<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fresh Atom and Pymakr install fails]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I've just had a fresh install of Atom and Pymakr  on OS X but getting an error on @serialport/bindings so this is unable to run.</p>
<p dir="auto">Has anyone seen this before and if so, what is the fix? Are the developers aware of this issue and when will a fix be available.<br />
<img src="/assets/uploads/files/1570619086711-screen-shot-2019-10-09-at-6.49.49-am.png" alt="Screen Shot 2019-10-09 at 6.49.49 AM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">thanks</p>
<p dir="auto">Andrew</p>
]]></description><link>https://forum.pycom.io/topic/5269/fresh-atom-and-pymakr-install-fails</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 16:34:10 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/5269.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Oct 2019 11:05:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fresh Atom and Pymakr install fails on Mon, 28 Oct 2019 06:21:57 GMT]]></title><description><![CDATA[<p dir="auto">Any updates on how to solve this problem?</p>
<p dir="auto">Or are there better alternatives to using the Atom/PyMakr combination that actually work out of the box without any messing around?<br />
This is for a novice user I'm helping using a Mac.</p>
]]></description><link>https://forum.pycom.io/post/30044</link><guid isPermaLink="true">https://forum.pycom.io/post/30044</guid><dc:creator><![CDATA[thinginnovations]]></dc:creator><pubDate>Mon, 28 Oct 2019 06:21:57 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh Atom and Pymakr install fails on Thu, 10 Oct 2019 11:56:48 GMT]]></title><description><![CDATA[<p dir="auto">Just to add, this was a completely fresh install were Atom and Pymakr were not previously installed.</p>
]]></description><link>https://forum.pycom.io/post/29768</link><guid isPermaLink="true">https://forum.pycom.io/post/29768</guid><dc:creator><![CDATA[thinginnovations]]></dc:creator><pubDate>Thu, 10 Oct 2019 11:56:48 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh Atom and Pymakr install fails on Thu, 10 Oct 2019 07:10:20 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar issue. Deleting the ~/.atom folder and reinstalling pymakr from scratch fixed the issue. I am running version 1.40.1 and pymakr 1.4.17.</p>
]]></description><link>https://forum.pycom.io/post/29765</link><guid isPermaLink="true">https://forum.pycom.io/post/29765</guid><dc:creator><![CDATA[berni]]></dc:creator><pubDate>Thu, 10 Oct 2019 07:10:20 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh Atom and Pymakr install fails on Wed, 09 Oct 2019 21:51:41 GMT]]></title><description><![CDATA[<p dir="auto">Works only with Atom version 1.38<br />
Dont forget to turn off auto update as soon as possible.</p>
<p dir="auto">Maybe it is only a small version setting in pymker and easy to fix.</p>
<p dir="auto">You will find the solution somewhere in the github forum of pycom. Someone posted there a link to a working atom version.</p>
]]></description><link>https://forum.pycom.io/post/29763</link><guid isPermaLink="true">https://forum.pycom.io/post/29763</guid><dc:creator><![CDATA[crumble]]></dc:creator><pubDate>Wed, 09 Oct 2019 21:51:41 GMT</pubDate></item></channel></rss>
