<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot registrating any devices on pybytes]]></title><description><![CDATA[<p dir="auto">Hello, Is Pybytes having problem for registrating devices ?<br />
I've try to register 2 devices on it without success.<br />
Creating the devices is ok, token is well generated, but when the firmware updater ask for the token it don't accept and &quot;None&quot; appear just below the token window !<br />
Is someone have the solution ?<br />
Best regards<br />
Jiemde</p>
]]></description><link>https://forum.pycom.io/topic/7361/cannot-registrating-any-devices-on-pybytes</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:02:04 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/7361.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Nov 2021 16:08:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Thu, 18 Nov 2021 16:08:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello, Is Pybytes having problem for registrating devices ?<br />
Best regards<br />
Jiemde</p>
]]></description><link>https://forum.pycom.io/post/39577</link><guid isPermaLink="true">https://forum.pycom.io/post/39577</guid><dc:creator><![CDATA[DEFRAINE.JM]]></dc:creator><pubDate>Thu, 18 Nov 2021 16:08:42 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Thu, 18 Nov 2021 22:37:02 GMT]]></title><description><![CDATA[<p dir="auto">Registering via the firmware updater didn't work for me yesterday, I instead used the <code>pybytes.activate</code> command via Pymakr.</p>
]]></description><link>https://forum.pycom.io/post/39584</link><guid isPermaLink="true">https://forum.pycom.io/post/39584</guid><dc:creator><![CDATA[d.alvrzx]]></dc:creator><pubDate>Thu, 18 Nov 2021 22:37:02 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Fri, 19 Nov 2021 08:18:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/5886">@d-alvrzx</a>,<br />
Try the pybytes activation with the Pymakr solution but also fail !</p>
<p dir="auto"><img src="/assets/uploads/files/1637309878717-capture_pybytes_activation.png" alt="Capture_pybytes_activation.PNG" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/39585</link><guid isPermaLink="true">https://forum.pycom.io/post/39585</guid><dc:creator><![CDATA[DEFRAINE.JM]]></dc:creator><pubDate>Fri, 19 Nov 2021 08:18:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Fri, 19 Nov 2021 15:17:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Since I got my FiPy, I never could activate through PyBytes. Also I can not provision with the offline firmware updater as when entering the Generated Token I get only a None return, and it is not possible to use online PyBytes management.</p>
<p dir="auto">But local activation through PyMakr plugin is working, only yesterday evening it was not possible to generate the activation string on PyBytes website.</p>
]]></description><link>https://forum.pycom.io/post/39590</link><guid isPermaLink="true">https://forum.pycom.io/post/39590</guid><dc:creator><![CDATA[Louis CONVERT]]></dc:creator><pubDate>Fri, 19 Nov 2021 15:17:02 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Tue, 23 Nov 2021 16:35:52 GMT]]></title><description><![CDATA[<p dir="auto">I can't get anything to work either.  I've tried all three methods of activation and keep getting the following,</p>
<pre><code>Please review Wifi SSID and password!
Wifi connection established... activating device!
Failed to send activation request!
Exception during WiFi cli activation!
'NoneType' object has no attribute 'status_code'
Activation failed!
</code></pre>
<p dir="auto">When using the offline FW updater, when I post the activation code I get a response of &quot;None&quot; <img src="/assets/uploads/files/1637685333758-e85cd6af-77f2-4179-8753-231b614f0161-image.png" alt="e85cd6af-77f2-4179-8753-231b614f0161-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">This is all terribly frustrating as nothing seems to work.</p>
]]></description><link>https://forum.pycom.io/post/39597</link><guid isPermaLink="true">https://forum.pycom.io/post/39597</guid><dc:creator><![CDATA[Joseph Martin]]></dc:creator><pubDate>Tue, 23 Nov 2021 16:35:52 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot registrating any devices on pybytes on Wed, 24 Nov 2021 13:32:23 GMT]]></title><description><![CDATA[<p dir="auto">I had the same issue few days back. I found that sometime it works and sometime it doesn't. Also nowadays i started using Pybytes ios app based method. It working perfectly fine for me. Also I was getting 401 error some time back. I have no clue what it was.</p>
]]></description><link>https://forum.pycom.io/post/39601</link><guid isPermaLink="true">https://forum.pycom.io/post/39601</guid><dc:creator><![CDATA[Narashiman P]]></dc:creator><pubDate>Wed, 24 Nov 2021 13:32:23 GMT</pubDate></item></channel></rss>
