<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Beta firmware updater 1.17.0.b0&#x2F;b1]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">We've been doing a lot of work behind the scenes over the last few months and one of the things I worked on is the firmware updater.</p>
<p dir="auto">The current stable version was built with Python2 and QT4 which is no longer supported. I started updating to Python3 and QT5 more than 2 years ago and finally believe I have a somewhat stable update.</p>
<p dir="auto">I started deploying 1.17.0.b0 for Linux and MacOS a few days ago but there were some additional issues on Windows.</p>
<p dir="auto">I have not tested the 32bit versions for Linux as I currently don't have any VM available for this. I'm thinking to drop 32bit support and I'd be interested to know if anyone would miss them.</p>
<p dir="auto">I also made some updates on the software server, mainly removing the Sigfox registration part because Sigfox decided to no longer offer the trial connectivity.</p>
<p dir="auto">If you are using Sigfox and have your own ID/KEY pair, you can use the <code>pycom.sigfox()</code> method to store them on the device, for example:</p>
<p dir="auto"><code>pycom.sigfox_info(id='AB12CD45',pac='AABBCCDDEEFF0011',public_key='00112233445566778899AABBCCDDEEFF',private_key='00112233445566778899AABBCCDDEEFF', force=True)</code></p>
<p dir="auto">After a reset you should be able to use Sigfox. It is possible that the firmware updater will overwrite your own Sigfox credentials, I will look at that next week.</p>
<p dir="auto">Please let me know if you encounter any issues with the new version. Thanks a lot.</p>
]]></description><link>https://forum.pycom.io/topic/7791/new-beta-firmware-updater-1-17-0-b0-b1</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 02:22:28 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/7791.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Mar 2023 19:07:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Thu, 09 Mar 2023 19:07:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
]]></description><link>https://forum.pycom.io/post/41476</link><guid isPermaLink="true">https://forum.pycom.io/post/41476</guid><dc:creator><![CDATA[Xykon]]></dc:creator><pubDate>Thu, 09 Mar 2023 19:07:29 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Fri, 10 Mar 2023 09:25:16 GMT]]></title><description><![CDATA[<p dir="auto">I now released 1.17.0.b2 for Windows. It was all looking good in my Virtual Machine but when I checked on my Windows PC at home the window was way too small.</p>
<p dir="auto">For now I disabled the fixed size completely so you can resize the window if needed.</p>
<p dir="auto">If anyone has problems with the updater showing at the wrong size please provide some screenshots and details of your monitor size &amp; resolution.</p>
<p dir="auto">Thanks a lot.</p>
]]></description><link>https://forum.pycom.io/post/41477</link><guid isPermaLink="true">https://forum.pycom.io/post/41477</guid><dc:creator><![CDATA[Xykon]]></dc:creator><pubDate>Fri, 10 Mar 2023 09:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Fri, 10 Mar 2023 22:30:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/69">@Xykon</a><br />
Hi. Good to see some activity.<br />
At first sorry for strong words, but announcing firmware updater tool without any firmware update have no sense for me.</p>
]]></description><link>https://forum.pycom.io/post/41478</link><guid isPermaLink="true">https://forum.pycom.io/post/41478</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Fri, 10 Mar 2023 22:30:18 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Sun, 12 Mar 2023 16:10:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a> I understand that but there were some problems with the current updater:</p>
<p dir="auto">a) It didn't work on any Linux distributions released in the last 2+ years.<br />
b) It was impossible to release any updates to the current version on any OS because the build tools are no longer available.</p>
<p dir="auto">The new updater also has support for the esp32-s3 chip series, and while I don't have a release date for the F01-S3, it's good to start testing the updater to make sure everything is working.</p>
<p dir="auto">Firmware wise we are focusing on what we call internally the &quot;next generation&quot; firmware, which is based on MicroPython 1.19.1. Our priority is to support the F01-S3 first and then add support for the current modules based on the esp32.</p>
]]></description><link>https://forum.pycom.io/post/41479</link><guid isPermaLink="true">https://forum.pycom.io/post/41479</guid><dc:creator><![CDATA[Xykon]]></dc:creator><pubDate>Sun, 12 Mar 2023 16:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Mon, 13 Mar 2023 09:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/69">@Xykon</a> said in <a href="/post/41479">New Beta firmware updater 1.17.0.b0/b1</a>:</p>
<blockquote>
<p dir="auto">it's good to start testing the updater to make sure everything is working</p>
</blockquote>
<p dir="auto">Testing by Pycom team?</p>
<p dir="auto">Do not take me wrong, updater tool probably is now much much better, and gain new quality.<br />
But to test it by us, we need to have new firmware release, without it i suppose near noone can test it as most have recent firmware already installed ;-)</p>
]]></description><link>https://forum.pycom.io/post/41480</link><guid isPermaLink="true">https://forum.pycom.io/post/41480</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Mon, 13 Mar 2023 09:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Mon, 13 Mar 2023 10:23:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi Xycon,</p>
<p dir="auto">Since few days, I have some issues on the 1.16.6 udater which does not gives me Sigfox ID and PAC after firmware update on Fipy modules.<br />
I'm internet connected during operation and do no install firmware from local file.</p>
<p dir="auto">I also cannot install pybytes legacy firmwares, updater only gives me the choice between 1.20+ versions, in online mode. It was possible few week ago</p>
<p dir="auto">Is there any other way to get Sigfox PAC/ID than firmware updater?</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.pycom.io/post/41481</link><guid isPermaLink="true">https://forum.pycom.io/post/41481</guid><dc:creator><![CDATA[Vin883]]></dc:creator><pubDate>Mon, 13 Mar 2023 10:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to New Beta firmware updater 1.17.0.b0&#x2F;b1 on Mon, 13 Mar 2023 22:02:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello, im new ok this of pycom, and i can't find a way to update the device, the software say access denied.<br />
im not ussign the expansion board, idk if it's for that i needed do something more before updating.</p>
]]></description><link>https://forum.pycom.io/post/41484</link><guid isPermaLink="true">https://forum.pycom.io/post/41484</guid><dc:creator><![CDATA[ErickM]]></dc:creator><pubDate>Mon, 13 Mar 2023 22:02:10 GMT</pubDate></item></channel></rss>
