SHORT
      AGC
        AGC RX gain (dB)                      : 0.00
        RX PSD BO (dBFs)                      : 0.00
        RX PSD (dBm)                          : 0.00
        Noise level RS (dBm)                  : 0.00
        Digital gain (dB)                     : 0.00
        CINR RS (dB)                          : 0.00
      NARROWBANDS
        Last DL NB                            : 0
        Last UL NB                            : 0
      AFC
        Frequency offset RF  (Hz)             : 0
        Frequency offset BB  (Hz)             : 0
      PBCH
        MIB received quantity                 : 0
        MIB timeout quantity                  : 0
    any suggestion ?
  • @stef said in FiPy , connecting to Orange LTE-M (France) , any informations ? [Solved]:
    lte.send_at_cmd('AT+COPS=?')
    Hello!
    I am using fipy to connect Orange LTE-M in France and after many attemp, I still do not have any results "lte.isattached()" allways false.
    Can anybody help me please.
  • @rskoniec said in FiPy , connecting to Orange LTE-M (France) , any informations ? [Solved]:
    husiast/hobbyst it's impossible
    Thanks for your help. I have also asked ThingsMobile. No agreement with Orange yet as far as LTE-M is concerned.
    Have a nice summer.
  • @Bruno Same here in Poland with Orange - just pilot projects and closed tests with LTE-M enabled on chosen BTS stations. :/ For now - if you're regular enthusiast/hobbyst it's impossible to try it out.
  • @stef Good evening Stef, i guess you've already got an answer. By the way, a simple question : how did you manage to get your Orange SimCard ? I'm quite enthusiastic to test LTE-M but can't find a way to in France.
    Have a pleasant evening.
  • Progressing .....
    for those who need the informations:
    orange LTE-M is b20 (800Mhz) with apn=orange.ltem.spec
    got this on cops:
    >>> print(lte.send_at_cmd('AT+COPS=?'))
    +COPS: (2,"Orange F","Orange F","20801",7),,(0,1,2,3,4),(0,1,2)
    edit:
    working fine with lte.attach(band=20,apn="orange.ltem.spec")
    the very first connexion was verrrryyyyyy long .... after that all is ok , even when Fipy is powered/unpowered.
