Reading data through Uart
I am trying to connect my SiPy to an MSP430 through UART but am not receiving anything. I have used an Ardunio to test that it works so i know nothing is wrong on the MSP430 side of things. The code is stuck on the uart.any()<=0 part of the code. My python knowledge isn't great so it may be something simple. I am using pins P5 and P6 as they are not used by the pytracks which i am also using. My code is listed below any help would be appreciated.
Good pickup, I will try and use P10 and P11 unless you recommend anything else?
Edit, it works now thanks for the help
@chrisi Are not P5 and P6 connected to the Sigfox module?
https://docs.pycom.io/chapter/datasheets/downloads/sipy-pinout.pdf
