<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Again: GPy modem not answering after firmware update]]></title><description><![CDATA[<p dir="auto">I tried to update the modem on a GPy to the most recent CAT-M1 firmware CATM1-5.2-48829 (<a href="https://docs.pycom.io/updatefirmware/ltemodem/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/updatefirmware/ltemodem/</a>), but after the first step the modem is not longer answering the anything. Step 2 of the update won't work, updating to NB-IoT firmware won't work, creating a lte object from the LTE class to run the proposed (<a href="https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/8">https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/8</a>) reset, disconnect, dettach cycle won't work, talking to the modem directly using the serial class with <code>serial = UART(1, baudrate=921600, pins=('P5', 'P98', 'P7', 'P99'), timeout_chars=1)</code> (<a href="https://forum.pycom.io/topic/6909/couldn-t-connect-to-modem-modem_state-disconnected/5">https://forum.pycom.io/topic/6909/couldn-t-connect-to-modem-modem_state-disconnected/5</a>) and so on won't work.</p>
<p dir="auto">Do I have any other chance to revive the modem?</p>
<p dir="auto">Cheers and thanks, Wolfgang</p>
]]></description><link>https://forum.pycom.io/topic/7590/again-gpy-modem-not-answering-after-firmware-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 09:03:01 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/7590.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jun 2022 08:13:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Again: GPy modem not answering after firmware update on Thu, 02 Jun 2022 08:13:53 GMT]]></title><description><![CDATA[<p dir="auto">I tried to update the modem on a GPy to the most recent CAT-M1 firmware CATM1-5.2-48829 (<a href="https://docs.pycom.io/updatefirmware/ltemodem/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/updatefirmware/ltemodem/</a>), but after the first step the modem is not longer answering the anything. Step 2 of the update won't work, updating to NB-IoT firmware won't work, creating a lte object from the LTE class to run the proposed (<a href="https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/8">https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/8</a>) reset, disconnect, dettach cycle won't work, talking to the modem directly using the serial class with <code>serial = UART(1, baudrate=921600, pins=('P5', 'P98', 'P7', 'P99'), timeout_chars=1)</code> (<a href="https://forum.pycom.io/topic/6909/couldn-t-connect-to-modem-modem_state-disconnected/5">https://forum.pycom.io/topic/6909/couldn-t-connect-to-modem-modem_state-disconnected/5</a>) and so on won't work.</p>
]]></description><link>https://forum.pycom.io/post/40410</link><guid isPermaLink="true">https://forum.pycom.io/post/40410</guid><dc:creator><![CDATA[Wolfgang Hottgenroth]]></dc:creator><pubDate>Thu, 02 Jun 2022 08:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to Again: GPy modem not answering after firmware update on Thu, 16 Jun 2022 15:11:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10231">@Wolfgang-Hottgenroth</a> Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3542">@pycom</a>, is this issue completely irrelevant for you? No hint for me how to unbrick the GPy? Or is it actually lethally bricked?</p>
]]></description><link>https://forum.pycom.io/post/40484</link><guid isPermaLink="true">https://forum.pycom.io/post/40484</guid><dc:creator><![CDATA[Wolfgang Hottgenroth]]></dc:creator><pubDate>Thu, 16 Jun 2022 15:11:22 GMT</pubDate></item><item><title><![CDATA[Reply to Again: GPy modem not answering after firmware update on Tue, 16 May 2023 17:11:52 GMT]]></title><description><![CDATA[<p dir="auto">I am having the same problem. Is there a solution?</p>
]]></description><link>https://forum.pycom.io/post/41530</link><guid isPermaLink="true">https://forum.pycom.io/post/41530</guid><dc:creator><![CDATA[Gabriel Torres]]></dc:creator><pubDate>Tue, 16 May 2023 17:11:52 GMT</pubDate></item></channel></rss>
