gPy modem bricked
  • Hi there,
    Maybe someone was successful in upgrading modem firmware or recovering from below state.
    I was trying to upgrade firmware to the newest version... it failed, and now I cannot use lte.
    >>> from network import LTE
    >>> lte=LTE()
    OSError: Couldn't connect to Modem
    When I'm trying to run firmware update again - it also fails:
    >>> sd = SD()
    >>> os.mount(sd,'/sd')
    >>> os.listdir('/sd')
    ['updater.elf', 'CATM1-41065.dup']
    >>> sqnsupgrade.run('/sd/CATM1-41065.dup','/sd/updater.elf',debug=True)
    <<< Welcome to the SQN3330 firmware updater [1.2.5] >>>
    >>> GPy with firmware version 1.18.2.r7
    File /sd/updater.elf has size 430284
    File /sd/CATM1-41065.dup has size 6160982
    The current delay is 1000
    Response (+++ #1): None
    Response (AT #1) None
    Response (AT #3) None
    Response (AT #4) None
    Response (AT #1 @ 115200) None
    Response (AT #2 @ 115200) None
    The current delay is 2000
    The current delay is 3000
    Response (AT #2 @ 115200) b"\xaczZ\xecc\xda\xff$\x03\x00\xc2\xac\xc6\x00\xa1'\xae$\x03\x00\xfe{\xae\xa3Fs\xa1F,\xe3\xeec!J\xca\xffFwsY\xd6#\x87%0\xdd\xe2g\xa1\xae\xe0\x84\xd3=\xc2`\xbc\xa7o\x0b\xef{\x9aN\xc2 ..."
    The current delay is 4000
    Response (+++ #1): b"ile: ... SNOWY PANDA\r\nFatal error\r\nFile: wdtHard.c@65\r\n'hardwatchdog triggered'\r\n\r\n##### SNOWY PANDA\r\nFatal error\r\nFile: wdtHard.c@65\r\n'hardwatchdog triggered'\r\ne: wdtHard.c@65\r\n'hardwatchdog trigger\xe5"
    Response (AT #2) None
    Response (+++ #2): None
    The current delay is 5000
    Response (AT #2 @ 115200) b"{\\B\xc2\xca\xbcjJ\xc6\xff\xeec!J\xca\xffFwsY\xd6#\x87%0F-g\xbaw\xe0\x84\xd3=\xc2`\xbc\xa7o\x0b\xcfw\xe7\xb1\xc2 \x82B\xceB3jB\x82BB!+\xef~\xf3gBh8\xd6\xbf\xfe$\x03\x00\xc2\xacc-g\xa1\xae$\x03\x00\xc2\xacc-..."
    Modem state: None
    Could not detect your modem!
    Please try to power off your device and restart in safeboot mode.
    Is it completely bricked?
