    DS18B20 on WiPi reading "none"
    31 Posts 5 Posters 211 Views 5 Watching
      cbourne
      Hi I have a DS18B20 and IU'm using the following code. I gave the data pin on the DS18B20 connected to Pin10 on my WiPi.
      However, its constantly just writes out "none"
      from machine import Pin
      from onewire import DS18X20
      from onewire import OneWire
      # DS18B20 data line connected to pin P10
      ow = OneWire(Pin('P10'))
      temp = DS18X20(ow)
          print(temp.read_temp_async())
          temp.start_conversion()
      robert-hhR optimhoO 2 Replies Last reply Reply Quote 0
        d.alvrzx
        I'm not exactly sure which onewire library you are using, because the imports usually look like this:
        from ds18x20 import DS18X20
        Yours imports DS18X20 from onewire. However, you should look into using this library by @robert-hh , which I've used without problems for months now. His example code in the repo shows you how to get a temp reading.
          cbourne @d.alvrzx
          @d-alvrzx said in DS18B20 on WiPi reading "none":
          ds18x20
          Thanks for this - very helpful.
          Seems that my problem is that the Pycom is not seeing any of my DS18X20's on the bus.
          i.e.
          ow.scan()
          returns and empty array.
          I've got my pins configured as:
          ds18x20 Pycom WiPy
          gnd => gnd
          data => P10
          Power => P11
          I also have a 4.7k resistor between data and Power.
          These are what I'm using https://thepihut.com/products/ds18b20-digital-temperature-sensor-extras?variant=27740417553
            d.alvrzx @cbourne
            @cbourne As far as the library I linked to goes, the scan() function is a part of the DS18X20 object (not the ow object). So your code should be something like this:
            from utime import sleep
            # setup temp sensor
            ow = OneWire(Pin('P22')) # replace for data pin in your setup
            TempSensor = DS18X20(ow)
            Roms = TempSensor.scan()
            if Roms:
                print("DS18S20 Resolution", TempSensor.resolution(Roms[0], 9))
            # read temp sensor
            if Roms:
                TempSensor.convert_temp()
                sleep(1) # wait for temp conversion
                currTemp = TempSensor.read_temp(Roms[0])
                print(currTemp)
            Then, I'm not sure why you have the DS18B20 VDD (power) pin connected to P11. You should connect that to the WiPy 3V3 output. As per the datasheet, these should be your connections:
            In your case, VPU=VDD.
            C 2 Replies Last reply Reply Quote 1
              cbourne @d.alvrzx
              @d-alvrzx Thanks for getting back on this. So I've wired everything as per the diagram and tried PINS 10, 17, 20. Ans still get an empty array for Roms using your suggested code. Not sure what else to do next now.
                cbourne @d.alvrzx
                @d-alvrzx So I also tested the voltage across the DS18X20 - its ~3.2 volt. Data is now on Pin10. Also tried a brand new Wipy 3. Still not seeing the DS18X20 and Roms return an empt array.
                  robert-hh @cbourne
                  @cbourne So you have the data pin at 3.2, when there is not data requested. That's fine. During transfer you should see with a voltage meter a slight drop. Is the DS18B20 cold or warm? If warm, the wiring is wrong.
                  Did the DS18B20 ever work? If not, it may be broken.
                    cbourne @robert-hh
                    @robert-hh So ?I get 3.2v between GND and Vdd and 2.8v between GND and the data pin. I've tried 3 seperate DS18B20 from here https://thepihut.com/products/ds18b20-digital-temperature-sensor-extras?
                    Just tried a new WiPi 3 and expansion board. Same result. i.e. and empty Roms array.
                      cbourne
                      OK so I just tested my DS18X20 on a Raspberry Pico & Circuit Python using this code:
                      import board
                      from adafruit_onewire.bus import OneWireBus
                      from adafruit_ds18x20 import DS18X20
                      # Initialize one-wire bus on board pin D5.
                      ow_bus = OneWireBus(board.GP16)
                      # Scan for sensors and grab the first one found.
                      ds18 = DS18X20(ow_bus, ow_bus.scan()[0])
                      # Main loop to print the temperature every second.
                          print("Temperature: {0:0.3f}C".format(ds18.temperature))
                          time.sleep(1.0)
                      It worked first time:
                      Temperature: 28.750C
                      Temperature: 28.813C
                      Temperature: 28.688C
                      Temperature: 28.625C
                      Temperature: 28.563C
                      So obviously there's something different happening here and it proved that the DS18X20 is working properly. Can anyone shed some light on this problem please.
                        robert-hh @cbourne
                        @cbourne I tried to replicate that on my lopy, only to find that I seem to have a completely different set of functions, which however work. Since I am not allowed to upload them here, i've put it to a different place:
                        https://github.com/robert-hh/Shared-Stuff/blob/master/ds18x20.zip
                          cbourne @robert-hh
                          @robert-hh Thanks, I'll try this again later. So are these different to the ones here: https://github.com/robert-hh/Onewire_DS18X20 ?
                            robert-hh @cbourne
                            @cbourne No. That should be the same. I simply forgot that I had made a repository for them. Quite a while ago. We never could convince Pycom to use these.
                            So take the files from the repository. They are proper documented.
                              cbourne @robert-hh
                              @robert-hh OK I’ve already tried the ones from the repository and get the same result. ‘Roms=[]’ I don’t understand this took me 5 mins to get working on the PI pico. So far I’ve spent 5 days and still can’t get it to work on a Wipy3.
                              The bigger issue here though is clearly the stock examples in the Pycom docs don’t work, so if they don’t work not sure if there’s much hope.
                              I think I need to look at a different ecosystem for my development boards. I also spent hours trying to find a workable ‘uRequests’ example because again the docs were not current.
                              If Pycom can’t provide and more importantly maintain, basic working examples for the most common use cases, then why should I waste my time and money here.
                                robert-hh @cbourne
                                @cbourne That's strange, because that code works here and also for other people. So it must be something else. Are you sure that you have it connected to P10 and that P10 works? Did you try a different Pin? Do you have a logic analyzer? Even the 10 € devices you can get at Amazon and othe rplaces are very helpful.
                                About the Data Pin. If you do not send data, the data pin should be at about 3.3V.
                                • optimhoO Offline
                                  optimho @cbourne
                                  @cbourne Hello, Might be an obvious one, but check that the pull up resistor is connected
                                    cbourne @optimho
                                    @optimho thanks yep already done that.
                                    robert-hhR optimhoO J 3 Replies Last reply Reply Quote 0
                                      robert-hh @cbourne
                                      @cbourne Did you use the same set-up with pull-up resistor for the Pico test?
                                        cbourne @robert-hh
                                        @robert-hh yes exactly the same components on the same breadboard.
                                        robert-hhR D 2 Replies Last reply Reply Quote 0
                                          robert-hh @cbourne
                                          @cbourne And the same jumper wires?
                                          • optimhoO Offline
                                            optimho @cbourne
                                            @cbourne It can be a bit of a frustration - but there is the pure joy when you get it to work, you know how it goes.
                                            An oscilloscope is what you need for these tricky ones.
                                            In absence of one, I would and you possibly already have inserted an LED between your pull up resistor and the supply to the resistor then add some code to turn on and off that LED, temporarily comment out some of your other code so that you can just revert back to it afterwards, then bridge out or remove the LED with out disturbing the circuit.
                                            This might seem like such a basic thing to do, but rules out faulty componentry, wiring and so on.
                                            Recheck the the value of your pull up.
                                            • 1
                                            • 2
                                            • 1 / 2
