<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pycom lopy4 doesn&#x27;t show repl prompt using vscode?]]></title><description><![CDATA[<p dir="auto">Hi everyone..!<br />
I am new to this galaxy of Pycom and micropython. I was trying to connect to pycom lopy4 using Pymakr vscode extension. Initially, it wasn't even showing the console. Thanks to all of you for posting solutions to this issue. I downgraded vscode version to 1.58.2 ! and pymakr version is the latest 1.1.18.<br />
It now shows the terminal.<br />
However, I am it doesn't connect to the pycom board and keeps showing connecting COM7 ...</p>
<ul>
<li>i have verified the serial port it is correct.</li>
<li>I have also tried to connect using PuTTy using 115200 baud rate and flow control :No</li>
<li>I have also tried using Ubuntu 20.4 -- Vscode pymakr + Picocom and Screen as well</li>
<li>But it keeps showing Connecting to port ....</li>
<li>on ubuntu, I have a user to dialout group as well.</li>
</ul>
<p dir="auto">Could you please help out to resolve this issue??</p>
<p dir="auto">Thanks in advance.!</p>
]]></description><link>https://forum.pycom.io/topic/7781/pycom-lopy4-doesn-t-show-repl-prompt-using-vscode</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 13:17:23 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/7781.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Feb 2023 11:08:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 11:08:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone..!<br />
<ul>
</ul>
]]></description><link>https://forum.pycom.io/post/41435</link><guid isPermaLink="true">https://forum.pycom.io/post/41435</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Thu, 16 Feb 2023 11:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:01:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10953">@Mogambo-Khan</a> You should be able to connect to the board using Ubuntu and just pico com at a baud rate of 115200. Which usb-serial interface do you use? The expansion board?</p>
]]></description><link>https://forum.pycom.io/post/41436</link><guid isPermaLink="true">https://forum.pycom.io/post/41436</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:01:52 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:01:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> thanks for your reply. Picocom says terminal ready: but can't type anything .....</p>
]]></description><link>https://forum.pycom.io/post/41437</link><guid isPermaLink="true">https://forum.pycom.io/post/41437</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:01:52 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:03:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10953">@Mogambo-Khan</a> What happens when you connect with picocom and push reset at the board? Which tty device do you connect to?</p>
]]></description><link>https://forum.pycom.io/post/41438</link><guid isPermaLink="true">https://forum.pycom.io/post/41438</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:03:54 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:21:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> I receive the following message when I press reset: for ttyACM0<br />
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)<br />
configsip: 0, SPIWP:0xee<br />
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00<br />
mode:DIO, clock div:1<br />
load:0x3fff8020,len:8<br />
load:0x3fff8028,len:2140<br />
ho 0 tail 12 room 4<br />
load:0x4009fa00,len:19760<br />
entry 0x400a05bc</p>
]]></description><link>https://forum.pycom.io/post/41439</link><guid isPermaLink="true">https://forum.pycom.io/post/41439</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:21:02 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:26:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10953">@Mogambo-Khan</a> OK. So you are on the right port. Just the firmware does not start. Try loading the LoPy4 firmware again. Which firmware did you use?</p>
]]></description><link>https://forum.pycom.io/post/41440</link><guid isPermaLink="true">https://forum.pycom.io/post/41440</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:31:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> the flashed firmware is 1.20.2.6r</p>
]]></description><link>https://forum.pycom.io/post/41441</link><guid isPermaLink="true">https://forum.pycom.io/post/41441</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:45:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10953">@Mogambo-Khan</a> Is it the pybytes or pygate firmware? In any case, try a legacy firmware version.<br />
You can as well try this one built by me, which I know it works on my LoPy4 devices: <a href="https://github.com/robert-hh/Shared-Stuff/blob/master/LoPy4-1.20.2.r6.tar.gz" target="_blank" rel="noopener noreferrer nofollow">https://github.com/robert-hh/Shared-Stuff/blob/master/LoPy4-1.20.2.r6.tar.gz</a></p>
]]></description><link>https://forum.pycom.io/post/41442</link><guid isPermaLink="true">https://forum.pycom.io/post/41442</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:45:59 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:47:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/10953">@Mogambo-Khan</a> Older Pycom versions of the firmware are here: <a href="https://docs.pycom.io/advance/downgrade/" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/advance/downgrade/</a><br />
It may be that a PyBytes firmware does not work any more since Pycom got bankrupt.</p>
]]></description><link>https://forum.pycom.io/post/41443</link><guid isPermaLink="true">https://forum.pycom.io/post/41443</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:47:57 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Thu, 16 Feb 2023 12:48:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> it is pybyte firmware. Anyways, thanks for your response! I will update the firmware and see if it works for me...<br />
thanks again!</p>
]]></description><link>https://forum.pycom.io/post/41444</link><guid isPermaLink="true">https://forum.pycom.io/post/41444</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Thu, 16 Feb 2023 12:48:24 GMT</pubDate></item><item><title><![CDATA[Reply to pycom lopy4 doesn&#x27;t show repl prompt using vscode? on Fri, 17 Feb 2023 09:23:48 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone, if you are seeing this comment !... So coming back to the problem I had. Since I was beginner so I tried almost all the tools and tricks to connect the pycom lopy4 using pymakr and vscode.<br />
But the issue was resolved by updating the firmware of the module to the latest one.<br />
Hence if you are having such issues don't forget to update the firmware.</p>
<p dir="auto">thanks to Robert, btw!</p>
]]></description><link>https://forum.pycom.io/post/41445</link><guid isPermaLink="true">https://forum.pycom.io/post/41445</guid><dc:creator><![CDATA[Mogambo Khan]]></dc:creator><pubDate>Fri, 17 Feb 2023 09:23:48 GMT</pubDate></item></channel></rss>
