    UART connexion failled
    22 Posts 4 Posters 491 Views 4 Watching
    • Q Offline
      quentho
      It will soon be a year and a half that I use my sipy in UART connection via USB by means of an FTDI. I have never had a problem with it. Since the update of Atome and Pymakr I can't get the prompt. I tried with a new sipy and it does not work. I also tried with different FTDI but I had the same results. But when I use a pysense it works. I have updated the latest firmware for sipy cards.
      My question is did someone experience the same problem and if not do you have any suggestions on how to resolve it.
      you can see the Electrical wiring on the picture
      Thank you in advance and good day to you.!89211857_635942097199263_3804664605561585664_n-ConvertImage.jpg
        thibault
        The Vin of the SIPY need voltage >= 3.5 volt isn't it? On your picture it seems you give 3.3 volt. Are you sure that the sipy was started? You got wifi connection?
          robert-hh @quentho
          @quentho ddi you try to use a simple terminal emulator like Putty or screen or picocom as crosscheck for the UART connection? After updates of Atom or VSC, pymakr sometimes stumbles.
          @thibault I tested at least a LoPy with lower input voltages. It worked fine down to 2.8V. Below 3.5V, the regulator switches to bypass mode, resulting at ~3.2V on the board. The ESP32 works fine down to 2.3V. The Sigfox/Lora chip may not work that far down, but 3.2V should be OK.
          T Q robert-hhR 3 Replies Last reply Reply Quote 0
            thibault @robert-hh
            @robert-hh nice tip thank's for this information
            • Q Offline
              quentho @robert-hh
              @robert-hh said in UART connexion failled:
              crosscheck
              Thank for the answer. I can see my board connected but i can't have the prompt.
              I will use putty, it is the putty connection good ? because i can't open
                thibault @quentho
                @quentho don't hesitate to check this page: https://docs.pycom.io/gettingstarted/programming/repl/serial/
                The baudrate was (by default) 115200 so i think is that your problem. (maybe you need to remove the flow control too)
                Q 1 Reply Last reply Reply Quote 0
                • Q Offline
                  quentho @thibault
                  @thibault
                  i try with 115200 , with and without flow control but i always have :
                    robert-hh @robert-hh
                    @robert-hh the baud rate is 115200, and you have to turn off flow control.
                      robert-hh @quentho
                      @quentho close atom.
                        robert-hh @quentho
                        @quentho you can check whether it is COM12 in the device manager. The device should appear and disappear when you plug and unplug the FTDI board.
                        • Q Offline
                          quentho @robert-hh
                          @robert-hh i did what you said but i always have the seem result.
                          Unable to open connection to COM12
                            robert-hh @quentho
                            @quentho Are you sure that COM12 exists and is the proper port? Putty will not tell you.
                            • Q Offline
                              quentho @robert-hh
                              @robert-hh
                              i see the connection on putty but i haven't the prompt.
                              I had install the FTDI driver but it's not working.
                              i chaned the sipy , the ftdi , the wire but it's not working.
                              when i connect with a pysense or pytrack it's working. I don't understand...
                                robert-hh @quentho
                                @quentho A few things to check:
                                • Please ensure, that the flow control setting of putty is disabled.
                                • Try to swap RX and TX
                                • Windows assigns COMxx numbers based on the USB ID. So if Pysense uses COM12, the FTDI will most probably be assigned to a different COMxx number. Open the device manage in Windows, section COM ports, and look, which COM ports are active, when the FTDI is connected. It shoul disappear when you disconnect the FTDI adapter.
                                • Q Offline
                                  quentho @robert-hh
                                  @robert-hh
                                  "Please ensure, that the flow control setting of putty is disabled."
                                  When i disconnect and reconnect my sipy, the flow controle set at XOn/XOFF. The speed is 9600. But after i change to none and 115200 for the speed bhut it's not working.
                                  "Try to swap RX and TX"
                                  i did both each time.
                                  "Windows assigns COMxx numbers based on the USB ID. So if Pysense uses COM12, the FTDI will most probably be assigned to a different COMxx number. Open the device manage in Windows, section COM ports, and look, which COM ports are active, when the FTDI is connected. It shoul disappear when you disconnect the FTDI adapter."
                                  i had check this one and it's on the good port. My bord is connected but i don't have the prompt . sometimes I have strange characters parading
                                    robert-hh @quentho
                                    @quentho Strange characters are a sign of wrong baud rate. What happens if you are connected with 115200 baud and push reset on the SiPy?
                                    As terminal emulator you may also try TeraTerm. TeraTerm remembers the recent setting ant lets you only use active COM ports.
                                    Edit: You can also start Putty from the command line, specifying Port and speed, e.g.:
                                    putty -serial COM12 115200
                                    • Q Offline
                                      quentho @robert-hh
                                      @robert-hh
                                      i have a prompt but in can't write inside. And i can't run or download!!
                                        robert-hh @quentho
                                        @quentho that looks like a flow control issue, or a problem with the wire into RX of the sipy.
                                        • Q Offline
                                          quentho @robert-hh
                                          I had chane rx to tx , i set the bit flow controle with tera term and i had change my sipy and it's working thank you for your time !
                                            robert-hh @quentho
                                            @quentho That is good. Just to add some more information for those who are in a similar situation: with Putty you can also specify all settings on the command line, e.g.:
                                            putty -serial COM12 -sercfg 115200,8,1,n,N
                                            And I faintly recall, that one of either Putty or TeraTerm is using it's own drivers. So it may still be a driver problem.
                                            • 1
                                            • 2
                                            • 1 / 2
