ssl wrapping of inherited socket crashes
  • I'm trying to ssl wrap a socket connection with a inherited socket so I can reroute write and read data to external uart based Ethernet module on LoPy. I've successfully been able to route mqtt client data to external Ethernet module. I now want to use ssl for the mqtt client. In sample code which just implements pass, non-ssl works fine using "Mysocket" but crashes with core dump when attempting to used wrapped socket
    from network import WLAN
    import usocket as _socket
    import ussl as ssl
    class MySocket(_socket.socket):
        pass
    def main(use_stream=False, use_ssl=False):
        wlan = WLAN(mode=WLAN.STA)
        wlan.connect(ssid='MYSSID', auth=(WLAN.WPA2, '12344321'))
        while not wlan.isconnected():
            print("Wifi .. Connecting")
        print ("Wifi Connected")
        s = MySocket()
        #s = _socket.socket()
        ai = _socket.getaddrinfo("google.com", 443) # 80
        print("Address infos:", ai)
        addr = ai[0][-1]
        print("Connect address:", addr)
        s.connect(addr)
        try:
            s = ssl.wrap_socket(s,server_hostname="google.com")
        except:
            print('ssl failed')
        print(s)
        time.sleep(5)
        print('start')
        if use_stream:
            # Both CPython and MicroPython SSLSocket objects support read() and
            # write() methods.
            s.write(b"GET / HTTP/1.0\r\n\r\n")
            print(s.read(4096))
            # MicroPython SSLSocket objects implement only stream interface, not
            # socket interface
            s.send(b"GET / HTTP/1.0\r\n\r\n")
            print(s.recv(4096))
        s.close()
    main(use_stream=True, use_ssl=True)
    LoPy4 Output:
    rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8028,len:8
    load:0x3fff8030,len:1688
    load:0x4009fa00,len:0
    load:0x4009fa00,len:14592
    entry 0x400a059c
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi .. Connecting
    Wifi Connected
    Address infos: [(2, 1, 0, '', ('172.217.10.14', 443))]
    Connect address: ('172.217.10.14', 443)
    <ussl>
    start
    Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
    . Exception was unhandled.
    Register dump:
    PC      : 0x400e32d1  PS      : 0x00060930  A0      : 0x801bc4a0  A1      : 0x3ffdad30
    A2      : 0xffffffff  A3      : 0x3f950590  A4      : 0x00000012  A5      : 0x3ffdad80
    A6      : 0x3ffc62dc  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x3ffdad10
    A10     : 0x3f9505e0  A11     : 0x3f950590  A12     : 0x00000012  A13     : 0x3ffdad80
    A14     : 0xffffff30  A15     : 0x3f950539  SAR     : 0x0000001e  EXCCAUSE: 0x0000001c
    EXCVADDR: 0x00000058  LBEG    : 0x4009b71d  LEND    : 0x4009b751  LCOUNT  : 0xffffffff
    Backtrace: 0x400e32d1:0x3ffdad30 0x401bc49d:0x3ffdad50 0x400fa464:0x3ffdad80 0x400fa4d1:0x3ffdadb0 0x400f53a2:0x3ffdade0 0x400f1d19:0x3ffdae10 0x400f1d81:0x3ffdae30 0x400fd1c9:0x3ffdae50 0x400f542c:0x3ffdaef0 0x400f1d19:0x3ffdaf30 0x400fd133:0x3ffdaf50 0x400f542c:0x3ffdaff0 0x400f1d19:0x3ffdb070 0x400f1d46:0x3ffdb090 0x400de29d:0x3ffdb0b0 0x400de578:0x3ffdb150 0x400dd1d1:0x3ffdb170
    9DYAABAAAABsAQAA
    LFX8P3Cs/T8ss/0/
    kK39P8Cy/T+tRwAAHFL8PxxS/D8sVfw/FFL8PxQAAAAAI/4/ACP+PyxV/D8AAAAA
    BQAAADCD/T9NaWNyb1B5AAAAAAAAAAAAAQAAACyz/T8AAAAAIAMGAAUAAAAAAAAA
    9Fr7PzRh/D9oOA1AAAAAAAAAAAB8a/0/5Gv9P0xs/T8AAAAAAAAAAAEAAAAAAAAA
    YmhAPwAAAABYvglAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
    BQAAANEyDkAwCQYAoMQbgDCt/T//////kAWVPxIAAACArf0/3GL8PwAAAAAAAAAA
    EK39P+AFlT+QBZU/EgAAAICt/T8w////OQWVPx4AAAAcAAAAWAAAAB23CUBRtwlA
    /////xIAAACArf0/WDQIQITY+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAALx9Qj8BAAAA2KQPQAUAAABnpA+AUK39P+AFlT+QBZU/
    AQAAAICt/T8AAAAAAAAAANSkD4CArf0/4AWVP5AFlT+4Mg5ACodAPwAAAAABAAAA
    EgAAAICt/T8AAAAAAAAAAKVTD4Cwrf0/AgAAABD5lD8AAAAAsK39P4gTAADcYvw/
    EgAAAAIAAAD+AAAAMPiUPxwdD4Dgrf0/hKQPQAIAAACQBZU/EgAAAEIAAABCCgAA
    AgAAAAQAAAAAAAAAQgoAAIQdD4AQrv0/uNZAPwIAAACse0E/vH1CPzCeQD8BAAAA
    AAAAABD5lD8BAAAAUhEAAMzRD4Awrv0/AQAAAAAAAAAAAAAAEPmUPwAAAAAAAAAA
    L1QPgFCu/T8IAAAAOAWVPwz5lD8BAAAAeK79P+Cu/T8cHQ+A8K79P3hh/D94Yfw/
    UK/9P602CEAvVA+AUK79P1Cv/T8NAAAAQPmUPwAAAAA8+ZQ/AAAAAAAAAAAAAAAA
    AAAAAAAAAAAcHQ+A8K79P3hh/D94Yfw/WsQPgGIPAAANAAAACAAAADT5lD8AAAAA
    AAAAAPD4lD9A+ZQ/PPmUPwwAAAAQsP0/7LUPQAMAAAAM+ZQ/AAAAADD///85BZU/
    NtEPgDCv/T/g95Q/AAAAAEIElT8wr/0/yN1APwMAAAACAAAAELD9P7z5lD+6+ZQ/
    8PiUP0AAAAANAAAA8K79Py9UD4BQr/0/EAAAAPf5lD8CAAAAELD9P3iv/T8Ar/0/
    HB0PgPCv/T94Yfw/eGH8P7Cw/T+gr/0/L1QPgFCv/T+wsP0/BQAAACCw/T8AAAAA
    HLD9PwAAAABQsP0/SAOVP30AAAAAAAAAHB0PgPCv/T94Yfw/eGH8P1rED4BYA5U/
    BQAAAAgAAAAUsP0/AAAAAAAAAADwr/0/ILD9Pxyw/T8EAAAAAAAAAFCw/T8MsP0/
    DLD9PwAAAAAw////+PmUP0kdD4BwsP0/oPeUPwAAAACW+ZQ/9fmUPyD3lD8IsP0/
    FLD9P3hh/D8FAAAA4PeUPxoWAABstkA/HhYAAGy2QD+O4g2AULD9PwYAAACg95Q/
    kvmUP2Cw/T+AsP0/AAAAAAAAAAAAAAAAAgAAAAAAAADwr/0/AAAAAAUAAAAwsP0/
    oOINgJCw/T+g95Q/AAAAAAAAAAAAAAAAiPiUP6D3lD975Q2AsLD9P6D3lD+DBQAA
    AAAAAAAAAAAAAAAA/QAAANTRDYBQsf0/Ju2UP+D3lD8AAAAAALH9P3vlDYCwsP0/
    AAAAAAAAAAAAAAAA3QdBP7gHQT8IAAAAAtINgECx/T8UAAAAALH9P9TRDYBQsf0/
    Ju2UP+D3lD9L4g2AGASVP9AClT8wsf0/BgAAANxi/D8AAAAAMLH9P8iw/T8wsf0/
    AAAAAL1DQgDg95Q/AQAAAAAAAADdB0E/uAdBPwgAAAAAAAAAcLH9Pw4WAADgVvw/
    ALH9PwAAAAAAAAAAQF38PwAAAADAsv0/AAAAAAAAAAABAAAAAAAAAKWlpaWlpaWl
    ogAAACEAAAAgQk9PVC5QWQD//////2Jvb3QucHkA////////////////////////
    //////////////////////+lpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
    paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaW0NAhAgM4NQDAABQAAAAAA
    wLL9PwAAAAAA//////////////////////////////////////////8AAAAAAAAA
    AAAAAAEAAAAAAAAA/////wAAAAD/////////////////////xUITgQAAAAAyAAAA
    AgEAAAAAAAAAAAAAAAAAAAAAGQBwsf0/AAAAAAAAAAAAACgAAAAAAECy/T8AAAAA
    AAAAAAEAAAABAAAAPh5APwAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAMyy/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    aF/9P/Bd/T9gX/0/
    8F39PwBf/T/9LjKo5GT9P7hR/D9oX/0/sFH8PxkAAAC/XhfQERQMLWhf/T8AAAAA
    AAAAAGRb/T9JRExFACraXXTwzX7ZlCsAAAAAAGBf/T8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAB8a/0/5Gv9P0xs/T8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADpHtA==
    tDQIQIQDFUAwBgYAIMwIgLBe/T8gAAAAAQAAAAAAAADcqPw/pFP8P0xR/D/4qPw/
    MzMzAwAAAABQDwAAAAAAAPAP/j8DAAAAIwAGAAoAAACQX/w/cF79P1hyDkCUcg5A
    AAAAAK02CEDwD/4/dNwIQMSE+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAADwD/4/AwAAACMABgAAAAAA0F79PwAAAAAAAAAA
    AAAAANyo/D+kU/w/TFH8PwAAAAAAX/0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
    AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAxf/T8AAAAA
    3GT9P2Bj/T/UZP0/
    YGP9P3Bk/T8aXeXzuFH8P3Bf/T/cZP0/sFH8PxkAAADzoRL7aJaAqdxk/T8AAAAA
    AAAAANhg/T9JRExFAMJ3Np0lqGGsJxIAAQAAANRk/T8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHcESw==
    tDQIQIQDFUAwCwYAIMwIgCBk/T8gAAAAAQAAACAAAADcqPw/qFP8P0xR/D8Yqfw/
    EGT9PwAAAAAjBAYAIAQGAOB8/T+4GPw/IAAGAAAAAAAAAAAArTYIQAAAAAAAAAAA
    AAAAAK02CEDgfP0/dNwIQDSK+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAABfMCIAgZP0/BBn8P6RT/D8AAAAAQGT9PwAAAAABAAAA
    AAAAAAQZ/D+oU/w/TFH8PwAAAABwZP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
    AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHxk/T8AAAAA
    hFn9PxBY/T98Wf0/
    EFj9PxBZ/T+uRwAADH37P9Br+z+EWf0/nFH8PxQAAAAAAAAAAAAAAIRZ/T8AAAAA
    BQAAAIBR/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAHxZ/T8AAAAAIQAGAAUAAAAAAAAA
    HNv7PwAAAABoOA1AAAAAAAsAAAB8a/0/5Gv9P0xs/T8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
    tDQIQJDLCEAwCwYAM9MNgNBY/T+uRwAAqFP8PwQZ/D8BAAAAAAD/AAAAAP+QywiA
    sFj9PwEAAACuRwAAhFn9PwEAAAD+AAAAOKv8PwAAAAAAmQ6AkFj9P3i2CUCmtglA
    /////602CEABAAAAdNwIQNR++j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAABACABcAAAAA/gAAAACr/D8AAAAA8Fj9PwAAAAABAAAA
    qFFAPwEAAAAAAP8AAAAA/wAAAAAQWf0/AAAAAAAAAAAAAAAAAQAAAGJZ/D8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHFn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    BH37P1AQ/j9YEv4/
    UBD+P/AR/j+vRwAA1Gf9P4xZ/T8Effs/nFH8PxMAAABYvglAAAAAAAR9+z8AAAAA
    BgAAAFwE/j9TaWdmb3gAAAAAAABMffsAAAAAAFgS/j8AAAAAIQAGAAYAAAAAAAAA
    tDQIQJDLCEAwBgYAXscagBAR/j+vRwAApFP8PwQZ/D8AAAAAAAAAAAAAAACQywiA
    8BD+PwAAAACvRwAABH37PwEAAAD+AAAAGMVCPxEAAAC0N/s/AAAAAFy4CUBnuAlA
    /////602CEABAAAAdNwIQLQ3+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAR9+z8BAAAA/gAAABjFQj8AAAAAMBH+Pzi7/D80u/w/
    BBn8PwAAAAAAAAAAAAAAAAAAAADwEf4/AAAAAAAAAAC0NAhARMcaQDAABQAAAAAA
    8BH+PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    tDf7PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPwR/j8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
    zGf9P5BP/T94Uf0/
    kE/9PxBR/T/8RwAApFH8Pwx9+z/MZ/0/nFH8PwcAAACItP0/iLT9P8xn/T+AtP0/
    EgAAAHxD/T90aVQAdADpkIupCU+g5QoA////f3hR/T8AAAAAIQAGABIAAAABAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHG8Jg==
    tDQIQEi+CEAwBAYA8Z0WgFBQ/T9ctP0/4FD9P6i0/T8AAAAAsLT9PwAAAABIvgiA
    MFD9PwAAAABkAAAApFP8PwAAAAAEGfw/AAAAABkAAADg2vw//wAAANWIFkDeiBZA
    AAAAAK02CEAAAAAAdNwIQNR2+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAGBQ/T9AUP0/DAAAAMT9/T81IxaAkFD9P+yr/D/gUP0/
    AAAAAJhHAAAAAAAAAAAAAGQAAAAAAAAAAQAAAAAAAABAIxaAoFD9PwAAAAB4OghA
    Z60VgMBQ/T/sq/w/4FD9P2etFYDAUP0/7Kv8P+BQ/T9kAAAAmEcAANoEvD8UAAAA
    AAAAAOBQ/T/smhZAAAAAAKSy/D8AIhZAAAAAAKRT/D8AAAAAEFH9PwAAAAAAAAAA
    AAAAAAAAAAAcUf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    yGv7P9Bp+z/Aa/s/
    0Gn7P2Br+z+uRwAAjFn9P6RR/D/Ia/s/nFH8PxMAAAAAAAAAAAAAAMhr+z8AAAAA
    BgAAAMRh+z9Mb1JhAAAAAAAAAAAAAAAAAQAAAMBr+z8AAAAAIQAGAAYAAAAAAAAA
    tDQIQJDLCEAwCwYA+isQgJBq+z+uRwAAqFP8PwQZ/D8BAAAAAAAAAAAAAACQywiA
    cGr7PwEAAACuRwAAyGv7PwEAAAD+AAAAAAEAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAK02CEABAAAAdNwIQCSR+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAMhr+z8BAAAA/gAAAAABAAAAAAAAsGr7P/Rm/D8AAAAA
    BBn8PwEAAAAAAAAAAAAAAAAAAABga/s/AAAAAAAAAABga/s/AAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkkfg/AAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAZ/w/CwAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbGv7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    TGb9P5B5/T/gev0/
    kHn9P4B6/T8AAAAAkFH8P5BR/D9MZv0/iFH8Pw8AAAAYcP0/GHD9P0xm/T8QcP0/
    CgAAAORw/T9UbXIgU3ZjAPCn99+DfNwAAAAAAOB6/T8AAAAAIQAGAAoAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFqtuQ==
    tDQIQMXaCEAwAAYAAAAAAFB6/T8AAAAAAAAAAAAAAAC0U/w/rFP8PwkAAADF2giA
    MHr9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAK02CEAAAAAAdNwIQESg+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAESg+j8AAAAAAAAAAAAAAAAAAAAAgHr9PwAAAAAAAAAA
    AAAAAAAAAACMev0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    DEL9P4BA/T8EQv0/
    gED9P6BB/T+cb5bbRHn7P8TO/T8MQv0/LFH8PwEAAABob/0/aG/9PwxC/T9gb/0/
    GAAAAAg+/T9pcGMxANMDjOUEUy4WwhoAAQAAAARC/T8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPA9eg==
    tDQIQEi+CEAwBQYA7B4IgEBB/T88b/0/AAAAAIhv/T8AAAAAPG/9PwAAAABIvgiA
    IEH9PwEAAAD/////qFP8PwEAAAAEGfw/IAMGAAAAAAAAAAAAAQAAAAAAAAAAAAAA
    AAAAAK02CEABAAAAdNwIQGRn+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAgEH9P4xQ/D8AAAAA
    AAAAAEQEAAAAAAAAIAMGAP////+AQf0/jFD8P3hQ/D/Ybv0/AAAAAAEAAAAAAAAA
    AAAAAKBB/T8AAAAAAAAAAJhfCEABAAAAAAAAAAAAAABRFAiAgH3+PwEAAAAAAAAA
    AAAAAAAAAACsQf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAA==
    PHn7P5B3+z80efs/
    kHf7P9B4+z8AAAAAoDz9PxRC/T88efs/LFH8PxEAAAAAAAAAAAAAADx5+z8AAAAA
    CAAAADht+z9Mb1JhX1RpbWVyX2NhbGwAAQAAADR5+z8AAAAAIQAGAAgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
    tDQIQPC/AEAwAAYArsYIgFB4+z8AAAAAIwAGACAABgAwsf0/AQAAAAAAAAD//z+z
    /gAAALgY/D8jAAYAPHn7PwEAAAD+AAAA5GFBPwAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAAK02CEABAAAAdNwIQJSe+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAe1giAYHj7PwQZ/D8IAAAA
    8RcQgIB4+z8BAAAA/////zx5+z8BAAAA/gAAACAGBgAAAAAAoHj7PwAAAAAAAAAA
    BBn8P6RT/D+oU/w/AQAAAAAAAADQePs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANx4+z8AAAAA
    mDz9PxA7/T+QPP0/
    EDv9PzA8/T+Gv5PSRGn9P0R5+z+YPP0/LFH8PwEAAAAQb/0/EG/9P5g8/T8Ib/0/
    GAAAAJQ4/T9pcGMwAEz/srX30STDH9MAAAAAAJA8/T8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCS2g==
    tDQIQEi+CEAwAAYA7B4IgNA7/T/kbv0/AAAAADBv/T8AAAAA5G79PwAAAABIvgiA
    sDv9PwAAAAD/////pFP8PwAAAAAEGfw/FwAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
    AAAAAK02CEAAAAAAdNwIQPRh+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAEDz9P4hQ/D8AAAAA
    AAAAAOIEAAAAAAAAFwAAAP////8AAAAAiFD8P3hQ/D/Ybv0/AAAAAAEAAAAAAAAA
    AAAAADA8/T8AAAAAAAAAAJhfCEAAAAAAAAAAAAAAAAC1EwiAYDz+PxRR/D8cUfw/
    AAAAAAAAAAA8PP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    PGn9PwDH/T+4yP0/
    AMf9P1DI/T9w7MPRYNj7P6A8/T88af0/LFH8PwUAAACQtv0/kLb9Pzxp/T+Itv0/
    FAAAALy8/T9ldmVudFRhc2sApsp6hdYAAAAAALjI/T8AAAAAIQAGABQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMZ2WQ==
    tDQIQEi+CEAwBgYAqAIVgMDH/T9ktv0/AMj9P7C2/T8AAAAAuLb9PwAAAABIvgiA
    oMf9PwAAAAD/////pFP8PwAAAAAEGfw/AAAAAAAAAAAXAAAAAMj9P3i2CUCmtglA
    AAAAAK02CEAAAAAAdNwIQBTu+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAAMj9P5So/D8AAAAA
    AAAAAO4wAAD+AAAAIAwGAP////8AyP0/lKj8PwAAAACwtv0/AAAAAHi3/T8BAAAA
    AAAAAFDI/T8AAAAAAAAAAAcAAADAqAER////AMCoAQEBAAAAEACAP/4AAAAGAAAA
    y0IWgFBQ/T/E/f0/yAK8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAABcyP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    WNj7P7DW+z9Q2Ps/
    sNb7P/DX+z8AAAAA9Db9P0Rp/T9Y2Ps/LFH8PwIAAADowfs/6MH7P1jY+z/gwfs/
    FwAAAFTI+z93aWZpAAAAAAAAAAAAAAAAAAAAAFDY+z8AAAAAIQAGABcAAAABAAAA
    tDQIQEi+CEAwBgYA+CITgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAABIvgiA
    UNf7PwAAAAD/////pFP8PwAAAAAEGfw/1QAAABgAAABQjvw/gAAAAHi2CUCmtglA
    /////602CEAAAAAAdNwIQLT9+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAACw1/s/6NH8P6CP/D8AAAAAsNf7P+jR/D+gj/w/
    AAAAAE9HAADo0fw/kEkNAf////+AAbw/AAAAAAAAAADcjrw/zHASQPUAAAAEAAAA
    AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARAAAAAAAAAAAAAAAAAAAA
    GgAAAMcjE0AcvUE/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA
    7Db9P2A1/T/kNv0/
    YDX9P4A2/T+IotJyoFH7P2DY+z/sNv0/LFH8PwMAAABMbf0/TG39P+w2/T9Ebf0/
    FgAAAOgq/T9lc3BfdGltZXIAUUuy+40AAAAAAOQ2/T8AAAAAIQAGABYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEBEzg==
    tDQIQEi+CEAwBgYALScNgCA2/T8gbf0/AAAAAGxt/T8AAAAAIG39PwAAAABIvgiA
    ADb9PwAAAAD/////pFP8PwAAAAAEGfw/IAAGAAAAAABEXPo/AAAAAHi2CUCmtglA
    /////602CEAAAAAAdNwIQERc+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAJMnDYBANv0/AAAAAAAAAAAAAAAAYDb9PzRQ/D88UPw/
    AAAAAGNHAAD+AAAAIAAGAP////9gNv0/oNr7PzxQ/D8AAAAAkVUeAQAAAABQAAAA
    AAAAAIA2/T8AAAAAAAAAAAAAAAAAAAAAPFD8PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAACMNv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAA==
    mFH7PwBQ+z+QUfs/
    AFD7PzBR+z8AAAAANFH8P/Q2/T+YUfs/LFH8PwQAAAAIR/s/CEf7P5hR+z8AR/s/
    FQAAAJRH+z9wbVQAAAAAAAAAAAAAAAAA////f5BR+z8AAAAAIQAGABUAAAAAAAAA
    tDQIQEi+CEAwCwYAJfcSgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAABIvgiA
    oFD7PwEAAAD/////qFP8PwEAAAAEGfw/KKL8Pw8AAAAzMzMDAAAAAHi2CUCmtglA
    /////602CEABAAAAdNwIQPR2+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAADoAwABAAAA/gAAACii/D8AAAAAAFH7P1CO/D84u0E/
    AAAAAGNHAABQjvw/OLtBP/////8AUfs/UI78Pzi7QT8oR/s/AAAAAP////8AAAAA
    AAAAADBR+z8AAAAAAAAAAAYAAAADAAAAAAAAAAAAAACMj/w/UI78PywBAAAAAAAg
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    vM79PxDm/T8o6P0/
    EOb9P8Dn/T+lpaWlFEL9PzRR/D+8zv0/LFH8Pw4AAADsyP0/7Mj9P7zO/T/kyP0/
    CwAAACzQ/T9JUlFzAKWlpaWlpaWlpaUAAQAAACjo/T8AAAAAIQAGAAsAAAAAAAAA
    AAAAAFzn/T8AAAAAAAAAAAAAAAB8a/0/5Gv9P0xs/T8AAAAAAAAAAAEAAAAAAAAA
    tDQIQEi+CEAwAQYAb44OgNDm/T/AyP0/cOf9PwzJ/T8AAAAAFMn9PwAAAABIvgiA
    sOb9PwEAAAD/////qFP8PwEAAAAEGfw/AAAAAAAAAACEDfs/AAAAAAAAAAAAAAAA
    AAAAAK02CEABAAAAdNwIQIQN+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAuAAAApaWlpaWlpaV81w2AEOf9PwBg/D9w5/0/
    AAAAADgAAAClpaWlpaWlpf////8Q5/0/3GL8P3Dn/T8AAAAAAQAAAPRf/D/INPw/
    AAAAAKDn/T/0X/w/AAAAAMDn/T8AAAAAAAAAAAAAAAAAAAAA9F/8PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB4Yfw/
    eGH8PwAAAABw5/0/ABQAAIQN+z8AAAAAAAAAAAAAAAB4Yfw/AAAAAAoAAAD///9/
    AAAAAMDn/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAADM5/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    Rebooting...
    ets Jun  8 2016 00:22:57
  • I'm having a similar problem with similar code. Have you made any progress?
