LoPy - Pybytes - LoRA
  • After a bit of a gap, I am experimenting again with LoPy and LoRA. How to I get the LoPy to transmit data via LoRa to Pybytes? It's working fine via WiFi (I set the device up to use both WiFi (1) - LoRa using OTAA (2) ) but am just missing the setup for LoRa. Incidentally, if I just load up the Stable firmware and run the example LoRaWan script (and set up TTN properly) I can successfully get data from the device to TTN.
