    How to wake up the lopy with the accelerometer
    23 Posts 7 Posters 877 Views 8 Watching
      CeylordZ
      Hi !
      I'm new with pycom product, I brought a Lopy and a Pytrack for a project. I'd like to know if there is a way to use sleep mode and the accelerometer in the same time ? I'd like to wake up the lopy when I have a high acceleration (6g by example) and send the data on my LorAwan network.
      Is it possible ? If not, I'll use an other board with accelerometer to use a interrupt pin of the lopy board.
      Thank you by advance for your help !
      • R Offline
        railmonitor
        Yes, that is definitly possible. Have a look a the following code, it is written for FiPy with Pysense board, so there might be some differences regarding libraries / pins but should work when corrected:
        from pysense import Pysense
        from LIS2HH12 import LIS2HH12
        py = Pysense()                  #Create Pysense object
        acc = LIS2HH12()                #Create accelerometer object
        if pycom.heartbeat() == True:   #turn off blinking LED
        wakeup_reason = machine.wake_reason()
        #Enable interrupts from accelerometer (P13) and button (P14)
        machine.pin_sleep_wakeup(['P13'], mode=machine.WAKEUP_ANY_HIGH, enable_pull = False)
        machine.pin_sleep_wakeup(['P14'], mode=machine.WAKEUP_ALL_LOW, enable_pull = False)
        # set the acceleration threshold to 2000mG (2G) and the min duration to 200ms
        acc.enable_activity_interrupt(2000, 160)
        if(wakeup_reason == machine.PIN_WAKE):
            pycom.rgbled(0xffff00)  #yellow
            time.sleep(2)
        print("Turning on Red LED for 2 sec")
        pycom.rgbled(0xff0000)      #red
        time.sleep(2)
        print("Enter lightsleep mode for 5 sec")
        machine.sleep(5000)         #Value in ms
        print("Pysense Wakeup reason is " + str(wakeup_reason))
        if acc.activity():
            pycom.rgbled(0x800080)  #purple
            pycom.rgbled(0x0000ff)  #blue
        C J 3 Replies Last reply Reply Quote 2
          CeylordZ @railmonitor
          @railmonitor that's what I looked for, thank you !
            @railmonitor And is it possible to store the data from the accelerator when it wake up ? Or I have to keep it awake if I want to measure the acceleration ?
            I want to know how strong is the acceleration when it wake up the board (2g, 4g or 8g for example...).
            • R Offline
              railmonitor @CeylordZ
              @CeylordZ Sure. There are several way to do that. An "elegant" way to do it, if you want several measurements over short intervals is to setup a timer Alarm, to call a method that takes readings from the accelerometer and stores them in a array or whatever you like. The following code, assuming you have setup the code from previous example should work, we are setting up a timer, to take readings every 10 ms, and cancelling the alarm after 5 seconds:
              measurement = [] #array
              #method for alarm callback
              def sample():
                  acc_val = acc.acceleration()
                  measurement.append(acc_val)
              alarm = Timer.Alarm(lambda x: sample(), ms = 10, periodic = True)
              time.sleep(5)
              alarm.cancel()
              Then you just add these lines right after the sleep, Hope it helps!
                @railmonitor Thanks !
                But with method, I have to listen the accelerometer even if it doesn't measure any accelerations. I think it will consume a lot of current for nothing.
                If it's possible I'd like to wake up only when the board is shocked (by a high acceleration) and store this acceleration in a file.
                • R Offline
                  @CeylordZ You could encapsule the whole reading sequence in a loop:
                  if acc.activity():
                           Read, append etc..
                    CeylordZ
                    But if I'm using a loop where I read the acceleration, I can't sleep the board, am I wrong ?
                    And what is the "append" function ?
                      jcaron @railmonitor
                      @railmonitor The code you posted above is actually missing the actual "deep sleep" part...
                      @CeylordZ If you want the actual acceleration value, I don't think you'll be able to use deep sleep with that. The accelerometer will wake up the LoPy, but by the time the LoPy has woken up and is ready to query the accelerometer, values will have changed. I don't think there's any way to tell the accelerometer to "keep" the value that caused the wake up, though you should check the chip's data sheet and application notes, there may be something in there.
                      IIRC the accelerometer has a buffer used to deliver data to the LoPy, but even at the lowest data rate I don't think it's large enough to last for the wake up time.
                      If you want the full data, you'll have to keep the LoPy awake, which will indeed use quite a bit of power.
                      What is your actual use case?
                      R C 2 Replies Last reply Reply Quote 0
                      • R Offline
                        railmonitor @jcaron
                        @jcaron Correct, i am using machine.sleep() which is the lightsleep mode, because, as you state, wakeup from deepsleep is rather slow due to boot time etc.. and not feasible if you want to wake and take measurements immediately.
                        @CeylordZ It's not really a loop in the traditional sense, you are just telling it to do your readings when there is activity on the accelerometer.
                          CeylordZ @jcaron
                          @jcaron It's problematic, My project would be to put the lopy-pytrack in a case and to let it sleep until it detect a high shock, at this moment it will send the data (with the intensity of the shock) in LoRa then it will go to sleep again until the next wake-up.
                          But it will impossible to recharge the Lipo battery before 2-3 months so, it's necessary that the lopy consume as little as possible.
                          @railmonitor how does the machine.sleep() works compared to the deepsleep ?
                          I know that the deep sleep almost shut down the processor and restart the board when it's waking up but not the machine.sleep()
                          • R Offline
                            @CeylordZ Have a look here:
                            https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/system/sleep_modes.html
                              jcaron @railmonitor
                              @CeylordZ What kind of battery are you planning to use? To last 2 months with, say, a 2500 mAh battery, you need to draw an average of 1.75 mA or less. Light sleep supposedly gets you down to 3.5 mA, but:
                              • it should be checked in actual conditions, with the accelerometer enabled in the right mode, etc.
                              • you have to consider that whenever it wakes up and sends stuff over LoRa, it will draw a lot more, so this will raise your average. Depending on how frequently you wake up and how long you do, this could increase your average just a tiny bit or a a whole lot.
                              • I'd be curious to see how light sleep and LoRa combine. Last time I looked into it (it was a while ago, though), as soon as LoRa is configured, it'll have a 1 kHz polling loop set up which will kill light sleep performance.
                              So either you'll have to pack a larger battery (> 5000 mAh, probably more, which becomes quite a large thing), or light sleep won't do. But deep sleep probably won't let you get the value of the acceleration that triggered the wake up. Again, I recommend you check the accelerometer's data sheet and application notes, it might actually be possible with correct configuration of the chip.
                              An alternative might be to use the ULP co-processor, but AFAIK using this on the Pycom modules is still work in progress.
                                CeylordZ @jcaron
                                  CeylordZ @jcaron
                                  @jcaron For now I received a 2000 mAh battery but it's only for testing I know it won't be enough for my application.
                                  I will study the possibility to use the ULP co-processor, maybe it is the only way for me to achieve my project, I'll check the LIS2HH12's datasheet in details, maybe there is something interesting I didn't see.
                                  Something I don't understand is the machine.sleep(), when I use it, the program stop working during the time of the sleep then it wake up and execute the rest of the program so I'm not able to let it do something during the machine.sleep.
                                  Furthermore, with @railmonitor's code, interruptions works only with the button but not with the accelerometer, I don't know why...
                                  And during the lightsleep, when I push the putton, the wake-up reason is (0,none)
                                    jcaron @CeylordZ
                                    @CeylordZ I've never used light sleep, so I don't really know how it interacts with the rest (i.e. if machine.pin_sleep_wakeup actually affects getting out of light sleep or not).
                                    BTW, going very very quickly through the pin_sleep_wakeup source and the Espressif docs, I believe the code from @railmonitor above has an issue: it seems to me that each call to pin_sleep_wakeup will "replace" all previous settings, so you need to have all pins in the array in the same call, and they should all use the same mode.
                                    I did not actually check or test it, but that's my understanding from a quick glance through the code and docs.
                                    As for the wakeup reason, another quick glance through the source also makes me think it is only initialised (in the firmware) during the boot process, so only after a deep sleep, not a light sleep. This one should be easily fixable in the firmware (adding another separate call I would think, there's probably a reason the value is stored rather than returned directly from the ESP-IDF in the current function).
                                    J 1 Reply Last reply Reply Quote 2
                                      johnmcdnz @jcaron
                                      @jcaron @CeylordZ
                                      I think I agree with your analysis that the call to machine.pin_sleep_wakeup overwrites previous settings.
                                      I'm experimenting also using the example code of the accelerometer.
                                      As provided, the code reliably wakes on button press. But doesn't wake on movement.
                                      If the line for setting up the wakeup for the button P13 is removed. the accellerometer does now wake up!
                                      I'm continuing to work on this and if/when I get reliable code I'll post it.
                                      F 1 Reply Last reply Reply Quote 0
                                      • F Offline
                                        Flavio Frattini @johnmcdnz
                                        @johnmcdnz Hi, have you achieved any progress with the accelerometer?
                                          johnmcdnz @Flavio Frattini
                                          @Flavio-Frattini Yes I did (sorry for delay in replying)
                                          as said before the code should only call machine.pin_sleep_wakeup once with the setup. Therefore it can either be used to wakeup with the button or the accellerometer, but can't use both.
                                          #Enable interrupts from accelerometer (P13) and button (P14)  JMCD:  bug report, only use one of these lines, subsequent calls overwrite earlier setup
                                          # enable activity and disable inactivity interrupts, using the default callback handler
                                          py.setup_int_wake_up(True, False)
                                          # set the acceleration threshold to 500mG (0.5G) and the min duration to 200ms
                                          acc.enable_activity_interrupt(500, 200)
                                          • B Offline
                                            Bryan Hom
                                            @johnmcdnz
                                            Any chance that you got further with this code and are willing to share?
                                            • 1
                                            • 2
                                            • 1 / 2
