<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LTE-M Telenor]]></title><description><![CDATA[<p dir="auto">Hi, setting up LTE M for band 20 in Sweden, does work with Telia, but not Telenor. Telenor has support for LTE-CAT M1 but no success. Have tested both Telenor Norways code and the standard Pycom approach. No success, the operator don´t even se that the SIMs have tested to connect. Thoughts?</p>
]]></description><link>https://forum.pycom.io/topic/5793/lte-m-telenor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 03:38:58 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/5793.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Mar 2020 10:33:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LTE-M Telenor on Fri, 13 Mar 2020 10:33:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi, setting up LTE M for band 20 in Sweden, does work with Telia, but not Telenor. Telenor has support for LTE-CAT M1 but no success. Have tested both Telenor Norways code and the standard Pycom approach. No success, the operator don´t even se that the SIMs have tested to connect. Thoughts?</p>
]]></description><link>https://forum.pycom.io/post/32096</link><guid isPermaLink="true">https://forum.pycom.io/post/32096</guid><dc:creator><![CDATA[Don-iot]]></dc:creator><pubDate>Fri, 13 Mar 2020 10:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to LTE-M Telenor on Wed, 27 May 2020 14:55:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5629">@Don-iot</a> i did not know that telia enabled lte-m. that is really interesting!</p>
]]></description><link>https://forum.pycom.io/post/32871</link><guid isPermaLink="true">https://forum.pycom.io/post/32871</guid><dc:creator><![CDATA[aen]]></dc:creator><pubDate>Wed, 27 May 2020 14:55:18 GMT</pubDate></item><item><title><![CDATA[Reply to LTE-M Telenor on Wed, 27 May 2020 18:08:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3390">@aen</a> At least in Sweden we have tested both LTE-M and NB-IoT with Telia quite a lot. Telenor runs LTE-M as well, I have tested that a lot as well and Tre has the NB-IoT in place. That one I am still trying to test, for some reason the NB-IoT firmware available for GPy is not available from the firmware I am using, so I am stuck at the moment, and have been for some time now. What networks have you tested?</p>
]]></description><link>https://forum.pycom.io/post/32876</link><guid isPermaLink="true">https://forum.pycom.io/post/32876</guid><dc:creator><![CDATA[Don-iot]]></dc:creator><pubDate>Wed, 27 May 2020 18:08:59 GMT</pubDate></item></channel></rss>
