    Error sending payload. SiPy Sigfox. **SOLVED**
    sipysigfoxpayloadcrash
    3 Posts 1 Posters 1.6k Views 1 Watching
      scg94
      Hello, good day to all.
      I have done tests from the console sending data to Sigfox's Backend, however when I do it from the code it is blocked the moment it is sent:
      s.send(bytes(payload))
      And this is the code I use:
      import time, utime, machine, dht, socket
      from machine import Pin, Timer, WDT
      from network import Sigfox
      ID_ESTACION=2
      T_ESTACION=114 #114 es la R en DEC --- 99 es la C en DEC --- 97 es la A en DEC
      FlagWDT = 0 #Bandera del WDT
      #wdt = WDT(timeout=60000) #inicializamos WDT con tiempo de 1 minuto
      pycom.heartbeat(False) #Apagamos el led
      #Código para leer Temperatura y Humedad
      th = dht.DTH(Pin('P11', mode=Pin.OPEN_DRAIN),1)
      tem=0
      hum=0
      result=0
      cont=0
      #time.sleep(2)
      #result = th.read()
      def readTemHum():
          global tem, hum
          cont=0
          #time.sleep(2)
          result = th.read()
          while result.is_valid()==False:
              result = th.read()
          if result.is_valid():
              tem=result.temperature/1.0
              hum=result.humidity/1.0
              #print('Temperatura: {:3.2f}'.format(tem))
              #print('Humedad: {:3.2f}'.format(hum))
              tem=tem
              hum=hum
      #FIN Código para leer Temperatura y Humedad
      #Código para leer e interpretar el ULTRASONIDO
      Pin('P5', mode=Pin.OUT, value=1)
      def tramaUltrasonic():
          uart1.readline()
          dist = 0
          cont=0
          for cont in range(0,5):
              dist=uart1.readline()
              Pin('P5', mode=Pin.OUT, value=0)
              time.sleep(0.15)
          return dist
      last_value=0
      def readUltrasonic():
          global last_value
          #separado = 0
          dist=tramaUltrasonic()
          valS=str(dist)
          #print(valS)
          try:
              separado=valS.split("b'R")
              separado = separado[1].split("\\")
              separado = separado[0]
              last_value=int(separado)
              return last_value
          except IndexError:
              #print("error")
              return last_value
              pass
      #FIN del Código para leer e interpretar el ULTRASONIDO
      #Pasar valor de los sensores a Bytes
      def int_to_bytes(value,length):
          result = []
          for i in range(0, length):
              result.append(value >> (i * 8) & 0xff)
          result.reverse()
          return result
      #FIN de Pasar valor de los sensores a Bytes
      #Codigo de conexión Sigfox
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4)
      s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
      s.setblocking(True)
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
      def sendsig(payload):
          print("Enviando Datos...")
          envio.callback(None)
          print(payload)
          print(bytes(payload))
          #s.send(bytes(payload))
          pycom.rgbled(0x7f0000) #ROJO
          print("Pasa el time: ",payload)
      #FIN Codigo de conexión Sigfox
      #Código para Enviar Datos
      payload=0
      envio = Timer.Alarm(None, 25, periodic = True) #299 segundos para 5 minutos
      def EnviarDatos(alarm):
          global payload
          pycom.rgbled(0x007f00) #Verde
          ultra=readUltrasonic()
          readTemHum()
          ID_EST=int_to_bytes(ID_ESTACION,1)
          ultraB=int_to_bytes(ultra,2)
          temB=int_to_bytes(int(tem*10),2)
          humB=int_to_bytes(int(hum),1)
          T_EST=int_to_bytes(T_ESTACION,1)
          payload=int(ID_EST[0]),int(ultraB[0]),int(ultraB[1]),int(temB[0]),int(temB[1]),int(humB[0]),int(T_EST[0])#Debe estar ordenado según se reciben en el Backend de Sigfox
          print("Valor a enviar: ",payload)
          print(type(payload[0]))
          sendsig(payload)
          #wdt.feed() #Alimentamos el WDT
          pycom.rgbled(0x000000) #Negro
          global FlagWDT
          FlagWDT=1
      #FIN del código para Enviar Datos
      while FlagWDT==0:
          envio.callback(EnviarDatos)
      time.sleep(2)
      #machine.deepsleep(588000) #duerme 9,8 min + 30 segundos que demora enviar el mensaje serían 10,30 min, equivalentes a 139.8 mensajes al día
      The payload that is sent is of this type:
      >>> print(payload)
      (2, 2, 183, 1, 38, 55, 114)
      >>>type(payload)
      <class 'tuple'>
      I've done the testing by sending this payload from the console and I have no problem, but when I load the code in SiPy, it crashes.
      I hope you can help me. Thank you and happy day.
        scg94
        Ok, I've noticed that there is a compatibility problem between the UART read and the socket to send to the Sigfox network.
        I will try to solve it and then we will see.
          scg94
          Hi everyone.
          I want to tell you that I have already solved the problem. There is a conflict with the line in which I declare a Pin as output and the moment in which it is transmitted:
          What I did was change the pin to P13, this ended the problem and I was able to transmit without any inconvenience and see the data in the Sigfox Backend.:
          Pin('P13', mode=Pin.OUT, value=1)
          0_1504880078593_upload-1af3b981-1883-46c5-afa3-16dfe2bcb8ef
