<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to provision Sigfox]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have recently acquired a Fipy and a expansion board 3.0. I have finally managed to provision the device using IOS Pybytes app.</p>
<p dir="auto">After that, my device has no Sigfox ID:</p>
<pre><code>(sysname='FiPy', nodename='FiPy', release='1.20.2.rc6', version='v1.11-01f49f7 on 2020-02-28', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.3.1')
sigfox id:
b'ffffffff'
sigfox pac:
b'ffffffffffffffff'
</code></pre>
<p dir="auto">I have tried to do the provision using Atom and I get the following message:</p>
<pre><code>Wifi connection established... activating device!
Unable to provision Sigfox! Please try again.
Activation failed!
</code></pre>
<p dir="auto">I there something I should do in order to activate Sigfox?</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.pycom.io/topic/5784/unable-to-provision-sigfox</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 17:45:33 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/5784.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Mar 2020 14:44:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to provision Sigfox on Wed, 11 Mar 2020 14:44:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
sigfox id:
b'ffffffff'
sigfox pac:
b'ffffffffffffffff'
</code></pre>
Activation failed!
</code></pre>
]]></description><link>https://forum.pycom.io/post/32058</link><guid isPermaLink="true">https://forum.pycom.io/post/32058</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Wed, 11 Mar 2020 14:44:45 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Thu, 12 Mar 2020 15:31:07 GMT]]></title><description><![CDATA[<p dir="auto">I'm having the same issue and I have no clue what's going on.</p>
<p dir="auto">Curious though what you get if you do the following:</p>
<ol>
<li>Add the device in Pybytes via USB and only enable WiFi.</li>
<li>Connect the device to Pymakr, connect to the WiFi you specified in step 1 and set <code>pybytes_debug</code> to 99 using following command:</li>
</ol>
<pre><code>import pycom
pycom.nvs_set('pybytes_debug', 99)
</code></pre>
<ol>
<li>Then trying to do the provisioning over wifi according to the instructions under <strong>&quot;Activate your device with Pymakr plugin&quot;</strong> in the provisioning tab?</li>
</ol>
<p dir="auto">I keep getting a response saying:</p>
<pre><code>/v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
</code></pre>
<p dir="auto">Are you able to update the firmware using Pycom Update-tool?</p>
]]></description><link>https://forum.pycom.io/post/32084</link><guid isPermaLink="true">https://forum.pycom.io/post/32084</guid><dc:creator><![CDATA[amkrup]]></dc:creator><pubDate>Thu, 12 Mar 2020 15:31:07 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Thu, 12 Mar 2020 19:45:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5920">@amkrup</a> said in <a href="/post/32084">Unable to provision Sigfox</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">No. It said that it couldn’t connect with the device or something like that. I had to do it manually or with Pybytes IOS app.</p>
<p dir="auto">At least I’m not alone.</p>
]]></description><link>https://forum.pycom.io/post/32091</link><guid isPermaLink="true">https://forum.pycom.io/post/32091</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Thu, 12 Mar 2020 19:45:55 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Sun, 15 Mar 2020 16:42:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5920">@amkrup</a> , any progress?</p>
]]></description><link>https://forum.pycom.io/post/32121</link><guid isPermaLink="true">https://forum.pycom.io/post/32121</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Sun, 15 Mar 2020 16:42:16 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Mon, 16 Mar 2020 16:03:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5918">@juse</a> I contacted PyCom today and had them escalate my ticket that I created last week. Will get back to you as soon as I have more info.</p>
]]></description><link>https://forum.pycom.io/post/32140</link><guid isPermaLink="true">https://forum.pycom.io/post/32140</guid><dc:creator><![CDATA[amkrup]]></dc:creator><pubDate>Mon, 16 Mar 2020 16:03:05 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Wed, 18 Mar 2020 08:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5920">@amkrup</a> Now it is working for me.</p>
]]></description><link>https://forum.pycom.io/post/32175</link><guid isPermaLink="true">https://forum.pycom.io/post/32175</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Wed, 18 Mar 2020 08:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to provision Sigfox on Wed, 18 Mar 2020 10:02:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5918">@juse</a> Same here! Guess the folks at Pycom corrected the issue with the device registration.</p>
]]></description><link>https://forum.pycom.io/post/32177</link><guid isPermaLink="true">https://forum.pycom.io/post/32177</guid><dc:creator><![CDATA[amkrup]]></dc:creator><pubDate>Wed, 18 Mar 2020 10:02:39 GMT</pubDate></item></channel></rss>
