<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need hardware recommendations]]></title><description><![CDATA[<p dir="auto">Hey folks. I'm new to the DIY electronics space though I have had some limited experience with raspberry Pis, know my way around python and understand the fundamentals of these project boards but am having trouble putting it altogether.</p>
<p dir="auto">What I'd like to ramp up to is a project that would involve two lipo battery powered GPys or FiPys connected to a button that when pressed would cause a vibration motor to activate on the other &quot;box&quot;, the trigger being sent wirelessly via cellular. I know the expansion board exists and maybe that would be all I need to get in tandem with the GPy/FiPy but before I started buying hardware I wanted to see if I could get some guidance in the right direction. Any assistance would be appreciated.</p>
]]></description><link>https://forum.pycom.io/topic/7232/need-hardware-recommendations</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 06:34:55 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/7232.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Aug 2021 18:18:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need hardware recommendations on Sat, 28 Aug 2021 18:18:48 GMT]]></title><description><![CDATA[<p dir="auto">Hey folks. I'm new to the DIY electronics space though I have had some limited experience with raspberry Pis, know my way around python and understand the fundamentals of these project boards but am having trouble putting it altogether.</p>
]]></description><link>https://forum.pycom.io/post/39124</link><guid isPermaLink="true">https://forum.pycom.io/post/39124</guid><dc:creator><![CDATA[Samuel Patwin]]></dc:creator><pubDate>Sat, 28 Aug 2021 18:18:48 GMT</pubDate></item><item><title><![CDATA[Reply to Need hardware recommendations on Fri, 03 Sep 2021 11:33:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi Samuel,<br />
Please check the network connection you are planning to use. For your application, it seems a direct LoRa RAW connection would be ideal, though I do not know about the separation distance.<br />
The problem I foresee in your current setup is the need of a central server able to relay communications between the devices, as cellular is a centralised network, requiring the need of a separate server (its not possible to connect between devices directly).</p>
<p dir="auto">Other than that, the Fipy / Gpy should work fine for the application :)</p>
]]></description><link>https://forum.pycom.io/post/39160</link><guid isPermaLink="true">https://forum.pycom.io/post/39160</guid><dc:creator><![CDATA[Gijs]]></dc:creator><pubDate>Fri, 03 Sep 2021 11:33:33 GMT</pubDate></item></channel></rss>
