LoPy4 always throws the same exception every time it starts nanogateway.py (although it doesn't break the logic)
  • Hi,
    I am using my LoPy4 as a simple LoRaWAN gateway based on the nanogateway.py pycom lib.
    Every time my gateway starts it throws the following exception:
    Unhandled exception in thread started by <bound_method>
      File "_pybytes_config.py", line 50, in smart_config
    TypeError: unsupported types for __add__: 'bytes', 'NoneType'
    Although this exception doesn't break the gateway logic and everything seems to work fine, I am wondering if it's possible to fix that somehow and if there are any hidden problems. Would appreciate if you could suggest any solutions to that issue.
    Thanks!
  • Banned
    i'm having a dou't wether we will use lopy4 as a access factor or can we use this as a wifi hub that may be connect to computer after which can it's used as a usb dongle
