How to accomplish lora.nvram_restore() ?
  • I'm trying to understand saving & restoring lora nvram.
    In boot.py I connect to TTN, send a packet, and do "lora.nvram_save()".
    the packet is received.
    main.py is:
    from network import LoRa
    s.setblocking(False)
    s.send('LoRa Continues')
    The second packet is not received.
    I've also tried lora = LoRa(). Also no success.
    Any idea what I'm missing?
  • Yes, thank you. I know I only need save/restore for deepsleep. But was testing it without deepsleep. Shouldn't it still work?
    Still looking for any posted example of use of save / restore.
    Yes, splitting code irrelevant if deepsleep.
  • @jalperin you only need to use nvram_save / nvram_restore if you use deep sleep.
    Also I'm not quite sure what's your logic for having some of the code in boot.py and some in main.py. Both are executed sequentially.
  • Update.
    comment out lora.nvram_restore() and the second message is received.
    Do I need more code or is the restore messing up?
