LoPy 4 Recurring Crashes
  • Hello,
    I've a Lopy4 plugged into a PySense. These perform a standard temperature sending in LoraWan on TTN, the authentication is done in OTAA. The process is as follows:
    -I join the Lorawan network
    -I send the data
    -I'm going deepsleep.
    The process takes place over several hours/days. The problem is that at a moment yet to be determined, it will cut itself off. I have set up a log system and I think the problem is the "socket.send()".
    Is there any known error in this regard?
    Thank you in advance to the community.
