Cannot connect terminal to FiPy
  • Hi,
    I'm struggling to get started with a FiPy in a PyScan board.
    Device permissions are OK.
    Firmware updated to 1.20.2.r6 using the fwtool GUI on linux AMD64
    pymakr on vscode lists the device but when connecting it spins on "safeboot" for a bit then fails with:
    Could not safeboot device. Please hard reset the device and verify that a shield is installed.
    What else can I try here?
  • Update.
    Going for broke, I used the fwtool to erase the flash and reset the CONFIG and NVS areas.
    working, connected to REPL etc.
    I don't see a pyscan DFU listed and wasn't able to grope for it. Seems to be working now after a spring clean.
  • @Rob-Shepherd If you do not get boot messages, you might have to update the pyscan board's PIC firmware. But that's another story.
  • @Rob-Shepherd Picocom is fine. When you have picocom connected and push the reset button, do you receive anything from the board. There should be at least some messages by the ROM based bootloader.
  • THank you @robert-hh
    Yes I should have mentioned, I have tried picocom thus:
    rob@graviton:/tmp$ sudo picocom -b 115200 /dev/ttyACM0
    [sudo] password for rob:
    picocom v3.1
    port is        : /dev/ttyACM0
    flowcontrol    : none
    baudrate is    : 115200
    parity is      : none
    databits are   : 8
    stopbits are   : 1
    escape is      : C-a
    local echo is  : no
    noinit is      : no
    noreset is     : no
    hangup is      : no
    nolock is      : no
    send_cmd is    : sz -vv
    receive_cmd is : rz -vv -E
    imap is        :
    omap is        :
    emap is        : crcrlf,delbs,
    logfile is     : none
    initstring     : none
    exit_after is  : not set
    exit is        : no
    Type [C-a] [C-h] to see available commands
    Terminal ready
    It just hangs there sadly.
    Thanks again
  • This post is deleted!
  • @Rob-Shepherd Try using a simple terminal emulator like putty first. pymakr with vcs or atom are notorious for having compatibility issues.
