<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Looking for general advices concerning usage]]></title><description><![CDATA[<p dir="auto">I am just not satisfied with my Sipy. At all.<br />
Communicating with it hard, at best. After Pymakr stopped working/started corrupting files there are too many workarounds to be done.<br />
I am using Filezilla which I can connect to via 192.168.4.1:21 almost every time. I have a very hard time transferring files. I succeed maybe every fifth try.<br />
When the files are uploaded I can't get a serial output. I tried every serial monitor I can think of.<br />
I get the messages when I hardreset the device or prompt it via the monitor.</p>
<p dir="auto">What do you guys do?<br />
Has anyone found a way to make working with the boards worth the effort?</p>
<p dir="auto">Best, Mathias.</p>
]]></description><link>https://forum.pycom.io/topic/793/looking-for-general-advices-concerning-usage</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 07:03:22 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/793.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Feb 2017 11:11:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:51:56 GMT]]></title><description><![CDATA[<p dir="auto">Expansion board.<br />
Sry for late answers. Must wait 600s between different replies.</p>
]]></description><link>https://forum.pycom.io/post/4724</link><guid isPermaLink="true">https://forum.pycom.io/post/4724</guid><dc:creator><![CDATA[maku]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maku" aria-label="Profile: maku">@<bdi>maku</bdi></a><br />
Do you use Expansion board or some TTL USB to UART converter?</p>
]]></description><link>https://forum.pycom.io/post/4722</link><guid isPermaLink="true">https://forum.pycom.io/post/4722</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:22:20 GMT]]></title><description><![CDATA[<p dir="auto">Done - changed nothing.</p>
]]></description><link>https://forum.pycom.io/post/4721</link><guid isPermaLink="true">https://forum.pycom.io/post/4721</guid><dc:creator><![CDATA[maku]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:22:20 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:10:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maku" aria-label="Profile: maku">@<bdi>maku</bdi></a> said in <a href="/post/4719">Looking for general advices concerning usage</a>:</p>
<blockquote>
<p dir="auto">Firmware is 1.6.3.b1</p>
</blockquote>
<p dir="auto">then try upgrade board to 1.6.5 - and back with results.</p>
]]></description><link>https://forum.pycom.io/post/4720</link><guid isPermaLink="true">https://forum.pycom.io/post/4720</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:08:59 GMT]]></title><description><![CDATA[<p dir="auto">Firmware is 1.6.3.b1 and code is:</p>
<pre><code>import os
print (os.uname().release)
for i in range(100):
	print("Hello Again World")
``</code></pre>
]]></description><link>https://forum.pycom.io/post/4719</link><guid isPermaLink="true">https://forum.pycom.io/post/4719</guid><dc:creator><![CDATA[maku]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:08:59 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 12:07:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maku" aria-label="Profile: maku">@<bdi>maku</bdi></a><br />
is this with latest firmware? 1.6.5?<br />
And do you have some code running on board with <code>while true:</code> loop in the same time when you are connected by ftp?</p>
]]></description><link>https://forum.pycom.io/post/4718</link><guid isPermaLink="true">https://forum.pycom.io/post/4718</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:07:39 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 11:56:38 GMT]]></title><description><![CDATA[<p dir="auto">I use FileZilla with mentioned settings. As mentioned I can prompt the board, I can see hardreset. But I cannot ever see print from code.<br />
This is what FileZilla looks like.<br />
<img src="/uploads/files/1488282568527-filezillatosipy-resized.png" alt="0_1488282563984_FileZillaToSipy.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">BTW: The "last modified" date doesn't look that good. Anynw else that has seen that?</p>
]]></description><link>https://forum.pycom.io/post/4716</link><guid isPermaLink="true">https://forum.pycom.io/post/4716</guid><dc:creator><![CDATA[maku]]></dc:creator><pubDate>Tue, 28 Feb 2017 11:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 11:45:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maku" aria-label="Profile: maku">@<bdi>maku</bdi></a><br />
Hi maybe some specific Sipy problem (i have only Wipy2) but maybe not</p>
<ol>
<li>did you configure filezilla to use only one connection?<br />
<a href="https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html?highlight=filezilla" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html?highlight=filezilla</a></li>
<li>I use com port monitor from Arduino IDE with succesfull</li>
<li>What is your firmware version?</li>
</ol>
<pre><code>os.uname()
</code></pre>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rskoniec" aria-label="Profile: rskoniec">@<bdi>rskoniec</bdi></a> you are faster ;-)</p>
]]></description><link>https://forum.pycom.io/post/4715</link><guid isPermaLink="true">https://forum.pycom.io/post/4715</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 28 Feb 2017 11:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to Looking for general advices concerning usage on Tue, 28 Feb 2017 11:43:17 GMT]]></title><description><![CDATA[<p dir="auto">On my LoPys I'm using PuTTY as serial port monitor and Filezilla for file transfer without any problems.</p>
<p dir="auto"><strong>Important note for Filezilla:</strong></p>
<p dir="auto"><a href="https://docs.pycom.io/pycom_esp32/pycom_esp32/general.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.pycom.io/pycom_esp32/pycom_esp32/general.html</a></p>
<p dir="auto"><em><strong>FileZilla settings</strong></em></p>
<p dir="auto"><em>Do not use the quick connect button, instead, open the site manager and create a new configuration. In the General tab make sure that encryption is set to: Only use plain FTP (insecure). In the Transfer Settings tab limit the max number of connections to one, otherwise FileZilla will try to open a second command connection when retrieving and saving files, and for simplicity and to reduce code size, only one command and one data connections are possible. Other FTP clients might behave in a similar way.</em></p>
]]></description><link>https://forum.pycom.io/post/4714</link><guid isPermaLink="true">https://forum.pycom.io/post/4714</guid><dc:creator><![CDATA[rskoniec]]></dc:creator><pubDate>Tue, 28 Feb 2017 11:43:17 GMT</pubDate></item></channel></rss>
