SD problems in Read/ f.truncate()
  • Hey guys!
    I'm working on a lopy4 + pysense i have a 8 Gb class 10 micro SD and i'm overall functionality that I want is:
    When LoRa_Tx available transmit -> when not, save to SD -> when LoRa_Tx available again, read from SD, transmit information and delete line from log file.
    I'm having problems with deleting the line from the log file, and the code that i have is the following
    def delete_first_lines_from_file(filename, nr_lines):
        with open('/sd/' + LOG_FILENAME, 'r+') as f:
            # skip X lines
            for _ in range(nr_lines):
                if f.readline() == "": # reached End Of File before reading all lines
                    print("#reached End Of File before reading all lines, truncating")
                    f.seek(0)
                    f.truncate()
                    return
            eof = False
            #start saving to buffer and then write
            last_pos_read  = f.tell()
            last_pos_write = 0
            while eof is False:
                line_list = []
                f.seek(last_pos_read) # be ready for the next iteration and read the rest of the file
                    line = f.readline()
                    if line == "":
                        eof = True
                        break
                    elif line == '\n':
                        continue
                        line_list.append(line)
                # go to begining, and start writing
                f.seek(last_pos_write)
                for line in line_list:
                    f.write(line)
                last_pos_write = f.tell()
            f.truncate()
    What i get is this:
    File "main.py", line 311, in delete_first_lines_from_file
    AttributeError: 'TextIOWrapper' object has no attribute 'truncate'
    Does truncate exists in micropython? Is there any equivalent way of doing this?
    Thanks in advance!
  • @robert-hh do you see any solution to erase lines from the log file and keep them updated?
  • @morrison trunctate does not exists. But if you open an existing file in just "w" mode, it is trunctated to 0. So instead of calling the first trunctate(),
    • close the file
    • reopen it in "w" mode.
    • and optionally close it again (that is missing from your script)
    For the second trunctate, I see no good solution.
