    Pymate fails to setup boot.py with the right known net
    Scheduled Pinned Locked Moved Pymate
    16 Posts 4 Posters 5.9k Views 4 Watching
    • X Offline
      Xykon administrators
      I ran a remote wireshark capture on my Wifi AP... after correcting the credentials in boot.py I can see the LoPy get its IP via DHCP, resolve mqtt.pycom.io as 198.199.124.44 and attempt to connect to port 1883.
      However the server replies with RST, ACK so the connection is reset. That's why the script is failing.
      Christian Ehlers
      K 2 Replies Last reply Reply Quote 0
      • K Offline
        kurt @Xykon
        @microman7k I'm trying to follow the code through a connect. One thing that sticks out is the MQTTClient using the select library for polling. But the Micropython documentation for the lopy says:
        Current objects that support polling are: pyb.UART, pyb.USB_VCP.
        So, maybe the LoPy is not ready yet for the Pymate?
        • K Offline
          kurt @Xykon
          @Xykon Yes, this confirms OSError 104 ECONNRESET 104 /* Connection reset by peer */
          I also tried
          >>> socket.getaddrinfo('mqtt.pycom.io', 1883)
          [(2, 1, 0, '', ('198.199.124.44', 1883))]
          A pleasant surprise, as socket.getaddrinfo() did not work last week.
          What's next? Why is the server resetting the connection? Timeout, wrong data...?
          My current plan is to get my WiPy working. It has a bad safe boot pin and I need to compile the firmware for another pin before trying Pymate on it...
          • X Offline
            The server mqtt.pycom.io does not listen on port 1883.
            nmap -p 1883 mqtt.pycom.io
            Starting Nmap 7.01 ( https://nmap.org ) at 2016-11-06 14:35 GMT
            Nmap scan report for mqtt.pycom.io (198.199.124.44)
            Host is up (0.022s latency).
            PORT     STATE  SERVICE
            1883/tcp closed unknown
            Nmap done: 1 IP address (1 host up) scanned in 0.10 seconds
            Christian Ehlers
            • K Offline
              kurt @Xykon
              @Xykon Meanwhile got my WiPy 1.0 working and upgraded it to the most recent firmware. But the result in regards to the Pymate is almost the same.
              Error: error connecting to the pymate server, connection closed
                File "boot.py", line 39, in <module>
                File "/flash/lib/pymate_basic.py", line 13, in <module>
                File "/flash/lib/pymate_library.py", line 354, in run
              KeyboardInterrupt:
              MicroPython v1.8.5-121-g5c3d75c on 2016-11-06; WiPy with CC3200
                microman7k
                @kurt Thanks, so we could agree that the problem is in pycom site? Hey, Pycom (@daniel) can you provide us with some information that Pymate is even working or not?
                  Roberto
                  Hello @kurt @microman7k
                  We have fixed this issue and updated some files in the server.
                  You will need to go to the setup stage again, delete your device by swiping it left and add it again.
                  To make sure that everything works properly please boot your device in safe mode
                  https://docs.pycom.io/lopy/lopy/general.html#boot-modes-and-safe-boot
                  and remove the connection between 3v3 and G28 (P12) when Pymate asks you to reset the device.
                  • X Offline
                    Xykon administrators @Roberto
                    @Roberto I gave this a quick test... the installation works OK now, the LoPy connects to my AP and I can see it go online and show the firmware version in Pymate.
                    I created a button in Pymate and told it to use digital pin 4.. I have an LED connected from P4 -> 1k resistor -> LED -> GND.
                    When I switch the button ON/OFF in Pymate the LED stays at a dim level.
                    When I bypass execfile('/flash/lib/pymate_basic.py') and use from machine import Pin; p_out = Pin('P4', mode=Pin.OUT); p_out(1) then the LED lights up bright and turns off with p_out(0).
                    I thought maybe Pymate is using expansion board numbers for digital pins so I also tried digital port 11 but I don't see any change.
                    Christian Ehlers
                      Roberto @Xykon
                      @Xykon I did the same test in my end and it works. To be clear, yes, the pins used by the apps are the expansion board pins (G 11) in you case.
                      Check List:
                      1. Go to the device list and refresh using the refresh button to make sure that the device is connected.
                      2. Once int he dashboard (widgets) long click on the button widget to edit. Make sure is of type button, and that is set the the right pin (11). As an output pin.
                      3. Save
                      4. Once back in the dashboard make sure you press the Plat button on the top. This will send the configuration of the pin to the device and allow you to use the button widget.
                      Make sure you do this before doing any code input in your device (for test propose) and check if the LED Turns on.
                      One last thing The User LED on the expansion board is the pin 16 G16. You can test with this Led first to make sure that everything is working as it should.
                      • X Offline
                        Thanks I got it to work now. I think I just didn't save it properly when switching from digital 4 to 11.
                        Christian Ehlers
                          Roberto @Xykon
                          @Xykon Great!. Hopefully @kurt will get it working as well
                          • K Offline
                            kurt @Roberto
                            @Roberto Yes, thank you, I got it working on the lopy as well. My wipy 1.0 is still resisting, but I'm not sure if this device is healthy. I try it again when I have more patience for it. Cheers!
                              Roberto @kurt
                              Great @kurt im glad to know that things are working on your side. Thanks for all the input
