KeyboardInterrupt after wake by timer or accel interrupt
  • Gpy on Pytrack and acceleromter_wake example.
    KeyboardInterrupt after wake by timer or accel interrupt.
    rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8028,len:8
    load:0x3fff8030,len:1728
    load:0x4009fa00,len:0
    load:0x4009fa00,len:14584
    entry 0x400a059c
    Previous board is not available anymore
    > Failed to connect (Error: Port is not open). Click here to try again.
    Connecting to /dev/tty.usbmodemPy9254bb1...
      File "main.py", line 9, in <module>
      File "pytrack.py", line 8, in __init__
      File "pycoproc.py", line 75, in __init__
    KeyboardInterrupt:
    Pycom MicroPython 1.18.1.r1 [cf6ef4f-dirty] on 2019-01-04; GPy with ESP32
  • @shaunix It still may be an interaction between the PC and its driver stack and the xxPy device. Can you try to catch the KeyboardException in a try/except clause, signal the fact by the LED and then run the device with a pure simple power supply, like a smart phone charger?
  • I guess I should make it clear that the keyboardinterrupt is not intentional. No keys were pressed. This happens automatically every time it wakes.
  • main.py
    from pytrack import Pytrack
    #from pysense import Pysense
    from LIS2HH12 import LIS2HH12
    py = Pytrack()
    # py = Pysense()
    # display the reset reason code and the sleep remaining in seconds
    # possible values of wakeup reason are:
    # WAKE_REASON_ACCELEROMETER = 1
    # WAKE_REASON_PUSH_BUTTON = 2
    # WAKE_REASON_TIMER = 4
    # WAKE_REASON_INT_PIN = 8
    print("Wakeup reason: " + str(py.get_wake_reason()) + "; Aproximate sleep remaining: " + str(py.get_sleep_remaining()) + " sec")
    time.sleep(0.5)
    # enable wakeup source from INT pin
    py.setup_int_pin_wake_up(False)
    # enable activity and also inactivity interrupts, using the default callback handler
    py.setup_int_wake_up(True, True)
    acc = LIS2HH12()
    # enable the activity/inactivity interrupts
    # set the accelereation threshold to 2000mG (2G) and the min duration to 200ms
    acc.enable_activity_interrupt(750, 200)
    # check if we were awaken due to activity
    if acc.activity():
        pycom.rgbled(0xFF0000)
        pycom.rgbled(0x00FF00)  # timer wake-up
    time.sleep(0.1)
    # go to sleep for 1 minute maximum if no accelerometer interrupt happens
    py.setup_sleep(60)
    py.go_to_sleep()
