    Does deepsleep work at all
    deepsleep
    83 Posts 20 Posters 52.5k Views 23 Watching
      chumelnicu @chumelnicu
      @chumelnicu Hi Daniel, sorry for late update but i was in holliday until yesterday.
      I did try deepsleep with new DeepSleep library and llopy behive same. After 14-15 DS cycles program stop running.
      I use lopy with DS Shield powered from USB and nothing on Pin12.
      Condition to wake up, is time, w-up after 10 minutes.
      Do u have any ideea what is wrong?
      Thx !
        tmz @daniel
        @daniel The result is the same. Stops after (5 - 20) cycles. How do i run in more verbose way? There is no error, it's jumps into REPL.
          chumelnicu @daniel
          @daniel Could you tell me how and when DeepSleep will work ? Im not only one who claim about this problem and I think is really time to clarify with your team what is happening
          Thank you !
            Robin @adam_IoTK
            @adam_IoTK
            I have the same problem with a LoPy + Deep sleep shield.
            My code runs for 20-40 times and then stops. Issue reported here: https://forum.pycom.io/topic/1685/lopy-with-deep-sleep-shield-is-unstable
            This is a blocker for any real world deployment.
            Not having seen any useful response from the Pycom team on the forum about this issue i am considering moving to another platform to get my project finished.
              The instability has been fixed here: https://github.com/pycom/pycom-libraries/commit/ea3e22c14884671801bcd1cfe49c703bc63c7078
              We are now working on reducing the deep sleep current.
              T R J C 4 Replies Last reply Reply Quote 0
                tmz @daniel
                @daniel
                Thank you! The issues seems to be fixed after this fix.
                Is > 8h without interruption.
                LoPy v1.7.9.b3
                Expansion board (with deep sleep shield)
                Fix: https://github.com/pycom/pycom-libraries/commit/ea3e22c14884671801bcd1cfe49c703bc63c7078
                  Robin @daniel
                  @daniel Seems to work for me too now.
                  Adding the garbage collector statements in the calling code seems to be crucial through.
                    johncaipa @daniel
                    @daniel I'm testing the deepsleep example but I get the following errors:
                    File "main.py", line 7, in <module>
                    File "/flash/lib/deepsleep.py", line 143, in get_wake_status
                    File "/flash/lib/deepsleep.py", line 76, in peek
                    IndexError: bytes index out of range
                    I am doing something wrong?
                    thanks
                      tmz @johncaipa
                      @johncaipa
                      Try the latest - https://github.com/pycom/pycom-libraries/blob/master/deepsleep/deepsleep.py
                        johncaipa @tmz
                        @tmz that is the library I'm using, and which errors are generated
                          Arnaud @tmz
                          @tmz said in Does deepsleep work at all:
                          Just tried the deepsleep example on Sipy 1.0 - Pytrack 1.0 with latest deepsleep.py and after firmware upgrade to 1.7.9b3 and got the same error than John.
                          I understood that Pytrack serves as deepsleep shield.
                          All this deepsleep troubles merged with lack of documentation is really frustrating...
                            @Arnaud with pytrack or pysense simply use their own libraries which also provide the deepsleep functionality:
                            https://github.com/pycom/pycom-libraries/tree/master/pytrack
                              Arnaud @Arnaud
                              Nice to hear that! Please help us with a bit more explicit documentation. You might be aware of this now based on the comments, you're building up hours of frustration which is not was intended at first I'm sure with the beautiful specs of your products.
                              BTW, I think deepsleep example lacks an import deepsleep for constants.
                                Arnaud @daniel
                                @daniel I've tried the latest pytrack lib for deepsleep with very simple main.py:
                                from pytrack import Pytrack
                                print( "Waking up")
                                Some job
                                print( "Going to sleep")
                                pytrack = Pytrack()
                                pytrack.setup_sleep( 10 )
                                pytrack.go_to_sleep()
                                Waking up with a buton press works.
                                Board never wakes up on timer.
                                  jcaron
                                  Just to make sure, you have the latest firmware (0.0.4 I believe) on the Pytrack? You can check with pytrack.read_fw_version().
                                    Arnaud @jcaron
                                    @jcaron read_fw_version returns 2.
                                    Since I haven't done any pytrack firmware upgrades since June, I'll assume I have to.
                                    This might be a hint for improving docs:
                                    Required Pytrack Firmware: x.y.z
                                      Arnaud @Arnaud
                                      @jcaron
                                      I have updated the pytrack firmware to 0.0.4 with DFU-util (Mac OSX).
                                      From there:
                                      The hearbeat (blue led) is not active anymore.
                                      I have a lot of troubles gettting a console connection to the board.
                                      Sometimes, the board executes main.py, prints a few lines but hangs on while printing firmware version and connection is lost.
                                        jmarcelino @Arnaud
                                        @Arnaud
                                        Can you try another USB cable?
                                          @Arnaud, I think the firmware upgrade failed. Just tried it again using the DFU procedure.
                                            Arnaud @daniel
                                            @daniel Got this during Pytrack firmware upgrade:
                                            Match product ID from file: f014
                                            Deducing device DFU version from functional descriptor length
                                            ID 04d8:f014
                                            Determining device status: state = dfuIDLE, status = 0
                                            dfu-util: WARNING: Runtime device already in DFU state ?!?
                                            Claiming USB DFU Interface...
                                            Setting Alternate Setting #0 ...
                                            dfuIDLE, continuing
                                            DFU mode device DFU version 0100
                                            Device returned transfer size 64
                                            Copying data from PC to DFU device
                                            Download [=========================] 100% 16384 bytes
                                            Download done.
                                            state(2) = dfuIDLE, status(0) = No error condition is present
                                            Done!
                                            • 5
                                            • 4 / 5
