How to wake up the lopy with the accelerometer
@railmonitor And is it possible to store the data from the accelerator when it wake up ? Or I have to keep it awake if I want to measure the acceleration ?
I want to know how strong is the acceleration when it wake up the board (2g, 4g or 8g for example...).
@railmonitor that's what I looked for, thank you !
Yes, that is definitly possible. Have a look a the following code, it is written for FiPy with Pysense board, so there might be some differences regarding libraries / pins but should work when corrected:
from pysense import Pysense from LIS2HH12 import LIS2HH12 import pycom import time import machine py = Pysense() #Create Pysense object acc = LIS2HH12() #Create accelerometer object if pycom.heartbeat() == True: #turn off blinking LED pycom.heartbeat(False) wakeup_reason = machine.wake_reason() #Enable interrupts from accelerometer (P13) and button (P14) machine.pin_sleep_wakeup(['P13'], mode=machine.WAKEUP_ANY_HIGH, enable_pull = False) machine.pin_sleep_wakeup(['P14'], mode=machine.WAKEUP_ALL_LOW, enable_pull = False) # set the acceleration threshold to 2000mG (2G) and the min duration to 200ms acc.enable_activity_interrupt(2000, 160) if(wakeup_reason == machine.PIN_WAKE): pycom.rgbled(0xffff00) #yellow time.sleep(2) print("Turning on Red LED for 2 sec") pycom.rgbled(0xff0000) #red time.sleep(2) print("Enter lightsleep mode for 5 sec") machine.sleep(5000) #Value in ms print("Pysense Wakeup reason is " + str(wakeup_reason)) if acc.activity(): pycom.rgbled(0x800080) #purple else: pycom.rgbled(0x0000ff) #blue
