<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I recently joined the Pycom family after purchasing a Pygate and Lopy4 (running on a Pysense 2). I have followed the getting started guides to set up the Pygate and Lopy4 for Australia (AU915) and put together a basic sketch to test the auth and data transfer on the LORAWAN network (using ABP and a slightly modified version of the example sketch). I will intermittently get a payload appear and the connected status will indicate a recent connection in the in the TTN console but that is very rare and intermittent (like 5 or 6 times a day).</p>
<p dir="auto">I have an arduino running a basic ABP sketch and on the Pygate I can see it connecting and delivering its payload 100% of the time which to me indicates the Pygate is working fine. I believe the issue lies with the Lopy/sketch. Does anybody have any experience troubleshooting this type of issue? I have tried OTAA but had the same issues?</p>
<p dir="auto">MY TEST SKETCH</p>
<pre><code>import socket
from network import LoRa
import binascii
import struct
from pysense import Pysense
py = Pysense()
# Initialize LoRa in LORAWAN mode.
# Asia = LoRa.AS923
# Australia = LoRa.AU915
# Europe = LoRa.EU868
# United States = LoRa.US915
lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
dev_addr = struct.unpack(&quot;&gt;l&quot;, binascii.unhexlify('MYADDRESS'))[0]
nwk_swkey = binascii.unhexlify('MYADDRESS')
app_swkey = binascii.unhexlify('MYADDRESS')
# Joining TTN via ABP
print(&quot;Joining TTN via ABP&quot;)
# Configure TTN socket
s.setblocking(False)
# Send test payload
print(&quot;Sending data ...&quot;)
s.send(bytes([1, 2, 3]))
#Allow time for data transmission
time.sleep(60)
#Put the board in to deep sleep for X amount of time
print(&quot;Pysense initiating sleep&quot;)
py.setup_sleep(600)
py.go_to_sleep()
</code></pre>
<p dir="auto">ARDUINO TRAFFIC ON THE PYGATE<br />
<img src="/assets/uploads/files/1611313758700-pygatetraffic.png" alt="PygateTraffic.png" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/topic/6771/intermittent-unreliable-data-transmission-on-ttna-lorawan</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 02:13:12 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/6771.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jan 2021 11:12:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 11:12:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
import binascii
import struct
py = Pysense()
# Asia = LoRa.AS923
# Send test payload
time.sleep(60)
py.setup_sleep(600)
py.go_to_sleep()
</code></pre>
]]></description><link>https://forum.pycom.io/post/36683</link><guid isPermaLink="true">https://forum.pycom.io/post/36683</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Fri, 22 Jan 2021 11:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 11:28:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/7905">@Matt-Walter</a> Do the channel sets of LoPy and Pygate match? Otherwise the LoPy may send on freqeuncies at which the PyGate does not listen.</p>
]]></description><link>https://forum.pycom.io/post/36684</link><guid isPermaLink="true">https://forum.pycom.io/post/36684</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 22 Jan 2021 11:28:20 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 11:35:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> I am 99% sure they do. The Lopy is set to region=LoRa.AU915 which matches the Pygate channel plan.</p>
]]></description><link>https://forum.pycom.io/post/36685</link><guid isPermaLink="true">https://forum.pycom.io/post/36685</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Fri, 22 Jan 2021 11:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 11:49:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> Here is the config from the Pygate</p>
<pre><code>{
	&quot;SX1301_conf&quot;: {
		&quot;lorawan_public&quot;: true,
		&quot;clksrc&quot;: 1,
		&quot;clksrc_desc&quot;: &quot;radio_1 provides clock to concentrator for most devices except MultiTech. For MultiTech set to 0.&quot;,
		&quot;antenna_gain&quot;: 0,
		&quot;antenna_gain_desc&quot;: &quot;antenna gain, in dBi&quot;,
		&quot;radio_0&quot;: {
			&quot;enable&quot;: true,
			&quot;type&quot;: &quot;SX1257&quot;,
			&quot;freq&quot;: 917200000,
			&quot;rssi_offset&quot;: -166.0,
			&quot;tx_enable&quot;: true,
			&quot;tx_freq_min&quot;: 915000000,
			&quot;tx_freq_max&quot;: 928000000
		&quot;radio_1&quot;: {
			&quot;freq&quot;: 917900000,
			&quot;tx_enable&quot;: false
		&quot;chan_multiSF_0&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 916.8 MHz&quot;,
			&quot;radio&quot;: 0,
			&quot;if&quot;: -400000
		&quot;chan_multiSF_1&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 917.0 MHz&quot;,
			&quot;if&quot;: -200000
		&quot;chan_multiSF_2&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 917.2 MHz&quot;,
			&quot;if&quot;: 0
		&quot;chan_multiSF_3&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 917.4 MHz&quot;,
			&quot;if&quot;: 200000
		&quot;chan_multiSF_4&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 917.6 MHz&quot;,
			&quot;radio&quot;: 1,
			&quot;if&quot;: -300000
		&quot;chan_multiSF_5&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 917.8 MHz&quot;,
			&quot;if&quot;: -100000
		&quot;chan_multiSF_6&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 918.0 MHz&quot;,
			&quot;if&quot;: 100000
		&quot;chan_multiSF_7&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 125kHz, all SF, 918.2 MHz&quot;,
			&quot;if&quot;: 300000
		&quot;chan_Lora_std&quot;: {
			&quot;desc&quot;: &quot;Lora MAC, 500kHz, SF8, 917.5 MHz&quot;,
			&quot;if&quot;: 300000,
			&quot;bandwidth&quot;: 500000,
			&quot;spread_factor&quot;: 8
		&quot;chan_FSK&quot;: {
			&quot;desc&quot;: &quot;disabled&quot;,
			&quot;enable&quot;: false
		&quot;tx_lut_0&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 0&quot;,
			&quot;pa_gain&quot;: 0,
			&quot;mix_gain&quot;: 8,
			&quot;rf_power&quot;: -6,
			&quot;dig_gain&quot;: 0
		&quot;tx_lut_1&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 1&quot;,
			&quot;mix_gain&quot;: 10,
			&quot;rf_power&quot;: -3,
		&quot;tx_lut_2&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 2&quot;,
			&quot;mix_gain&quot;: 12,
			&quot;rf_power&quot;: 0,
		&quot;tx_lut_3&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 3&quot;,
			&quot;pa_gain&quot;: 1,
			&quot;rf_power&quot;: 3,
		&quot;tx_lut_4&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 4&quot;,
			&quot;rf_power&quot;: 6,
		&quot;tx_lut_5&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 5&quot;,
			&quot;rf_power&quot;: 10,
		&quot;tx_lut_6&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 6&quot;,
			&quot;mix_gain&quot;: 13,
			&quot;rf_power&quot;: 11,
		&quot;tx_lut_7&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 7&quot;,
			&quot;pa_gain&quot;: 2,
			&quot;mix_gain&quot;: 9,
			&quot;rf_power&quot;: 12,
		&quot;tx_lut_8&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 8&quot;,
			&quot;mix_gain&quot;: 15,
			&quot;rf_power&quot;: 13,
		&quot;tx_lut_9&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 9&quot;,
			&quot;rf_power&quot;: 14,
		&quot;tx_lut_10&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 10&quot;,
			&quot;mix_gain&quot;: 11,
			&quot;rf_power&quot;: 16,
		&quot;tx_lut_11&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 11&quot;,
			&quot;pa_gain&quot;: 3,
			&quot;rf_power&quot;: 20,
		&quot;tx_lut_12&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 12&quot;,
			&quot;rf_power&quot;: 23,
		&quot;tx_lut_13&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 13&quot;,
			&quot;rf_power&quot;: 25,
		&quot;tx_lut_14&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 14&quot;,
			&quot;rf_power&quot;: 26,
		&quot;tx_lut_15&quot;: {
			&quot;desc&quot;: &quot;TX gain table, index 15&quot;,
			&quot;mix_gain&quot;: 14,
			&quot;rf_power&quot;: 27,
	&quot;gateway_conf&quot;: {
		&quot;server_address&quot;: &quot;router.au.thethings.network&quot;,
		&quot;serv_port_up&quot;: 1700,
		&quot;serv_port_down&quot;: 1700,
		&quot;servers&quot;: [ {
			&quot;serv_enabled&quot;: true
        &quot;gateway_ID&quot;: &quot;45b98b097087aedf&quot;,
        &quot;keepalive_interval&quot;: 10,
        &quot;stat_interval&quot;: 30,
        &quot;push_timeout_ms&quot;: 100,
        &quot;forward_crc_valid&quot;: true,
        &quot;forward_crc_error&quot;: false,
		&quot;forward_crc_disabled&quot;: false,
		&quot;fake_gps&quot;: true,
		&quot;ref_latitude&quot;: -26.602380,
		&quot;ref_longitude&quot;: 153.027713,
		&quot;ref_altitude&quot;: 0
</code></pre>
]]></description><link>https://forum.pycom.io/post/36686</link><guid isPermaLink="true">https://forum.pycom.io/post/36686</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Fri, 22 Jan 2021 11:49:19 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 14:41:08 GMT]]></title><description><![CDATA[<p dir="auto">The AU915 range covers 64 channels, while the gateway only listens to 8, I have attached an example that sets the correct channels on the lopy</p>
<pre><code>from network import LoRa
import ubinascii
import struct
# Initialise LoRa in LORAWAN mode.
# Asia = LoRa.AS923
print(&quot;joining&quot;)
dev_addr = struct.unpack(&quot;&gt;l&quot;, ubinascii.unhexlify(''))[0]
nwk_swkey = ubinascii.unhexlify('')
app_swkey = ubinascii.unhexlify('')
#Do not transmit on the channels outside the Pygate scope
for i in range(0,64):
    lora.remove_channel(i)
lora.add_channel(0, frequency=916800000, dr_min=0, dr_max=3)
lora.add_channel(1, frequency=917000000, dr_min=0, dr_max=3)
lora.add_channel(2, frequency=917200000, dr_min=0, dr_max=3)
lora.add_channel(3, frequency=917400000, dr_min=0, dr_max=3)
lora.add_channel(4, frequency=917600000, dr_min=0, dr_max=3)
lora.add_channel(5, frequency=917800000, dr_min=0, dr_max=3)
lora.add_channel(6, frequency=918000000, dr_min=0, dr_max=3)
lora.add_channel(7, frequency=918200000, dr_min=0, dr_max=3)
# join a network using ABP (Activation By Personalization)
# create a LoRa socket
# set the LoRaWAN data rate
s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
# make the socket blocking
# (waits for the data to be sent and for the 2 receive windows to expire)
s.setblocking(True)
# send some data
s.send(bytes([0x01, 0x02, 0x03]))
# (because if there's no data received it will block forever...)
# get any data received (if any...)
data = s.recv(64)
print(data)
</code></pre>
<p dir="auto">(I have not tested this exact adaptation, but it should work for you)</p>
<p dir="auto">I want to add this to the documentation, where would you expect / have looked for this information?</p>
]]></description><link>https://forum.pycom.io/post/36687</link><guid isPermaLink="true">https://forum.pycom.io/post/36687</guid><dc:creator><![CDATA[Gijs]]></dc:creator><pubDate>Fri, 22 Jan 2021 14:41:08 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 17:09:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311">@Gijs</a></a> <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/7905"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/7905">@Matt-Walter</a></a> To be precise, AU915 has 72 uplinks channels: 64 channels with BW125 (numbered 0-63) and 8 with BW500 (numbered 64-71).</p>
<p dir="auto">Gateways usually listen on 9 of them (8 BW125 and 1 BW500). Which ones they listen on depends on the network and gateway configuration.</p>
<p dir="auto">The TTN frequency plan for AU915 uses channels 8 to 15 (frequencies 916.8 MHz to 918.2 MHz BW 125) and channel 65 (917.5 MHz BW 500).</p>
<p dir="auto">Many operations (like RX1 channel selection) are based on the channel uplink channel number modulo 8, so using channel numbers 0-7 instead of 8-15 doesn't matter for those, but I would expect some MAC commands (those which update the list of channels to use and the like) to fail miserably if there is a mismatch.</p>
<p dir="auto">It's probably easier to keep the existing &quot;correct&quot; channels (8-15, 65) which should already pre-configured with the right settings (BW, DR...) and just remove the ones not in use (0-7, 16-64, 66-71). Something like:</p>
<pre><code>for i in range(0,8):
for i in range(16,65):
for i in range(66,72):
</code></pre>
<p dir="auto">(I didn't test it as I'm not in a region with such issues).</p>
<p dir="auto">Of course the Pygate must indeed be appropriately configured for the same frequencies (as described by <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311">@Gijs</a></a>)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/7905"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/7905">@Matt-Walter</a></a> Also, if you use deep sleep, you <strong>need to</strong> save (before going to sleep) and restore (when waking up) the LoRa state, as that will at last have the correct frame counters, but also any information sent by the network about channels to use or not use, frequencies, DRs, RX offsets, and whatnot.</p>
]]></description><link>https://forum.pycom.io/post/36694</link><guid isPermaLink="true">https://forum.pycom.io/post/36694</guid><dc:creator><![CDATA[jcaron]]></dc:creator><pubDate>Fri, 22 Jan 2021 17:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 20:43:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311">@Gijs</a>  Thanks for this, I tested the example and it works 100%!!</p>
<p dir="auto">When settings this up I look in the following places for the doco:<br />
<a href="https://docs.pycom.io/tutorials/networks/lora/lorawan-abp/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/tutorials/networks/lora/lorawan-abp/</a><br />
<a href="https://www.thethingsnetwork.org/docs/devices/lopy/usage.html" target="_blank" rel="noopener noreferrer nofollow">https://www.thethingsnetwork.org/docs/devices/lopy/usage.html</a></p>
<p dir="auto">Am I correct in thinking I can change the dr_max and socket data rate to 5 as it is supported in AU? <a href="https://avbentem.github.io/airtime-calculator/ttn/au915/8" target="_blank" rel="noopener noreferrer nofollow">https://avbentem.github.io/airtime-calculator/ttn/au915/8</a></p>
<p dir="auto">Thanks again for your help, I really appreciate it.</p>
]]></description><link>https://forum.pycom.io/post/36698</link><guid isPermaLink="true">https://forum.pycom.io/post/36698</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Fri, 22 Jan 2021 20:43:45 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Fri, 22 Jan 2021 21:14:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1538">@jcaron</a> This is awesome info!! This approach seems to work as well, I have 100% data transmission.</p>
<p dir="auto">I have been trying to work out what I needed to do before putting the device into deep sleep. Are you able to point me in the direction of some doco or an example on how to save and restore the LoRa state?</p>
<p dir="auto"><img src="/assets/uploads/files/1611350079712-gateway_traffic.png" alt="Gateway_Traffic.png" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/36701</link><guid isPermaLink="true">https://forum.pycom.io/post/36701</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Fri, 22 Jan 2021 21:14:59 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Mon, 25 Jan 2021 09:17:47 GMT]]></title><description><![CDATA[<p dir="auto">Yes, its listed here: <a href="https://docs.pycom.io/tutorials/networks/lora/nvram/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/tutorials/networks/lora/nvram/</a><br />
Maybe the name is a bit confusing, but it saves the data to non volatile storage and then you can safely deepsleep</p>
]]></description><link>https://forum.pycom.io/post/36718</link><guid isPermaLink="true">https://forum.pycom.io/post/36718</guid><dc:creator><![CDATA[Gijs]]></dc:creator><pubDate>Mon, 25 Jan 2021 09:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to Intermittent&#x2F;unreliable data transmission on TTNA&#x2F;LORAWAN on Mon, 25 Jan 2021 23:36:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/6311">@Gijs</a> Perfect!! Thanks for your help.</p>
]]></description><link>https://forum.pycom.io/post/36742</link><guid isPermaLink="true">https://forum.pycom.io/post/36742</guid><dc:creator><![CDATA[Matt Walter]]></dc:creator><pubDate>Mon, 25 Jan 2021 23:36:52 GMT</pubDate></item></channel></rss>
