<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[expansion board 2.1a]]></title><description><![CDATA[<p dir="auto">Hi there, I have a question.</p>
<p dir="auto">My brand new lopy and expansion board 2.1a has arrived by post :) the packaging was super and it was a joy to unpack it :) (thx pycom.. so far it is excellent). But after hooking up the expansionboard (with the lopy module) to my laptop (windows 7) via a checked usb cable, the board wasn't recognised (I followed the manual via <a href="http://docs.pycom.io" target="_blank" rel="noopener noreferrer nofollow ugc">docs.pycom.io</a> on the website...) After some seaching and finding out  via the device manager I saw there was a problem with a missing FTDI driver (FT230X Basic UART). I installed it but still the board still wasn't recognised.</p>
<p dir="auto">I even put in a micro sd card in the expansion board, just to check out if reading / writing works. but no dice :(</p>
<p dir="auto">I'm I doing something wrong here?</p>
<p dir="auto">I hope someone has the same issues and knows how to fix this. I'm not able to update the firmware and / or use IDLE.</p>
<p dir="auto">With kind regards, Jeroen</p>
]]></description><link>https://forum.pycom.io/topic/885/expansion-board-2-1a</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 18:03:01 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/885.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Mar 2017 15:21:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to expansion board 2.1a on Fri, 24 Mar 2017 17:31:51 GMT]]></title><description><![CDATA[<p dir="auto">hi all, thx for all the responses, i've got the exp. board (in combination with the lopy) working. the vcp driver did the trick :) thx :) :)</p>
]]></description><link>https://forum.pycom.io/post/5594</link><guid isPermaLink="true">https://forum.pycom.io/post/5594</guid><dc:creator><![CDATA[joena]]></dc:creator><pubDate>Fri, 24 Mar 2017 17:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to expansion board 2.1a on Sat, 18 Mar 2017 21:50:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joena" aria-label="Profile: joena">@<bdi>joena</bdi></a> Please check this <a href="https://forum.pycom.io/topic/763/firmware-upgrade-troubleshooting-checklist-procedure">topic</a></p>
]]></description><link>https://forum.pycom.io/post/5376</link><guid isPermaLink="true">https://forum.pycom.io/post/5376</guid><dc:creator><![CDATA[rskoniec]]></dc:creator><pubDate>Sat, 18 Mar 2017 21:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to expansion board 2.1a on Sat, 18 Mar 2017 19:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a> hi robert,<br />
Thx for your reply, I appriciate it :) I will check out your advice this monday (when I have access to the lopy/exp. board).<br />
Kind regards, Jeroen</p>
]]></description><link>https://forum.pycom.io/post/5375</link><guid isPermaLink="true">https://forum.pycom.io/post/5375</guid><dc:creator><![CDATA[joena]]></dc:creator><pubDate>Sat, 18 Mar 2017 19:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to expansion board 2.1a on Fri, 17 Mar 2017 16:58:41 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/joena" aria-label="Profile: Joena">@<bdi>Joena</bdi></a>,</p>
<p dir="auto">no, you would not see the SD card. The connection through USB is purely a Virtual Com Port. Which means - you need the VCP drivers. You should see the new COM port in the device manager. If not, there is a problem with the driver, the cable or the jumpers. If all of the is ok, you should get an REPL prompt in an terminal emulation program like putty or teraterm (115200 baud, 8 bit, no parity).</p>
]]></description><link>https://forum.pycom.io/post/5359</link><guid isPermaLink="true">https://forum.pycom.io/post/5359</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 17 Mar 2017 16:58:41 GMT</pubDate></item><item><title><![CDATA[Reply to expansion board 2.1a on Fri, 17 Mar 2017 15:53:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi there, thx for your quick response. All the headers are in place. I even reconnected them. I use the board (and LoPy unit) at work. A second module (I bought two boards and lopy's) is still in it's package at work. I will test the second unit on monday.  Is it correct when i say this: If I connect the Expansion Board (so without the LoPy module) and I insert a Micro SD card. Do I See it in my Explorer (in Windows)?? Just to see / check if usb connection is ok/correct??</p>
<p dir="auto">Thx, Jeroen</p>
]]></description><link>https://forum.pycom.io/post/5356</link><guid isPermaLink="true">https://forum.pycom.io/post/5356</guid><dc:creator><![CDATA[joena]]></dc:creator><pubDate>Fri, 17 Mar 2017 15:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to expansion board 2.1a on Fri, 17 Mar 2017 15:25:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/joena" aria-label="Profile: joena">@<bdi>joena</bdi></a>,</p>
<p dir="auto">Somtimes, in transit, the expansion board headers slip off and need to be re-attached!</p>
<p dir="auto">Check out this forum post to see if your headers are all there!</p>
<p dir="auto"><a href="https://forum.pycom.io/uploads/files/1487695521217-img_6970-resized.jpg">https://forum.pycom.io/uploads/files/1487695521217-img_6970-resized.jpg</a></p>
<p dir="auto">Let me know how you get on :)</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.pycom.io/post/5354</link><guid isPermaLink="true">https://forum.pycom.io/post/5354</guid><dc:creator><![CDATA[bucknall]]></dc:creator><pubDate>Fri, 17 Mar 2017 15:25:46 GMT</pubDate></item></channel></rss>
