<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot;]]></title><description><![CDATA[<p dir="auto">I've been trying to register my device so that I can use SigFox. Tried registering using Pycom Firmware Updater, PyBytes app and also tried to provision the device via USB  running the <code>pybytes.activate()</code>-function.</p>
<p dir="auto">I although keep getting following error message when entering the activation token that I have in PyBytes:</p>
<pre><code>pybytes.activate(&quot;{MY_SUPERLONG_ACTIVATION_GOES_HERE}&quot;)
Disconnecting current connection!
self.__connection_status=0 | self.__network_type=None
Already disconnected
{'a': '{ID}', 'p': '{WLAN_PWD}', 's': '{WLAN_SSID}'}
performing Wi-Fi activation
Please wait while we try to connect to {WLAN_SSID}
WLAN connected? True
Wifi connection established... activating device!
Activation response:
{'mqttServiceAddress': 'mqtt.pybytes.pycom.io', 'userId': '{USER_ID}', 'network_preferences': 'wifi', 'wifi': {'ssid': '{WIFI_SSID}', 'password': '{WIFI_PWD'}, 'deviceToken': '{DEVICE_TOKEN}'}
sigfox_registration: {'activationToken': '{ACTIVATION_TOKEN}', 'wmac': b'{WMAC}', 'smac': b'{SMAC}'}
/v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
</code></pre>
<p dir="auto">PS. <code>{}</code>-field have real values in the real response.</p>
<p dir="auto">The <code>/v2/register-sigfox </code>-endpoint, is that a Pybyte/Pycom endpoint or SigFox? And what other arguments are supposed to be supplied?</p>
<p dir="auto">My FiPy device is currently running <code>'1.20.2.rc3'</code> but I've tried the same procedure after flashing <code>FiPy-1.20.2.rc6.tar</code> with the same result. Pycom Firmware updater only works using &quot;Flash from local file&quot; due to the update failing and showing an error message saying &quot;Could not connect to the board&quot; using following settings:</p>
<p dir="auto"><img src="/assets/uploads/files/1584023955967-f9d7083c-d63d-4abb-8c4e-d070ab3feb23-image.png" alt="f9d7083c-d63d-4abb-8c4e-d070ab3feb23-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">Result:</p>
<p dir="auto"><img src="/assets/uploads/files/1584024060413-d0ebb710-5f8f-444a-9f67-47709357956b-image.png" alt="d0ebb710-5f8f-444a-9f67-47709357956b-image.png" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/topic/5788/solved-v2-register-sigfox-returning-response-registersigfoxdevice-is-missing-some-arguments</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 11:55:32 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/5788.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Mar 2020 14:41:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Wed, 18 Mar 2020 11:13:28 GMT]]></title><description><![CDATA[<p dir="auto">I've been trying to register my device so that I can use SigFox. Tried registering using Pycom Firmware Updater, PyBytes app and also tried to provision the device via USB  running the <code>pybytes.activate()</code>-function.</p>
</code></pre>
]]></description><link>https://forum.pycom.io/post/32083</link><guid isPermaLink="true">https://forum.pycom.io/post/32083</guid><dc:creator><![CDATA[amkrup]]></dc:creator><pubDate>Wed, 18 Mar 2020 11:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Mon, 16 Mar 2020 10:00:53 GMT]]></title><description><![CDATA[<p dir="auto">Exact same problem here with a FiPy</p>
]]></description><link>https://forum.pycom.io/post/32128</link><guid isPermaLink="true">https://forum.pycom.io/post/32128</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Mon, 16 Mar 2020 10:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Tue, 17 Mar 2020 15:37:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi, thanks for reporting this. We'll take a look</p>
]]></description><link>https://forum.pycom.io/post/32157</link><guid isPermaLink="true">https://forum.pycom.io/post/32157</guid><dc:creator><![CDATA[jirkakrepl]]></dc:creator><pubDate>Tue, 17 Mar 2020 15:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Wed, 18 Mar 2020 07:26:13 GMT]]></title><description><![CDATA[<p dir="auto">Now is working for me. I got a Sigfox ID and PAC</p>
]]></description><link>https://forum.pycom.io/post/32171</link><guid isPermaLink="true">https://forum.pycom.io/post/32171</guid><dc:creator><![CDATA[juse]]></dc:creator><pubDate>Wed, 18 Mar 2020 07:26:13 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Wed, 18 Mar 2020 11:13:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2077">@jirkakrepl</a> Got my FiPy working now. Thanks!</p>
]]></description><link>https://forum.pycom.io/post/32178</link><guid isPermaLink="true">https://forum.pycom.io/post/32178</guid><dc:creator><![CDATA[amkrup]]></dc:creator><pubDate>Wed, 18 Mar 2020 11:13:01 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] &#x2F;v2&#x2F;register-sigfox returning response: &quot;registerSigfoxDevice is missing some arguments&quot; on Tue, 31 May 2022 16:22:26 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm trying to provision my new FiPy devices, and I get exactly the same error:</p>
<pre><code>[         70.320] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
[         89.743] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
[        109.000] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
[        127.997] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
[        147.543] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments
Unable to provision Sigfox! Please try again.
Activation failed!
</code></pre>
<p dir="auto">I'm not using Sigfox nor Lora for the moment.<br />
Can you help me register correctly my devices on PyBytes?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.pycom.io/post/40401</link><guid isPermaLink="true">https://forum.pycom.io/post/40401</guid><dc:creator><![CDATA[Louis CONVERT]]></dc:creator><pubDate>Tue, 31 May 2022 16:22:26 GMT</pubDate></item></channel></rss>
