<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mapping G and P pin numbers]]></title><description><![CDATA[<p dir="auto">I have a hard time mapping the P numbers of the LoPy to the G numbers on the expansion board. The LoPy pinout sheet (PDF) only talks about the P numbers, but there seems to be no mentioning about the G numbers (or I am blind). Where can I find a mapping between these two different pin numbering schemes?</p>
]]></description><link>https://forum.pycom.io/topic/606/mapping-g-and-p-pin-numbers</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 17:07:35 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/606.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Feb 2017 14:08:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mapping G and P pin numbers on Sun, 05 Feb 2017 14:08:38 GMT]]></title><description><![CDATA[<p dir="auto">I have a hard time mapping the P numbers of the LoPy to the G numbers on the expansion board. The LoPy pinout sheet (PDF) only talks about the P numbers, but there seems to be no mentioning about the G numbers (or I am blind). Where can I find a mapping between these two different pin numbering schemes?</p>
]]></description><link>https://forum.pycom.io/post/3772</link><guid isPermaLink="true">https://forum.pycom.io/post/3772</guid><dc:creator><![CDATA[tobru]]></dc:creator><pubDate>Sun, 05 Feb 2017 14:08:38 GMT</pubDate></item><item><title><![CDATA[Reply to Mapping G and P pin numbers on Sun, 05 Feb 2017 21:47:52 GMT]]></title><description><![CDATA[<p dir="auto">This should help you (made from LoPy and EB pinout sheets'):</p>
<pre><code>	LED/USB
RST		5V
P0 - G2		GND
P1 - G1		3,3V
P2 - G23	P23 - G10
P3 - G24	P22 - G9
P4 - G11	P21 - G8
CLK - G12	P20 - G7
MOSI - G13	P19 - G6
MISO - G14	P18 - G30
P8 - G15	P17 - G31
P9 - G16	P16 - G3
P10 - G17	P15 - G0
P11 - G22	P14 - G4
P12 - G28	P13 - G5
</code></pre>
<p dir="auto">Also read this <a href="https://forum.pycom.io/topic/242/expansion-board-pin-numbers-vs-lopy-pin-numbers/5">https://forum.pycom.io/topic/242/expansion-board-pin-numbers-vs-lopy-pin-numbers/5</a></p>
]]></description><link>https://forum.pycom.io/post/3786</link><guid isPermaLink="true">https://forum.pycom.io/post/3786</guid><dc:creator><![CDATA[rskoniec]]></dc:creator><pubDate>Sun, 05 Feb 2017 21:47:52 GMT</pubDate></item><item><title><![CDATA[Reply to Mapping G and P pin numbers on Mon, 06 Feb 2017 20:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/360">@rskoniec</a> Great! Thanks a lot</p>
]]></description><link>https://forum.pycom.io/post/3822</link><guid isPermaLink="true">https://forum.pycom.io/post/3822</guid><dc:creator><![CDATA[tobru]]></dc:creator><pubDate>Mon, 06 Feb 2017 20:14:35 GMT</pubDate></item></channel></rss>
