Deep Sleep Summary
For Pytrack, could include (if I am right)
- GPS/Accel powered during deep sleep: No (explain low 20µA deep sleep current)
For Pysense, something is obviously powerd which consume 2.5mA, but as electric schematics is not avail, it is difficult to say...
@Emmanuel-Goudot
The Pysense problem was fixed yesterday https://forum.pycom.io/post/10039 -
Great summary. I agree with @RobTuDelft: many people and projects are waiting on this to settle so some definitive conclusion from pycom would be great. They're doing such a great job but we need to know what they've done or what they're working on.
Still the current with the sipy is 89mA
just doing this
from deepsleep import DeepSleep import pycom pycom.heartbeat(False) ds = DeepSleep() while True: ds.go_to_sleep(60) # go to sleep for 60 seconds print("Woke up") -
Well turns out that if you put it backwards like the Official documentation
https://docs.pycom.io/chapter/datasheets/downloads/deepsleep-pinout.pdf
you will fry it..
i put the other shield for my other sipy the correct way and now it works. 620uA
@iotmaker See this post for the correct orientation of the deep sleep schield
@iotmaker How are you measuring the current?
@PeterBaugh From the battery positive lead in series to the VIn of the expansion board
I'm using LopY with Expansion board. SW upgraded to ver 1.7.8.b1
I tried deepsleep functionality simple as below.
import machine machine.pin_deepsleep_wakeup(['P18', 'P15'],machine.WAKEUP_ALL_LOW, True) machine.deepsleep(15*1000) print("\n\n Wakeup", machine.wake_reason())The board is going to sleep and indeed is waking up on P18 dumping the following output .
rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff9010,len:12 ho 0 tail 12 room 4 load:0x3fff9020,len:388 load:0x40078000,len:11584 load:0x4009fc00,len:848 entry 0x4009fd9c** I don't understand why the LoPy was reset after this wakeup **
In order to dump the reason, I also added in main.py the following
print("\n\n Wakeup main reason", machine.wake_reason())and has no output
Wakeup main reason (1, [])** I believe there is bug that no GPIO is mentioned in that list **
@Colateral wake from deep sleep is actually similar to a reset: as the CPU and its RAM are not powered during deep sleep, you can't just resume at the next Python instruction, as it restarts from scratch.
Differentiating a wake up from deep sleep from other reasons (regular power on, reset...) is still a bit difficult, the subject has already been discussed in other threads.
@jcaron Thank you.
Yes, in the meanwhile I read dozens of posts. The question is why after reset I don't get the GPIO pin that triggered the wakeup?
Do the deepsleep shield fixing this GPIO wake up cause bug?
Actually, If the Lopy is working fine with this reset what else is enhancing the deepsleep shield? -
@iotmaker I am measuring the same power comsumption ... 620 uA with expansion board and 520 uA without it.
@rloro338 said in Deep Sleep Summary:
I am glad i am not the only one.. I just took another sipy updated firmware and deepsleep library and same issue 520uA really far from 7 or 10 ua
Hi, I have a SiPy + Pysense + 3.7 V LiPo battery. I'm testing Deep sleep mode from Pysense library but the multimeter is not showing 12 µA current consumption.
SiPy firmware: 1.18.0
Pysense firmware: 0.0.8My program disabled WiFi in boot.py. In main.py I blink an LED for 5 seconds and then go to sleep. These are my results:
Blinking: ~50 mA
Deep sleep: ~2.2 mAmain.py code:
from pysense import Pysense import pycom import time py = Pysense() #Turn-of heartbeat if pycom.heartbeat() == True: pycom.heartbeat(False) for i in range(5): pycom.rgbled(0x1F) time.sleep(0.05) pycom.rgbled(0x00) time.sleep(1) #Sleep 20 seconds py.setup_sleep(20) py.go_to_sleep()Is there any piece of code I'm missing? What are you doing to get 12 µA with the Pysense board?
@dmayorquin never tried with a SiPy, only a LoPy, but the end result should be the same as the PySense will completely switch off the module.
The usual culprit is powering through USB, but if I understand correctly your setup, this is not the case. You are connecting the battery directly to the JST-PH connector on the Pysense, right?
Do you have anything else connected? Do you have an SD card in the slot? You haven’t setup any of the sensors to remain awake (like accelerometer wake up)?
Hi @jcaron , thanks for your fast answer. Yes, I'm connecting the battery directly to the JST connector on the Pysense and I'm not using any sensor or SD card. In boot.py I disable WiFi:
from network import WLAN wlan = WLAN() wlan.deinit()And main.py code is exactly as It's shown in my previous reply. I'm going to try with other releases of SiPy firmware. If you have any suggestion please let me know.
@dmayorquin Did you resolve this issue? Looking at your code, one question comes to mind that I have been looking to find an answer to.
You use py.go_to_sleep() to enter sleep mode which is part of the Pysense class.
Is that that call functionally equivalent to machine.deepsleep() ?
@sslupsky if you have one of the older modules (LoPy 1, SiPy, WiPy 2), then there is an issue with the “native” deep sleep (
machine.deepsleep) which results in a higher than expected power draw during deep sleep (>10 mA instead of 10-20 uA).For those modules, the workaround to achieve low current deep sleep is to use an external board: Deep Sleep Shield, PySense or PyTrack, and the relevant library. This will cut all power to the module during deep sleep.
If you use one of the more recent modules, you should in most cases use the native deep sleep.
Hi @sslupsky, I solved the issue and the complete code is here: https://forum.pycom.io/topic/3594/how-to-deep-sleep-with-sipy-pysense-3-7v-lipo/3
As @jcaron says, machine.deepsleep() works well with the new hardware, but I'm not sure it works too when your setup has a shield like Pysense. In that case I've read that you should use the deep sleep method from Pysense library (or Pytrack or whatever shield you're using).
