<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FiPy LTE-M Amazon AWS-IoT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a FiPy which is working OK with LTE-M in the UK in that I have managed to successfully do an http get request on a webpage. I have also managed to get a GPS location from the attached pytrack 2.0 board.</p>
<p dir="auto">What I would like to do now is send the location information over LTE-M to Amazon AWS (preferably AWS IoT but if not that then S3).</p>
<p dir="auto">From reading around it seems I can use either http or mqtt to achieve this.</p>
<p dir="auto">Can anyone point me to some instructions or some code to get this up and running on my FiPy?</p>
<p dir="auto">Many thanks for any help you can offer.</p>
]]></description><link>https://forum.pycom.io/topic/6712/fipy-lte-m-amazon-aws-iot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 07:09:58 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/6712.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jan 2021 15:40:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FiPy LTE-M Amazon AWS-IoT on Mon, 04 Jan 2021 15:40:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
]]></description><link>https://forum.pycom.io/post/36300</link><guid isPermaLink="true">https://forum.pycom.io/post/36300</guid><dc:creator><![CDATA[Andrew Long]]></dc:creator><pubDate>Mon, 04 Jan 2021 15:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to FiPy LTE-M Amazon AWS-IoT on Mon, 04 Jan 2021 16:35:57 GMT]]></title><description><![CDATA[<p dir="auto">I've made a bit of progress, and found this: <a href="https://docs.pycom.io/tutorials/networkprotocols/aws/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/tutorials/networkprotocols/aws/</a></p>
<p dir="auto">The aws webpage has changed significantly since the instructions were written, but I think I've managed to do everything asked for.</p>
<p dir="auto">BUT... I'm stuck where it says:</p>
<p dir="auto"><code>&quot;Connect to the device via FTP and put the root CA certificate, the client certificate (*.pem.crt) and the private key (*.private.pem.key) in the /flash/cert folder.&quot;</code></p>
<p dir="auto">Where do I get the root CA certificate from? (I got the client certificate and the private key during the previous steps, but no root CA certificate that I can see)</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.pycom.io/post/36301</link><guid isPermaLink="true">https://forum.pycom.io/post/36301</guid><dc:creator><![CDATA[Andrew Long]]></dc:creator><pubDate>Mon, 04 Jan 2021 16:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to FiPy LTE-M Amazon AWS-IoT on Thu, 07 Jan 2021 09:27:01 GMT]]></title><description><![CDATA[<p dir="auto">Can anyone help me find the Root CA Certificate?</p>
]]></description><link>https://forum.pycom.io/post/36342</link><guid isPermaLink="true">https://forum.pycom.io/post/36342</guid><dc:creator><![CDATA[Andrew Long]]></dc:creator><pubDate>Thu, 07 Jan 2021 09:27:01 GMT</pubDate></item></channel></rss>
