<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoPy4 - Narrow bandwidth modes (7.8&#x2F;10.4&#x2F;62.5 kHz)]]></title><description><![CDATA[<p dir="auto">I have a couple of LoPy4's and am interesting in experimenting with the narrower bandwidth modes. The micropython API for LoRa allows me to set the 500/250/125 kHz modes as per the examples on the Pycom web site and elsewhere but I cannot see how to set the bandwidth to the narrow bandwidths e.g. 7.8/10.7/62.5  kHz.</p>
<p dir="auto">Is it possible with the currrent LoPy4 firmware to set these modes and if so what is the API call? If not, is there a possibility of having these modes added to the next firmware release?</p>
<p dir="auto">Failing the above, is it possible to programe these narrow bandwidth modes by bit/bang the SX1276 LoRa chip directly from micropython API calls?</p>
]]></description><link>https://forum.pycom.io/topic/4784/lopy4-narrow-bandwidth-modes-7-8-10-4-62-5-khz</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 04:34:12 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4784.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 May 2019 08:33:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoPy4 - Narrow bandwidth modes (7.8&#x2F;10.4&#x2F;62.5 kHz) on Fri, 03 May 2019 08:33:02 GMT]]></title><description><![CDATA[<p dir="auto">I have a couple of LoPy4's and am interesting in experimenting with the narrower bandwidth modes. The micropython API for LoRa allows me to set the 500/250/125 kHz modes as per the examples on the Pycom web site and elsewhere but I cannot see how to set the bandwidth to the narrow bandwidths e.g. 7.8/10.7/62.5  kHz.</p>
]]></description><link>https://forum.pycom.io/post/27671</link><guid isPermaLink="true">https://forum.pycom.io/post/27671</guid><dc:creator><![CDATA[AlbertMcG]]></dc:creator><pubDate>Fri, 03 May 2019 08:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy4 - Narrow bandwidth modes (7.8&#x2F;10.4&#x2F;62.5 kHz) on Fri, 03 May 2019 08:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/4468">@AlbertMcG</a> It is not only firmware but hardware. For narrow bandwidth (less then 125kHz) you need a higher stability oscillator, I mean a TXCO. I do not know circuit diagram of LoPy4, check the XTAL oscillator part.</p>
]]></description><link>https://forum.pycom.io/post/27672</link><guid isPermaLink="true">https://forum.pycom.io/post/27672</guid><dc:creator><![CDATA[bmarkus]]></dc:creator><pubDate>Fri, 03 May 2019 08:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy4 - Narrow bandwidth modes (7.8&#x2F;10.4&#x2F;62.5 kHz) on Fri, 03 May 2019 08:43:44 GMT]]></title><description><![CDATA[<p dir="auto">Yes. I saw that I would need a  more stable oscillator somewhere else on the web. I have no problem sorting that out but it still leaves me needing the API calls.</p>
]]></description><link>https://forum.pycom.io/post/27674</link><guid isPermaLink="true">https://forum.pycom.io/post/27674</guid><dc:creator><![CDATA[AlbertMcG]]></dc:creator><pubDate>Fri, 03 May 2019 08:43:44 GMT</pubDate></item></channel></rss>
