VS&Pymakr, json file not opening
  • Hi,
    I’m a begginer with Pymakr with VS.
    I was doing some experiments with Fire Dev Kit when I’ve an issues. After a blue screen, i coud not connect anymore the card to Pymakr.
    I tried to go in global setting to put the good port to connect from VS to the card but when the json file should open after clicking on global settings, nothing is opening.
    I tried to reinstall node js and also VS and the Pymakr extension but it does not fix my problem.
    I also tried to change the project settings, I changed it but it stills not connecting to the board. As anoyone ever had the issue that clicking on global setting is not opening the json file ?
    Thanks !
  • Maybe there is an issue with your board that's why some error messaging are displaying or there could be a hardware failure,get it checked from some expert technician.
