<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Input Voltage for Pin]]></title><description><![CDATA[<p dir="auto">Hello There,</p>
<p dir="auto">I would like to confirm that Max Input voltage for an input to WiPy 2.0 is 3.3V. Am I right? ...so If I connect a switch to a pin, it has to be at 3.3v.</p>
<p dir="auto">Cheers<br />
ColombianAus</p>
]]></description><link>https://forum.pycom.io/topic/895/input-voltage-for-pin</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 19:57:38 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/895.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2017 11:25:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Input Voltage for Pin on Mon, 20 Mar 2017 11:25:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello There,</p>
ColombianAus</p>
]]></description><link>https://forum.pycom.io/post/5399</link><guid isPermaLink="true">https://forum.pycom.io/post/5399</guid><dc:creator><![CDATA[ColombianAus]]></dc:creator><pubDate>Mon, 20 Mar 2017 11:25:49 GMT</pubDate></item><item><title><![CDATA[Reply to Input Voltage for Pin on Mon, 20 Mar 2017 12:14:06 GMT]]></title><description><![CDATA[<p dir="auto">According to the data sheet, the maximum input voltage for a digital input is 3.3V. The maximum input voltage for the analog Pins vary according to the attenuator setting and should not higher than the analog range. I remeber to have seen a spec about that, but cannot find it again.<br />
If you connect a switch with a longish wire, please add protection circuitry, at least an RC lowpass (e.g. 100k in series/1nF to GND) element as close as possible to the input to suppress spikes.<br />
Please not</p>
]]></description><link>https://forum.pycom.io/post/5405</link><guid isPermaLink="true">https://forum.pycom.io/post/5405</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Mon, 20 Mar 2017 12:14:06 GMT</pubDate></item></channel></rss>
