Gpy + Pytrack - Modem won't attach after firmware upgrade
  • I successfully upgraded the Gpy firmware to the latest stable version 1.18.2.r7 using the Pycom Firmware Updater app for OS X.
    I then upgraded the modem firmware to CATM1-41065.
    I uploaded updater.elf to /flash
    On the Gpy I ran the following commands:
    >>> import sqnsupgrade
    >>> sqnsupgrade.uart(True,'/flash/updater.elf')
    <<< Welcome to the SQN3330 firmware updater [1.2.5] >>>
    >>> GPy with firmware version 1.18.2.r7
    Preparing modem for upgrade...
    FFH mode is not necessary... ignoring!
    Do not specify updater.elf when updating!
    Attempting AT wakeup...
    Going into MIRROR mode... please close this terminal to resume the upgrade via UART
    Closed Atom and ran the following commands from the terminal on my Mac:
    PBM:CATM1-41065 prs$ python3
    Python 3.7.3 (default, May  7 2019, 21:44:49)
    [Clang 10.0.1 (clang-1001.0.46.4)] on darwin
    Type "help", "copyright", "credits" or "license" for more information.
    >>> import sqnsupgrade
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy9254bb1', '/Users/prs/Desktop/CATM1-41065/CATM1-41065.dup', debug=True)
    <<< Welcome to the SQN3330 firmware updater [1.2.4] >>>
    File /Users/prs/Desktop/CATM1-41065/CATM1-41065.dup has size 6160982
    mirror? False  recover? False  resume? False  direct? False  atneg_only? False bootrom? False load_fff? True
    baudrate: 921600 target_baudrate: 921600
    Setting port /dev/tty.usbmodemPy9254bb1
    Setting baudrate to 921600
    Initial prepartion complete...
    Loading /Users/prs/Desktop/CATM1-41065/CATM1-41065.dup
    Firmware file is too big to load via FFF method. Using ON_THE_FLY
    Attempting AT wakeup...with baudrate 921600
    b''
    count=1
    b''
    count=2
    b''
    count=3
    b''
    count=4
    b''
    count=5
    b''
    count=6
    b''
    count=7
    b''
    count=8
    b''
    count=9
    b''
    count=10
    b''
    Nothing happened to I tried:
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy9254bb1', '/Users/prs/Desktop/CATM1-41065/CATM1-41065.dup', '/Users/prs/Desktop/CATM1-41065/updater.elf', debug=True)
    File /Users/prs/Desktop/CATM1-41065/updater.elf has size 430284
    mirror? False  recover? True  resume? True  direct? True  atneg_only? False bootrom? False load_fff? False
    Loading /Users/prs/Desktop/CATM1-41065/updater.elf
    Entering recovery mode
    AT+SMOD? returned
    Starting STP mode...
    Failed to start STP mode!
    So then I tried:
    >>> import sqnsupgrade
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy9254bb1', '/Users/prs/Desktop/CATM1-41065/upgdiff_39529-to-41065.dup')
    ^CTraceback (most recent call last):
      File "/Users/prs/Desktop/CATM1-41065/sqnsupgrade.py", line 1012, in run
        sqnup.upgrade_ext(port=port, ffile=ffile, mfile=mfile, resume=resume, debug=debug, pkgdebug=False, verbose=verbose, load_fff=load_fff)
      File "/Users/prs/Desktop/CATM1-41065/sqnsupgrade.py", line 889, in upgrade_ext
        if self.__run(file_path=ffile, resume=True if mfile is not None else resume, direct=False, port=port, debug=debug, pkgdebug=pkgdebug, verbose=verbose, load_fff=load_fff):
      File "/Users/prs/Desktop/CATM1-41065/sqnsupgrade.py", line 419, in __run
        if not self.wakeup_modem(baudrate, port, 10, 1, debug):
      File "/Users/prs/Desktop/CATM1-41065/sqnsupgrade.py", line 736, in wakeup_modem
        response = self.read_rsp(size=25)
      File "/Users/prs/Desktop/CATM1-41065/sqnsupgrade.py", line 81, in read_rsp
        time.sleep(0.001)
    KeyboardInterrupt
    Seemed frozen to I stopped it and tried:
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy9254bb1', '/Users/prs/Desktop/CATM1-41065/upgdiff_39529-to-41065.dup', '/Users/prs/Desktop/CATM1-41065/updater.elf', debug=True)
    File /Users/prs/Desktop/CATM1-41065/upgdiff_39529-to-41065.dup has size 455057
    AT+SMOD? returned
  • Does any of this information help?
    >>> print(lte.send_at_cmd("ATI"))
    PYCOM
    FiPy
    UE5.0.0.0d
    OK
    >>> print(lte.send_at_cmd('AT!="showphy"'))
    DL SYNCHRO STATISTICS
        Synchro state                         : OFF
        PPU SIB1 ACQ watchdog                 : 0
        Frequency Hypothesis RF  (Hz)         : 0
        RSRP (dBm)                            : 0.00
        RSRQ  (dB)                            : 0.00
        Channel estimation state (Cell-spec.) : LOW CINR
        Channel estimation state (UE-spec.)   : LOW CINR
        Channel estimation state (MBSFN)      : LOW CINR
        Channel estimation CINR               : 0.00
        Channel length                        : SHORT
      AGC
        AGC RX gain (dB)                      : 0.00
        RX PSD BO (dBFs)                      : 0.00
        RX PSD (dBm)                          : 0.00
        Noise level RS (dBm)                  : 0.00
        Digital gain (dB)                     : 0.00
        CINR RS (dB)                          : 0.00
      NARROWBANDS
        Last DL NB                            : 0
        Last UL NB                            : 0
      AFC
        Frequency offset RF  (Hz)             : 0
        Frequency offset BB  (Hz)             : 0
      PBCH
        MIB received quantity                 : 0
        MIB timeout quantity                  : 0
    OK
    >>> print(lte.send_at_cmd('AT!="fsm"'))
    SYSTEM FSM
        |            FSM           |        STATE       |
        | RRC TOP FSM              |STOPPED             |
        | RRC SEARCH FSM           |NULL                |
        | RRC ACTIVE FSM           |NULL                |
        | PMM PLMN FSM             |NULL                |
        | EMM MAIN FSM             |NULL                |
        | EMM AUTH FSM             |NULL                |
        | EMM CONN FSM             |NULL                |
        | EMM TAU FSM              |NULL                |
        | EMM TEST FSM             |NULL                |
        | ESM BEARER FSM           |BEARER_NULL         |
        | SMS MT FSM               |IDLE                |
        | SMS MO FSM               |IDLE                |
        | HP MAIN FSM              |NULL                |
        | HP USIM FSM              |NULL                |
        | HP SMS MO FSM            |IDLE                |
        | HP SMS MT FSM            |IDLE                |
        | HP CAT FSM               |NULL                |
    OK
    The one thing that I noticed was:
    PYCOM
    FiPy
    UE5.0.0.0d
    Does it think my Gpy is a FiPy? Could that be the problem?
    Other info to note: I'm using Bell Canada and it worked flawlessly before I upgraded the firmware. Tried this on 2 different Gpy's and both are experiencing this issue.
  • >>> from network import LTE
    >>> lte = LTE()
    >>> lte.attach()
    >>> lte.connect()
    OSError: modem not attached
    >>> lte.attach()
    >>> lte.connect()
    >>> lte.connect()
    >>> lte.connect()
    OSError: LTE modem version not read
    >>> lte.connect()
    >>> lte.attach()
    >>> lte.connect()
    >>> lte.connect()
  • I managed to successfully update the Gpy firmware to the latest stable version 1.18.2.r7
    I also managed to successfully update the modem firmware to version CATM1-41065
    >>> import sqnsupgrade
    AT+SMOD? returned 0
    Starting STP code upload
    running m.wipe
    running m.reset
    magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0xFEEC
    Correct SRSP signature: 0x74736166
    running m.open_session
    Session opened: version 1, max transfer 2048 bytes
    running push(m)
    Sending 430284 bytes: [########################################] 100%
    running dev.set_timeout(2)
    running m.reset(True)
    Waiting for updater to load... [921600]
    b'\r\nOK\r\n'
    Upgrader loaded successfully, modem is in update mode
    mirror? False  recover? False  resume? True  direct? False  atneg_only? False bootrom? False load_fff? True
    Attempting AT wakeup... [921600]
    b'\r\nOK\r\n'
    AT+SMOD? returned 4
    Starting STP ON_THE_FLY
    Sending AT+SMSTPU="ON_THE_FLY"
    running m.wipe
    running m.reset
    magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0x0
    Session opened: version 1, max transfer 8192 bytes
    running push(m)
    Sending 6160982 bytes: [########################################] 100%
    Code download done, returning to user mode
    Waiting for modem to finish the update...
    <<<=== DO NOT DISCONNECT POWER ===>>> [921600]
    b''
    count=1
    b'\r\nOK\r\n\r\nOK\r\n'
    AT+SMUPGRADE? returned b'+SMUPGRADE: success\r\n\r\nOK\r\n' [timeout: 0.4593789577484131]
    AT+SMSWBOOT? returned b'FFH\r\nOK\r\n'
    This is my result: success
    Resetting.AT+SMSWBOOT=1,1 returned b'+SMUPGRADE: success\r\n\r\nOK\r\n'
    Sending AT+SQNSUPGRADENTF="success"
    AT+SQNSUPGRADENTF="success" returned b'\r\nOK'
    Sending AT+FSRDFILE="/fs/crashdump"
    AT+FSRDFILE="/fs/crashdump" returned b'\r\nOK'
    Your modem has been successfully updated.
    Here is the current firmware version:
    mirror? False  recover? False  resume? True  direct? True  atneg_only? False bootrom? False load_fff? False
    SYSTEM VERSION
      FIRMWARE VERSION
        Bootloader0  : 5.1.1.0 [41065]
        Bootloader1* : 5.1.1.0 [41065]
        Bootloader2  : 5.1.1.0 [38638]
        NV Info      : 1.1,0,0
        Software     : 5.1.1.0 [41065] by robot-soft at 2018-12-17 13:03:40
        UE           : 5.0.0.0d
      COMPONENTS
        ZSP0         : 1.0.99-13616
        ZSP1         : 1.0.99-12376
    IMEI: 354347091745387
    >>> quit()
    But it still won't attach.
    lte = LTE()
    lte.attach()
    while not lte.isattached():
        time.sleep(0.25)
    Loops forever...
  • Did a hard reset and now back to square one
    >>> lte = LTE()
    >>> lte.attach()
    >>> lte.connect()
    >>> lte.attach()
    >>> lte.connect()
    So I tried to downgrade the modem again.
    >>> import sqnsupgrade
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy8ac71d1', '/Users/prs/Desktop/CATM1-39529/CATM1-39529.dup')
    Sending 6059510 bytes: [########################################] 100%
    Resetting.................
    UE5.0.0.0d
    LR5.1.1.0-39529
    IMEI:
    ERROR
    354347099436476
    But still...modem won't attach.
  • I decided to upgrade to the latest development release version 1.20.0.rc11
    After that I was able to update the modem firmware successfully:
    >>> import sqnsupgrade
    >>> sqnsupgrade.run('/dev/tty.usbmodemPy8ac71d1', '/Users/prs/Desktop/CATM1-41065/CATM1-41065.dup', debug=True)
    Setting port /dev/tty.usbmodemPy8ac71d1
    b'\r\nERROR\r\n'
    count=1
    b'\r\nOK\r\n'
    AT+BIND=AT returned b'\r\nOK\r\n'
    ATE0 returned b'\r\nOK\r\n'
    Entering upgrade mode...
    AT+SMOD? returned 2
    AT+SMSWBOOT=3,1 returned: b'\r\nOK\r\n'
    Response after reset: b'\x00'
    Sending AT+CFUN=4
    AT+CFUN=4 returned 2
    running m.wipe
    running m.reset
    running push(m)
    <<<=== DO NOT DISCONNECT POWER ===>>>with baudrate 921600
    b''
    count=1
    AT+SMUPGRADE? returned b'+SMUPGRADE: success\r\n\r\nOK\r\n' [timeout: 0.21889209747314453]
    AT+SMSWBOOT? returned b'RECOVERY\r\nOK\r\n'
    SYSTEM VERSION
      FIRMWARE VERSION
        Bootloader2  : 5.1.1.0 [41065]
        NV Info      : 1.1,0,0
        UE           : 5.0.0.0d
      COMPONENTS
        ZSP0         : 1.0.99-13616
        ZSP1         : 1.0.99-12376
    IMEI:
    ERROR
    354347099436476
    But now I get:
    >>> import sqnsupgrade
    >>> sqnsupgrade.info()
    >>> GPy with firmware version 1.20.0.rc11
    UE5.0.0.0d
    LR5.1.1.0-41065
    IMEI: 354347099436476
    >>> lte = LTE()
    >>> lte.attach()
    OSError: the requested operation failed
    >>> lte.attach()
    >>> lte.connect()
  • Pycom MicroPython 1.18.2.r7 [v1.8.6-849-df9f237] on 2019-05-14; GPy with ESP32
    >>> lte = LTE()
    >>> lte.attach()
    >>> lte.attach()
    >>> lte.connect()
    I tried downgrading back to CATM1-39529 but that didn't work.
