Wi-Fi works on Lopy4 not on Fipy
  • I am trying to use the Wi-Fi feature on the Fipy. I am running the given example:
    import network
    # setup as a station
    wlan = network.WLAN(mode=network.WLAN.STA)
    wlan.connect('your-ssid', auth=(network.WLAN.WPA2, 'your-key'))
    while not wlan.isconnected():
        time.sleep_ms(50)
    print(wlan.ifconfig())
    When I run this code on the Lopy4 (with my own ssid and key), it connects successfully. However, when I run the exact same code on the Fipy, I get the message: OSError: the requested operation failed. I also made sure the LTE was both unattached and disconnected before trying to setup the Wi-Fi.
    If it's relevant, the current firmware on the Fipy is version 1.20.0.rc13
    Does anyone know why it's failing?
