<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[using lib files]]></title><description><![CDATA[<p dir="auto">I'm trying to develop some code in Atom. I've just realised that when I run <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a> from Atom it's using library files stored in the lib folder in flash on the GPY rather than the library files in lib in Atom! Is there a way to force it to use the Atom lib files?</p>
]]></description><link>https://forum.pycom.io/topic/4934/using-lib-files</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 18:14:36 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4934.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Jun 2019 05:50:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to using lib files on Mon, 24 Jun 2019 05:50:15 GMT]]></title><description><![CDATA[<p dir="auto">I'm trying to develop some code in Atom. I've just realised that when I run <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a> from Atom it's using library files stored in the lib folder in flash on the GPY rather than the library files in lib in Atom! Is there a way to force it to use the Atom lib files?</p>
]]></description><link>https://forum.pycom.io/post/28329</link><guid isPermaLink="true">https://forum.pycom.io/post/28329</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Mon, 24 Jun 2019 05:50:15 GMT</pubDate></item><item><title><![CDATA[Reply to using lib files on Mon, 24 Jun 2019 06:49:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> Since <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a> is executed on the target, it is accessing the files on the target. The GPY has no acces to the PC file system. The only thing that you can get is synchronizing the lib files form you Atom/PC library to GPY. I do not work with the pymakr plug-ins,  so I cannot give you details, but there were threads of synchronizing a project directory with the target module.</p>
]]></description><link>https://forum.pycom.io/post/28332</link><guid isPermaLink="true">https://forum.pycom.io/post/28332</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Mon, 24 Jun 2019 06:49:08 GMT</pubDate></item></channel></rss>
