LoPy corrupted when powered by USB and works fine when powered via PINs
This is when the LoPy is powered by USB. When I power it up via PINs in 2 conditions it works:
- USB not plugged and PINs plugged
- USB plugged in and PINs plugged.
This is happening to 2 of my LoPys. Is this some kind of hardware fault? They working perfectly before...
@finnzc Did you try another USB cables. Maybe it's somehow degraded.
The same USB cable works fine with all other LoPys so I don't think it is a problem related to the cables nor the USB ports...
