<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pins supporting OneWire]]></title><description><![CDATA[<p dir="auto">I am designing a custom board for the LoPy4 and I was wondering which pins can support OneWire. Is there any limitation apart from the pins already assigned (e.g. LoRa module, UART, etc). Any requirement?<br />
Thank you in advance!</p>
]]></description><link>https://forum.pycom.io/topic/6787/pins-supporting-onewire</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 16:17:53 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/6787.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jan 2021 00:11:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pins supporting OneWire on Wed, 27 Jan 2021 00:11:21 GMT]]></title><description><![CDATA[<p dir="auto">I am designing a custom board for the LoPy4 and I was wondering which pins can support OneWire. Is there any limitation apart from the pins already assigned (e.g. LoRa module, UART, etc). Any requirement?<br />
]]></description><link>https://forum.pycom.io/post/36780</link><guid isPermaLink="true">https://forum.pycom.io/post/36780</guid><dc:creator><![CDATA[berni]]></dc:creator><pubDate>Wed, 27 Jan 2021 00:11:21 GMT</pubDate></item><item><title><![CDATA[Reply to Pins supporting OneWire on Wed, 27 Jan 2021 01:09:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1369">@berni</a> You can use any digital bidirectional (i.e. non analogue input only) pin which is not allocated to another functionality. This means you should avoid:</p>
<ul>
<li>P13-P18 since they are input-only pins,</li>
<li>P12 which is used for antenna selection,</li>
<li>P5-P7 which are used for LoRa radio, and</li>
<li>P0-P1 used for UART.</li>
</ul>
]]></description><link>https://forum.pycom.io/post/36781</link><guid isPermaLink="true">https://forum.pycom.io/post/36781</guid><dc:creator><![CDATA[Antonis Gotsis]]></dc:creator><pubDate>Wed, 27 Jan 2021 01:09:13 GMT</pubDate></item></channel></rss>
