<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GPY full flash erase]]></title><description><![CDATA[<p dir="auto">OK I've figured out that the pycom-fwtool is part of the updater &amp; a test command worked</p>
<pre><code>C:\Program Files (x86)\Pycom\Pycom Firmware Update&gt;pycom-fwtool-cli.exe -p COM3 chip_id
Running in FTDI mode
ESP32D0WDQ6 (revision 1)
</code></pre>
<p dir="auto">No obvious reason why the adhoc wifi is gone after the change to 1.20.1.r1 though</p>
<pre><code>C:\Program Files (x86)\Pycom\Pycom Firmware Update&gt;pycom-fwtool-cli.exe -p COM3 wmac
WMAC=30AEA42A6AB4
</code></pre>
<p dir="auto">it knows it's wifi MAC</p>
<p dir="auto">Anyway I'm anxious about trying the full flash erase considering &quot;Erase entire flash, only use this if you are sure you know what you are doing. This will remove your devices lpwan mac addresses etc.&quot; at <a href="https://docs.pycom.io/advance/cli/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/advance/cli/</a> At the moment 1.20.1.r1 has delivered reduced functionality (no adhoc wifi) I'm worried the full flash erase could leave me even worse off.</p>
]]></description><link>https://forum.pycom.io/topic/5348/gpy-full-flash-erase</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 02:19:05 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/5348.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Oct 2019 23:34:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GPY full flash erase on Thu, 31 Oct 2019 23:34:56 GMT]]></title><description><![CDATA[<p dir="auto">OK I've figured out that the pycom-fwtool is part of the updater &amp; a test command worked</p>
</code></pre>
WMAC=30AEA42A6AB4
</code></pre>
]]></description><link>https://forum.pycom.io/post/30143</link><guid isPermaLink="true">https://forum.pycom.io/post/30143</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Thu, 31 Oct 2019 23:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 07:48:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> The LPwan mac and sigfox addresses are restored during the firmware install using the pycom updater. So this is not a risk, and the robust method to start over with a defined state.  Since I try a lot with my devices, I have to do that full erase from time to time. I cannot tell anything about the ad-hoc wifi, since Im using STA mode in the local network, which anyhow requires a dedicated set-up of the WLAN. You can always do that specific set-up in your <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow">boot.py</a> or <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a>, if needed.</p>
]]></description><link>https://forum.pycom.io/post/30150</link><guid isPermaLink="true">https://forum.pycom.io/post/30150</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 07:48:30 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 11:07:09 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure how to do an adhoc wifi setup in <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow">boot.py</a> Rob. I tried pycom.wifi_on_boot(1) to get adhoc wifi back but it doesn't work. Any tips?</p>
]]></description><link>https://forum.pycom.io/post/30159</link><guid isPermaLink="true">https://forum.pycom.io/post/30159</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Fri, 01 Nov 2019 11:07:09 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 11:20:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> I had problem with the AccessPoint not initializing on 1.20.1.r1 release. However, that all went away when I did the &quot;erase_all&quot;, and then reflashing 1.20.1.r1 again.</p>
<p dir="auto"><img src="/assets/uploads/files/1572607216853-01.erase_all.png" alt="01.erase_all.png" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/30161</link><guid isPermaLink="true">https://forum.pycom.io/post/30161</guid><dc:creator><![CDATA[kodarn]]></dc:creator><pubDate>Fri, 01 Nov 2019 11:20:42 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 11:48:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5079">@kodarn</a> Was that on a GPY?</p>
]]></description><link>https://forum.pycom.io/post/30162</link><guid isPermaLink="true">https://forum.pycom.io/post/30162</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Fri, 01 Nov 2019 11:48:44 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 11:50:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> Ah, um, no, it was on a LoPy4 board.</p>
]]></description><link>https://forum.pycom.io/post/30163</link><guid isPermaLink="true">https://forum.pycom.io/post/30163</guid><dc:creator><![CDATA[kodarn]]></dc:creator><pubDate>Fri, 01 Nov 2019 11:50:22 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:33:17 GMT]]></title><description><![CDATA[<p dir="auto">It was a nice feature before that a new (firmware flashed) device was accessible by WiFi this is gone with the 1.20.1 release and makes the setup for some scenarios more complicated. I fear this feature was switched off to be replaced by PyCom's own setup wizard via pybytes in the future.</p>
]]></description><link>https://forum.pycom.io/post/30165</link><guid isPermaLink="true">https://forum.pycom.io/post/30165</guid><dc:creator><![CDATA[Clemens]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:33:17 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> I tested this short script, and it sets up the AP. Note, that you can set ssid, password, and IP address as you like. The DNS settings are more or less useless.</p>
<pre><code>#
# set device in AP mode
from network import WLAN
wlan=WLAN(mode=WLAN.AP, ssid=&quot;my_wlan_1&quot;, auth=(WLAN.WPA2, &quot;wlan_password&quot;))
wlan.ifconfig(id=1, config=(&quot;192.168.4.1&quot;, &quot;255.255.255.0&quot;, &quot;0.0.0.0&quot;, &quot;0.0.0.0&quot;))
</code></pre>
]]></description><link>https://forum.pycom.io/post/30166</link><guid isPermaLink="true">https://forum.pycom.io/post/30166</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:36:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/804">@Clemens</a> In my homebrew 1.20.0.r1 this feature is still present. It could be related to the fact, that the version 1.20.1 you can install via the pycom updater is a pybytes variant. For that, the automatic AP setup my be not useful, since that prevent access to the internet.</p>
]]></description><link>https://forum.pycom.io/post/30167</link><guid isPermaLink="true">https://forum.pycom.io/post/30167</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> I do not assume that GPY and the other board behave different with respect to WiFi.</p>
]]></description><link>https://forum.pycom.io/post/30168</link><guid isPermaLink="true">https://forum.pycom.io/post/30168</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:44:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> we at hiveeyes use and promote your firmware build as a good medicine in case the official version makes problems. So many thanks for this. It's a bit pity that you have to do the work pycom should jump in normally!</p>
]]></description><link>https://forum.pycom.io/post/30169</link><guid isPermaLink="true">https://forum.pycom.io/post/30169</guid><dc:creator><![CDATA[Clemens]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:44:58 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 12:50:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/804">@Clemens</a> I'm confused now. Are there two different 1.20.1.r1, the official pycom one &amp; Rob's? We don't use pybytes so I'd be keen to try Rob's. Where can I get a copy &amp; what do I use to load it if the pycom updater only does the pybytes variant?</p>
]]></description><link>https://forum.pycom.io/post/30171</link><guid isPermaLink="true">https://forum.pycom.io/post/30171</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 13:05:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> You can always build the firmware from the sources. That's easiest done on a Linux system. A virtual machine or WSL of Windows 10 also works. The latest version of the Dev branch creates the tar bundles, which can installed using the Pycom updater. On Linux system, you can do that also w/o the pycom updater. Using the Pycom updater has the advantage, that ot resets the Lora and Sigfox MAC, if that was lost after a full flash erase.</p>
<p dir="auto">Nevertheless, going that way is a big initial step, if you are not used to it. For Linux, any old system is sufficient, which many people may have around. Using Xubuntu or Mint xfce  is an easy install process.  Setting up the build environment is documented, but there are quite a few chances to omit things.</p>
<p dir="auto">b.t.w: I could update my pre-built bundles.<br />
b.t.w.2: I asked several times also to update the &quot;official&quot; non-pybytes variant. I think pycom refuses to do so, promoting pybytes as their entry into a service business.</p>
]]></description><link>https://forum.pycom.io/post/30172</link><guid isPermaLink="true">https://forum.pycom.io/post/30172</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 13:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 13:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> said in <a href="/post/30172">GPY full flash erase</a>:</p>
<blockquote>
<p dir="auto">I think pycom refuses to do so, promoting pybytes as their entry into a service business.</p>
</blockquote>
<p dir="auto">Pycom marked the &quot;normal&quot; firmware as legacy. So I do not think, that they will update this branch.</p>
]]></description><link>https://forum.pycom.io/post/30174</link><guid isPermaLink="true">https://forum.pycom.io/post/30174</guid><dc:creator><![CDATA[crumble]]></dc:creator><pubDate>Fri, 01 Nov 2019 13:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 16:32:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">we might want to divert that to a different forum thread, but just for the sake of completeness we also started brewing our own firmware images and publish them to [1]. Please let us know if we can be helpful for the community in any way on this topic.</p>
<p dir="auto">Cheers,<br />
Andreas.</p>
<p dir="auto">P.S.: Disclaimer: <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/804">@Clemens</a> and me are on the same team working on a datalogger software called <em>Terkin for MicroPython</em> [2]. We learned many things from <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> and are taking different kinds of deep-dives into things we wouldn't better not have known about [3].</p>
<p dir="auto">[1] <a href="https://packages.hiveeyes.org/hiveeyes/foss/pycom/" target="_blank" rel="noopener noreferrer nofollow">https://packages.hiveeyes.org/hiveeyes/foss/pycom/</a><br />
[2] <a href="https://community.hiveeyes.org/t/developing-terkin-for-micropython/233" target="_blank" rel="noopener noreferrer nofollow">https://community.hiveeyes.org/t/developing-terkin-for-micropython/233</a><br />
[3] <a href="https://community.hiveeyes.org/t/random-memory-corruption-faults-on-esp32-wrover-rev-1-and-rev-2-when-running-in-dual-core-mode/2515" target="_blank" rel="noopener noreferrer nofollow">https://community.hiveeyes.org/t/random-memory-corruption-faults-on-esp32-wrover-rev-1-and-rev-2-when-running-in-dual-core-mode/2515</a></p>
]]></description><link>https://forum.pycom.io/post/30176</link><guid isPermaLink="true">https://forum.pycom.io/post/30176</guid><dc:creator><![CDATA[andreas]]></dc:creator><pubDate>Fri, 01 Nov 2019 16:32:37 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Fri, 01 Nov 2019 16:31:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> Looking at the source code I can see, that the WiFi settings for boot are now taken from a flash configuration data set. I did not dig further about how this data is set. The intention may be to set that in the pybytes configuration dashboard.   Since my devices start that AP with software implementing that property, and these have been erased, It may be that the default is: start the AP.</p>
]]></description><link>https://forum.pycom.io/post/30178</link><guid isPermaLink="true">https://forum.pycom.io/post/30178</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Nov 2019 16:31:12 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 00:03:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> I'm still confused. Am I right in thinking there are two 1.20.1.r1 firmwares now? The pybytes version (which has no adhoc wifi) that the pycom updater will install and your version that I have to assemble on a linux machine before I can install it?</p>
]]></description><link>https://forum.pycom.io/post/30184</link><guid isPermaLink="true">https://forum.pycom.io/post/30184</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Sat, 02 Nov 2019 00:03:49 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 00:53:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> Anyone can build firmware images from the sources. Pycom is obviously featuring their offical firmware builds stronger with respect to features of their product platform while we are aiming to freeze our foundation modules into different builds in order to brew customized firmware images better fitting the requirements of our community.</p>
]]></description><link>https://forum.pycom.io/post/30185</link><guid isPermaLink="true">https://forum.pycom.io/post/30185</guid><dc:creator><![CDATA[andreas]]></dc:creator><pubDate>Sat, 02 Nov 2019 00:53:25 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> As <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1198">@andreas</a> told, the firmware builds I make are not that special. They include only my favorite scripts as frozen bytecode, and I have tailored the build scripts to support my build environment. Sometimes I try special variants, like a version the supports Lora EU433, or an option to invert UART, .....,<br />
It is not explained by PyCom, which of the various branches in the PyCom repository is the recent &quot;official&quot; one. By convention, it should be 'master'. But the actual development seems to happen at Dev (tagged as default), which seems to include the pybytes code. But there is also a branch called 'pybytes-master'.<br />
Edit: This is the list of actual branches with their most recent update times:</p>
<pre><code>Dev (default)           Oct 30, 2019
Release/v1.20           Oct 7, 2019
pybytes-master          Oct 5, 2019
OTA_1_20_Prep/master    Sep 15, 2019
fw_fixes                Sep 10, 2019
release-candidate       Aug 22, 2019
Release/v1.18           May 15, 2019
master                  May 14, 2019
bug_fixes               Apr 15, 2019
pypic_pid_fix           Mar 1, 2019
development             Nov 12, 2018
spi_bitorder            Nov 7, 2017
</code></pre>
]]></description><link>https://forum.pycom.io/post/30187</link><guid isPermaLink="true">https://forum.pycom.io/post/30187</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:26:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> I don't think I'm smart enough to roll my own firmware. When I run the latest Windows pycom firmware updater it starts by telling me the latest firmware is 1.16.1 but then later it says it downloaded &amp; used 1.20.1.r1  I assume that's the Oct 5th pybytes-master in your list, with no adhoc wifi? How is this different from Oct7th Release/v1.20?</p>
]]></description><link>https://forum.pycom.io/post/30188</link><guid isPermaLink="true">https://forum.pycom.io/post/30188</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:26:51 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:37:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> said in <a href="/post/30166">GPY full flash erase</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Is this a way to setup an adhoc wifi that I can turn on/off with import pycom, machine; pycom.wifi_on_boot(1); machine.reset() ?</p>
]]></description><link>https://forum.pycom.io/post/30190</link><guid isPermaLink="true">https://forum.pycom.io/post/30190</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:37:53 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:45:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> 1.16.1 is the version of the firmware updater itself. Whereas 1.20.1r1 is the latest revision of the firmware for the PyCom modules. Both the Dev and Release/ v1.20 have the revision number 1.20.1.r1, the differ in the pybytes revision. Dev shows pybytes 1.2.0, Release/v1.20 shows pybytes 1.1.3. The branch pybytes-master has the firmware revision 1.18.3. That's all in the file pycom_version.h in the repository.<br />
b.t.w.: I build my firmware w/o pybytes support.</p>
]]></description><link>https://forum.pycom.io/post/30191</link><guid isPermaLink="true">https://forum.pycom.io/post/30191</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:45:00 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:47:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> said in <a href="/post/30190">GPY full flash erase</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">No. This little script will turn on an AP, configured to your needs, if you put it into <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow">boot.py</a> or <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a></p>
]]></description><link>https://forum.pycom.io/post/30192</link><guid isPermaLink="true">https://forum.pycom.io/post/30192</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:47:09 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 07:52:59 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<p dir="auto">Do you know if there is flavour of LittleFS firmware that still has adhoc wifi? If so could I download it with the pycom updater with the 'legacy' option?</p>
]]></description><link>https://forum.pycom.io/post/30193</link><guid isPermaLink="true">https://forum.pycom.io/post/30193</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Sat, 02 Nov 2019 07:52:59 GMT</pubDate></item><item><title><![CDATA[Reply to GPY full flash erase on Sat, 02 Nov 2019 10:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3449">@kjm</a> LittleFS came with version 1.20.<br />
I just made a test about ad-hoc AP and firmware variants:</p>
<ul>
<li>1.20.1r1 without pybyte: ad-hoc AP comes</li>
<li>1.20.1r1 with pybytes: no ad-hoc AP</li>
</ul>
<p dir="auto">So it is the by pybytes option which chooses another way. Some Information may be found at <a href="https://docs.pycom.io/smart" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/smart</a>. That all looks for me like an endless source of trouble, because so many instances are involved: - your PC, Pycom servers &amp; services, a smart phone IOS only(!) app, local access points, the Pycom devices, ... And if any of that fails, the process fails.</p>
<p dir="auto">BUT: at least I found a bypass, that worked on my device. If you copy a file named &quot;pybytes_config.json&quot; with the content below to your device, pybytes will not start and the ad-hoc AP comes up.</p>
<pre><code>{&quot;wifi&quot;: {&quot;ssid&quot;: &quot;&quot;, &quot;password&quot;: &quot;&quot;},
         &quot;wlan_antenna&quot;: 0,
         &quot;dump_ca&quot;: &quot;FALSE&quot;,
         &quot;cfg_msg&quot;: &quot;NULL&quot;,
         &quot;server&quot;: &quot;&quot;,
         &quot;ssl&quot;: &quot;FALSE&quot;,
         &quot;lte&quot;: {&quot;apn&quot;: &quot;NULL&quot;, &quot;cid&quot;: 1, &quot;reset&quot;: &quot;FALSE&quot;, &quot;carrier&quot;: &quot;NULL&quot;, &quot;band&quot;: &quot;NULL&quot;, &quot;type&quot;: &quot;NULL&quot;},
         &quot;device_id&quot;: &quot;&quot;,
         &quot;network_preferences&quot;: [],
         &quot;ota_server&quot;: {&quot;port&quot;: 443, &quot;domain&quot;: &quot;software.pycom.io&quot;},
         &quot;pybytes_autostart&quot;: &quot;FALSE&quot;,
         &quot;username&quot;: &quot;&quot;,
</code></pre>
<p dir="auto">Note: These are double quotes in the text. Strange also, that with pybytes Ctrl-D for soft reset does not work any more.</p>
]]></description><link>https://forum.pycom.io/post/30194</link><guid isPermaLink="true">https://forum.pycom.io/post/30194</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Sat, 02 Nov 2019 10:02:23 GMT</pubDate></item></channel></rss>
