<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’?]]></title><description><![CDATA[<p dir="auto">when i use ssl module, how can i take the file 'ca.pem' to '/flash/cert/' ?</p>
]]></description><link>https://forum.pycom.io/topic/628/how-to-take-the-file-ca-pem-to-flash-cert</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 05:28:34 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/628.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Feb 2017 09:12:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Wed, 08 Feb 2017 09:12:52 GMT]]></title><description><![CDATA[<p dir="auto">when i use ssl module, how can i take the file 'ca.pem' to '/flash/cert/' ?</p>
]]></description><link>https://forum.pycom.io/post/3888</link><guid isPermaLink="true">https://forum.pycom.io/post/3888</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Wed, 08 Feb 2017 09:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Wed, 08 Feb 2017 10:25:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a><br />
connect to it by ftp (wifi) and put file there<br />
default ip is 192.168.4.1 user micro password python</p>
]]></description><link>https://forum.pycom.io/post/3891</link><guid isPermaLink="true">https://forum.pycom.io/post/3891</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Wed, 08 Feb 2017 10:25:26 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Fri, 10 Feb 2017 01:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a> Thanks for your explain, as your method i can view '/flash/' ,but can't write file to it.</p>
]]></description><link>https://forum.pycom.io/post/3948</link><guid isPermaLink="true">https://forum.pycom.io/post/3948</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Fri, 10 Feb 2017 01:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Fri, 10 Feb 2017 07:01:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a><br />
Which tool do you use for ftp? And do you got some error when you put file?<br />
In current firmware i have some problems with ftp stability<br />
but i can put file by e.g. Filezilla</p>
]]></description><link>https://forum.pycom.io/post/3949</link><guid isPermaLink="true">https://forum.pycom.io/post/3949</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Fri, 10 Feb 2017 07:01:39 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 14 Feb 2017 06:58:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
I used 'freshftp' before, i can see the flash directory by this tool, but can't write file to flash.<br />
then i used 'Filezilla', an error come out :&quot;GnuTLS error -15: An unexpected TLS packet was received&quot;<br />
is there any settings required?</p>
]]></description><link>https://forum.pycom.io/post/4075</link><guid isPermaLink="true">https://forum.pycom.io/post/4075</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Tue, 14 Feb 2017 06:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 14 Feb 2017 07:46:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a><br />
look here - go to Filezilla section<br />
<a href="https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html?highlight=filezilla" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html?highlight=filezilla</a></p>
]]></description><link>https://forum.pycom.io/post/4076</link><guid isPermaLink="true">https://forum.pycom.io/post/4076</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 14 Feb 2017 07:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 14 Feb 2017 08:53:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
Thank you! It works now.</p>
]]></description><link>https://forum.pycom.io/post/4077</link><guid isPermaLink="true">https://forum.pycom.io/post/4077</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Tue, 14 Feb 2017 08:53:42 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Mon, 27 Feb 2017 02:51:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
Is the ssl module OK? did you use it successful?<br />
there aways output an OSError:-9984</p>
]]></description><link>https://forum.pycom.io/post/4623</link><guid isPermaLink="true">https://forum.pycom.io/post/4623</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Mon, 27 Feb 2017 02:51:41 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Mon, 27 Feb 2017 07:07:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a> said in <a href="/post/4623">How to take the file 'ca.pem' to ‘/flash/cert/’?</a>:</p>
<blockquote>
<p dir="auto">ssl</p>
</blockquote>
<p dir="auto">No, i did not used it. But you can see on the forum that few person use it succesfully.<br />
What version of firmware do you have?</p>
<pre><code>os.uname()
</code></pre>
]]></description><link>https://forum.pycom.io/post/4627</link><guid isPermaLink="true">https://forum.pycom.io/post/4627</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Mon, 27 Feb 2017 07:07:09 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Mon, 27 Feb 2017 10:09:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
<img src="/uploads/files/1488190089256-upload-a6582b95-ec60-46e5-83bd-993c88ab23ef-resized.png" alt="0_1488190087923_upload-a6582b95-ec60-46e5-83bd-993c88ab23ef" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/4653</link><guid isPermaLink="true">https://forum.pycom.io/post/4653</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Mon, 27 Feb 2017 10:09:08 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Mon, 27 Feb 2017 10:25:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a><br />
could you show some sample code?<br />
it is something near this?<br />
<a href="https://docs.pycom.io/pycom_esp32/library/ussl.html" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/pycom_esp32/library/ussl.html</a></p>
<pre><code>import socket
import ssl
s = socket.socket()
ss = ssl.wrap_socket(s, cert_reqs=ssl.CERT_REQUIRED, ca_certs='/flash/cert/ca.pem')
ss.connect(socket.getaddrinfo('cloud.blynk.cc', 8441)[0][-1])
</code></pre>
]]></description><link>https://forum.pycom.io/post/4655</link><guid isPermaLink="true">https://forum.pycom.io/post/4655</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Mon, 27 Feb 2017 10:25:55 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 28 Feb 2017 04:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
This is my ssl code.and WiFi is connect.<br />
s = socket.socket()<br />
#s = socket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_TCP)<br />
ss = ssl.wrap_socket(s, cert_reqs=ssl.CERT_REQUIRED, ca_certs='/flash/cert/client.pem')<br />
ss.connect(socket.getaddrinfo('192.168.119.38', 43416)[0][-1])</p>
]]></description><link>https://forum.pycom.io/post/4692</link><guid isPermaLink="true">https://forum.pycom.io/post/4692</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Tue, 28 Feb 2017 04:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 28 Feb 2017 04:15:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a><br />
only socket is OK.<br />
s.connect(socket.getaddrinfo('192.168.119.38', 43414)[0][-1])</p>
<p dir="auto">By the way ,how to add my code with black backcolor?</p>
]]></description><link>https://forum.pycom.io/post/4693</link><guid isPermaLink="true">https://forum.pycom.io/post/4693</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Tue, 28 Feb 2017 04:15:34 GMT</pubDate></item><item><title><![CDATA[Reply to How to take the file &#x27;ca.pem&#x27; to  ‘&#x2F;flash&#x2F;cert&#x2F;’? on Tue, 28 Feb 2017 07:06:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/572">@DongYin</a> said in <a href="/post/4693">How to take the file 'ca.pem' to ‘/flash/cert/’?</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">look here <a href="http://commonmark.org/help/" target="_blank" rel="noopener noreferrer nofollow">http://commonmark.org/help/</a></p>
]]></description><link>https://forum.pycom.io/post/4696</link><guid isPermaLink="true">https://forum.pycom.io/post/4696</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 28 Feb 2017 07:06:14 GMT</pubDate></item></channel></rss>
