CAT-M1 cannot Attached
  • Device using: Gpy
    SIM card: Hologram
    I activated some hologram sim cards and test it on my Gpy but it cannot attach to the network. I test "at+cereg" in the loop of attaching, and the result is:
    ^EXIT: Assertion failed
    +SYSSTART
    +CEREG: 2,0
    I tested Gpy that can work perfectly with the newly activated sim card, and it can connect.
    But the same code on a new board with the same sim card, it cannot attach to the network. So I guess it is probably not the problem of sim cards.
    My lte connection code is
    lte.init()
    lte.send_at_cmd('AT+CFUN=0')
    lte.send_at_cmd('AT!="clearscanconfig"')
    print("Hologram use"+lte.send_at_cmd('at+cgdcont=1,"IP","hologram"'))
    lte.send_at_cmd('AT+CFUN=1')
    while not lte.isattached():
           time.sleep(0.5)
           attachTimeout += 1
           print(lte.send_at_cmd('AT+CEREG?')[:-1], end='')
           if attachTimeout == 15:
                    print(" LTE Failed")
                    time.sleep(0.750)
                    # Shutdown the LTE system
                    if lte.isconnected:
                        lte.disconnect()
                        time.sleep(2)
                    if lte.isattached():
                        lte.dettach()
                        time.sleep(2)
                    lte.deinit(reset=True)
                    machine.reset()
            print("lte is attached")
            # Now we busy wait for the Internet connection
            print("Start to connect")
            lte.connect()
            connectTimeout = 0
            while not lte.isconnected():
                connectTimeout += 1
                if connectTimeout == 15:
                    # pycom.rgbled(ucot.LED_RED)
                    time.sleep(0.750)
                    # pycom.rgbled(ucot.LED_BLACK)
                    print("lte is not connected")
                    lte_off()
                    # # Go to deepsleep for one tenth of a reporting interval
                    # pySense.setup_sleep((REPORTING_INTERVAL/10) * 60)
                    # pySense.go_to_sleep()
                    machine.reset()
            print("lte is connected")
    Is there any problem of this usage or do I need to specially config anything?
  • @Terry666 Can you try to set the timeout to a much larger value? For the first time, that may be needed.
